This thread is about: Bump Stops, it's in Wheels, Tyres, Suspension and Brakes at the Honda Civic forum Civinfo; I have a knock like a loose exhaust coming from the back of my 1.8 Civic. I mentioned this at the 1st service and was ...
Old 16th May 2008, 17:23   #1 (permalink)
Bump Stops
I mentioned this at the 1st service and was told to bring it back and they would fit bump stops to the rear suspension.
Just got it back....same knock.... Had a look under car at the rear shocks and cant see any new additions to the set up.
Where would bump stops be fitted
civicj1 is offline   Reply With Quote
Old 16th May 2008, 20:35   #2 (permalink)
you`ll see the bump stops that your dealer is refering to are fitted on the front suspension struts within the coil spring,the new ones should be identified by there white colour,just have a quick look under the wheelarch near the top of the front spring,the origanal bump stops on the front struts have been manufactured wrong & are too small so tend to fall out after a period of driving resulting in a knocking/thumping noise from the suspension,so these get replaced with a modified part which is designed slightly bigger so as not to fall out.im sure they looked at your car & this was a fairly obvious problem associated with your complaint about a noise from the suspension !
hondatech is offline   Reply With Quote
Old 16th May 2008, 23:02   #3 (permalink)
Bump Stops
Thanks for the reply. Are there similar bump stops on the rear suspension. The noise seems to be coming from the rear of the car.
Old 17th May 2008, 10:49   #4 (permalink)
Bump Stops
Hi again. I have just checked my front suspension and found the bumpstops that were mentioned. Off side is white and nearside is purple.
Any sugestions
Old 17th May 2008, 19:25   #5 (permalink)
it looks like they have just replaced the one on the offside of your car as you have identified it by its white colour,from what ive seen on the rear of 06 civics there are no conventional type bump stops fitted,i see numerous cars come in at work with the same complaint of a knocking noise from the rear,normally when reversing first thing in the morning,apart from all the usual checks of springs fitted wrong way up,faulty shockers,exhaust rubbers with incorrecrt clearance you can never see anything obviously wrong but that said although people complain about the noise from the rear you invariably find the front bump stops adrift from there mounts , so these need to get sorted first.
Old 17th May 2008, 20:26   #6 (permalink)
Any sugestions
I guess unless Honda has changed the colour coding this can't be right.
Anyway, on mine the faulty ones were yellow and the OK replacements are white (BTW they said the whole struts were replaced on mine)
Old 18th May 2008, 09:09   #7 (permalink)
My apologies civic fan/hondatech On checking again, this time using a torch, the nearside stop is yellow. Better get my colour vision checked out. Will go back to dealer tomorrow and see just what has been done.
Thanks once again for the info.
Old 18th May 2008, 09:28   #8 (permalink)
fennj's Avatar
Have you tried driving without your parcel shelf fitted ? That's how I identified my rear knocking noise before I did this I was sure that it was something to do with the suspension.
fennj is offline   Reply With Quote
Similar Threads for: Bump Stops
Loose bump stops Altimocivic Wiki Article Discussion 0 30th March 2008 21:30
Suspension Bump Stops slowhand Wheels, Tyres, Suspension and Brakes 73 26th October 2007 07:53
Seats Annoying bump in my seat JuhaR Bugs, faults and irritations 3 4th May 2007 12:24
Windows Electric windows stops working after opening door pikkumies Bugs, faults and irritations 1 20th June 2006 17:40
