This thread is about: space saver size, it's in Wheels, Tyres, Suspension and Brakes at the Honda Civic forum Civinfo; I have the oppurtunity to buy either a 135/70/15 or a 125/70/16 5 stud Honda space saver spare will any of these fit my 1.8 ...
Old 4th December 2007, 22:50   #1 (permalink)
MT Head's Avatar
space saver size
I have the oppurtunity to buy either a 135/70/15 or a 125/70/16 5 stud Honda space saver spare will any of these fit my 1.8 SE
MT Head is offline   Reply With Quote
Old 4th December 2007, 23:09   #2 (permalink)
No, the space saver is a 16 inch wheel with a 135/80/16 tyre fitted. Both of the two you have quoted are too small.
Old 4th December 2007, 23:10   #3 (permalink)
nigel8558's Avatar
yes go for the 16" one as long as it off a honda 5stud and the pcd is 114.3mm and bore is 64mm
nigel8558 is offline   Reply With Quote
Old 4th December 2007, 23:19   #4 (permalink)
I reckon the 125/70/16 tyre is too small. The overall height of the tyre wheel combination will be about 41mm too small compared to one of the normal wheels.
Best to check with your dealer if you are unsure. My spacesaver is a 135/80/16 tyre on a 16 inch rim.
Old 5th December 2007, 00:53   #5 (permalink)
Tyre Shredder
ritchie_perriam's Avatar
Hey MThead
what size wheels do you have on your car now?
you will need to find out the size of the wheels and tyres together,
to do this you need to convert the wheel diameter from inches to mm then times the tyre profile by 2 and add them together!
e.g. 16 inch wheels with 45 tyre profile would be 16in =406mm + (45 X 2)
=496mm diameter wheels
if you do the same calculations with your wheels and the 2 space savers you should see if they are similar sizes.
Old 5th December 2007, 01:11   #6 (permalink)
Originally Posted by ritchie_perriam View Post
Hey MThead
The figure 45 in a tyre size does not refer to a side wall height of 45 mm. It is the aspect ratio. It is a percentage of the width of the tyre. So for example a 135/80/16 tyre would have a side wall height equal to 80% of 135mm so 108mm.
A 205/45/16 tyre would have a side wall height equal to 45% of 205mm so it would be 92.25 mm.
Do you understand what I mean. MT Head, I've worked it out and both tyre/wheels you have quoted are too small.
Old 5th December 2007, 16:50   #7 (permalink)
MT Head's Avatar
Thanks to all who responded to my query, I think, with the info received I will give the 2 space savers a miss & keep a look out for the correct size. I have the T135/70D15 in my garage if anyone wants it, its going for £50 it has 5 stud holes & a new Bridgestone tyre which still has the bobbles on it, the wheel has 1 or 2 storage scratches.
Old 5th December 2007, 23:16   #8 (permalink)
Hi, How much has your dealer offered you the correct spare wheel kit for?
I bought mine for £100 inc vat and that included everything, the fixing kit, cargo net and a bag to put the normal road wheel in when removed from the car. I have to say the cargo net is really useful as I use it to stop things moving around in the boot.
Old 5th December 2007, 23:17   #9 (permalink)
Tyre Shredder
ahhh right. i always thought it was a measurement in mm! thanks for that!
Old 5th December 2007, 23:20   #10 (permalink)
No probs Ritchie, we all live and learn!!
Old 8th December 2007, 15:41   #11 (permalink)
eyemdee's Avatar
Same here - just collected it this morning after ordering last week. £100 inc VAT for the full kit included fitting tyre to wheel and a black plastic cover fitted over the tyre to stop it dirtying the boot!
eyemdee is offline   Reply With Quote
Old 8th December 2007, 19:30   #12 (permalink)
Honda customer services refunded my £100 after I sent my comments via their customer feedback form on the Honda website.
Might be worth a try!!!
Old 8th December 2007, 20:22   #13 (permalink)
Jack The Lad.'s Avatar
What exactly do you mean by "plastic cover" eyemdee. ??
Coz I didn't get one, unless you mean the bag for the damaged wheel.
If you mean the moulded plastic one shown in the U.K. manual, I shall be in the Dealers first thing next week, ---- shouting.
Old 8th December 2007, 22:04   #14 (permalink)
eyemdee's Avatar
It is like an bit of elasticated black bin liner wrapped around the tyre - probably what the tyre was originally shipped to the dealers in. I shall probably remove it as it serves no purpose once installed in the car.
@Dimplyred - I have to say when I read the review of the new Focus (sorry for swearing) on the Honest John web site and noticed that Ford charge £30 for a full sized steel spare wheel or offer a space saver f.o.c. in lieu of the inflation kit, I couldn't help feeling a little disappointed at the Honda price for this item! My dealer originally quoted £150 including fitting to the car until I started to walk away!
Old 8th December 2007, 22:11   #15 (permalink)
Thats O.K. then.
I was given a white bag. Why didn't I get a black one too.
Similar Threads for: space saver size
Spare Space Saver Wheel Compatibility dazaboy Wheels, Tyres, Suspension and Brakes 4 18th November 2007 22:13
Other another space saver question daiashthomas Wheels, Tyres, Suspension and Brakes 10 9th July 2007 16:12
Space Saver Wheel Andy68 General commercial posts 15 12th May 2007 19:22
Spare getting a free space saver MARK182 Wheels, Tyres, Suspension and Brakes 14 17th February 2007 21:31
Spare Finding a non Honda Space saver theonefelix Wheels, Tyres, Suspension and Brakes 2 11th December 2006 08:55
