| This thread is about: Uneaven tyre wear, it's in Wheels, Tyres, Suspension and Brakes at the Honda Civic forum Civinfo; hi guys. ive got a 1997 1.5vtece honda civic 5 door. its lowered 40mm all round and ive got 17" alloys on it. ive noticed ... | ||
Uneaven tyre wear
hi guys. ive got a 1997 1.5vtece honda civic 5 door. its lowered 40mm all round and ive got 17" alloys on it. ive noticed that my tyres are wearing out on the inside edge on all 4 wheels. ive had a 4 wheel alignment done and had the tracking checked in 3 diffrent garages and they said it was spot on. i got the new tyres put on 4 months ago after the same thing happend to the old ones and there is about 1.5 to 2mm diffrence in the ouside tread and the inside. has anyone got any ideas to what is wrong with it??
the car was ok before about 7 months ago but i had a problem with the front brake sticking which the mechanic thought caused the uneaven tyre wear. so i got that fixed and had to get new tyres aswell and ever since then ive had the problem.
Had a slight front tyres inner wear (also posted in another thread here...).
Measured the suspension - had 0°09' toe-out on both sides. Camber was 0°20' and -0°07'. All values are (barely) within specifications, but they all worked in the same direction - inner tyre wear. So I had it realigned. Seems like the civic is pretty touchy on this. Btw - only summer tyres 225/45-17 seems affected. Winter tyres 205/55-16 doesn't show any sign of inner tyre wear. |
This has to be something with the suspension setup, possibly in conjunction with the particular tyres you have fitted (which might be more sensitive to loading changes). When you changed them, did the tyre model change too? Either way, the core problem is most likely to be the camber change as a direct result of the rideheight change (the two go hand in hand, can't change the rideheight without some impact on the camber).
Courant |
Got Michelin Primacy summer tyres and Conti WinterContact studless winter tyres, all original delivered with the car.
(In Norway all cars are delivered with two set of wheels - summer and winter - plus eventually a spare (which I haven't)). However the summer tyres have longer mileage and experienced much more base friction, suppose that counts. |
yeh i did put diffrent make tyres on it. but the tyres that were originaly with the alloys when i bought the car was ok then all of a sudden the tyres went bold. what im gona try now is put more of a toe in on the front to c how it goes
LinkBack to this Thread: http://www.civinfo.com/forum/wheels-tyres-suspension-brakes/13912-uneaven-tyre-wear.html
| Sjí?d?ní pneumatik | Honda CIVIC 8. generace | This thread | Refback | 22nd July 2008 08:25 | |
| Brakes Brake wear | Kpow99 | Wheels, Tyres, Suspension and Brakes | 79 | 16th August 2008 12:27 |
| Suspension Inner tyre wear | GHGH | Wheels, Tyres, Suspension and Brakes | 10 | 20th May 2008 08:25 |
| Tyre Life Another tyre with a nail / Poor tyre wear, What should I do | nelster | Wheels, Tyres, Suspension and Brakes | 3 | 6th March 2008 09:46 |
| Tyne & Wear | civie | Wiki Article Discussion | 0 | 4th February 2008 20:24 |
| Tyre Life Uneven tyre wear | Miggins | Wheels, Tyres, Suspension and Brakes | 57 | 14th April 2007 11:31 |
