| This thread is about: Road Camber Effect, it's in Wheels, Tyres, Suspension and Brakes at the Honda Civic forum Civinfo; Why do manufacturers not set up cars to compensate for camber on the road? I've had 4 Honda's in a row and there has always ... | ||
Road Camber Effect
Why do manufacturers not set up cars to compensate for camber on the road? I've had 4 Honda's in a row and there has always been a gentle drift to the left which can get tiring over a long journey. I presume all manufacturers are the same?
Could be a bit hard to do with every country having slightly diffrernt road building norms, would also be a problem if you go from Britain to "continental" Europe etc. I got so used to it that I barely notice it any more. This effect is present, yes, but was by far more noticeable on my previous (mainly French) cars
All cars fall down the camber - Newton made sure of that. Imagine you are driving in a straight line but the camber is a mad 45 degrees, you will quickly veer off downhill into the verge.
Some cars translate a small camber into a significant effort at the steering wheel - this is normally cars with precise and quick ratio steering. You can reduce the camber effect but then the steering feels dead... Dialling it out is not an option - if the camber is reversed or you drive on the continent, then the pull will be twice as bad! |
#5 (permalink) | |
Bournemouth Belle
I don't really notice it now but when my other half drove the car last week (he doesn't normally - its MY car....) he thought it was quite bad but then he drives a big van (a big renault traffic) for work everyday and never notices the camber in that.
If you think the camber is bad here just try driving in Florida - the camber can be a lot worse to help with drainage. Found ourselves going 'slightly' off road at times.... |
Random Monkey, that's a great spin normally given by salesmen, turning an undesirable trait into a safety feature. Of course, if such a feature really was engineered, it would be to send the car straight on to avoid stuff on both sides of the road.
Could be, but have it checked.
Had mine realigned twice (225/45-17 summer wheels). Had slightly toe-out and a bit negative camber, happy with that until I noticed inner tyre wear on my summer tyres. Got the car realigned - a few minutes toe-in - the handling went stiff and "unpleasant". Realigned once more - neutral (well a couple of minutes toe-out) and now I like the handling. Maybe a bit nervous at low speed due to the wide tyres but a good compromise. Amazing how small changes needed to feel the difference. |
| ABP Motorsport Camber Modification | Homer Simpson | ABP Motorsport | 10 | Yesterday 18:44 |
| camber adjustment? and Induction kit! | u05rdh | Type-R | 5 | 12th February 2008 19:17 |
| Road Tax | JPDirect | General Discussion | 13 | 9th October 2007 17:01 |
| Who's seen a type R on the road? | DanKo | Type-R | 38 | 23rd March 2007 13:36 |
| Used Just bought a used Civic, the HDS effect! | golly | Buying, Dealers and Servicing | 13 | 21st January 2007 08:42 |
