This thread is about: Upgrade suspension without lowering?, it's in Wheels, Tyres, Suspension and Brakes at the Honda Civic forum Civinfo; Does anyone know of a suspension upgrade that doesn't result in the Civ sitting lower? There's a speed bump on my street I have to ...
Old 4th June 2008, 00:29   #1 (permalink)
kissifer1972's Avatar
There's a speed bump on my street I have to take at about 10MPH or else I catch the front on it and if I go lower god knows what it will do.
Also don't want too sporty a ride, it's a family car not a CTR.
Chris
kissifer1972 is offline   Reply With Quote
Old 4th June 2008, 05:29   #2 (permalink)
-=Stella Artois=-'s Avatar
K & W do 3 variants for the Civic
Height Adjustable.
Height and Rebound
and Firmer stock.
KW Site
HTH.
Marc.
-=Stella Artois=- is offline   Reply With Quote
Old 4th June 2008, 06:25   #3 (permalink)
dinoc's Avatar
KW means lower ride , he doesn't want that
I think the best option will be to replace the shock absorbers with those famous Koni FSD.
Do a search for Koni FSD, I know this are available for Civic, also.
Koni FSD Damper Set
dinoc is offline   Reply With Quote
Old 4th June 2008, 06:52   #4 (permalink)
I wonder if there are any third party kits out there that would improve the suppleness of the ride and get rid of the slow speed harshness that some of us suffer ?
Old 4th June 2008, 08:27   #5 (permalink)
gjackson's Avatar
Will Type S bits fit?
It has the same ride height but stiffer dampers and thicker anti roll bars I believe.
gjackson is offline   Reply With Quote
Old 4th June 2008, 08:54   #6 (permalink)
3rd Honda's Avatar
That would interest me. My guess and its only that would be that it needs better dampers and probably slightly softer springs. However - I have a funny feeling that the permissible suspension travel (which is pretty restricted) will greatly limit the scope for a better ride. Short suspension travel has always been a Honda 'feature' and ride has never really been a Honda 'strength'. Nevertheless, both my previous Hondas have been a bit more supple than this Civic, and more comfortable and less 'jiggly' whilst remaining reassuringly 'firm'.
Old 4th June 2008, 08:57   #7 (permalink)
pcr
pcr's Avatar
This is my number one wish for the Civic, making the suspension cope with rough surfaces a lot better than it does. Those Koni FSD's appear to be a solution, but does anyone have experience of them ?. I note the front Koni shocks are inserts only, requiring modification of the existing front strut.
In another thread, someone commented on the 2008 model having a better ride, I would love to think that things have been improved.
Old 4th June 2008, 09:22   #8 (permalink)
I wonder if that is an area they have identified as a "solution to a problem" that they advertise ?
Old 4th June 2008, 13:46   #9 (permalink)
Koni FSD Damper Set
You can set the ride height, if you want it the same height set it the same as stock. Just because it can, you don't have to.
Old 4th June 2008, 21:59   #10 (permalink)
Thanks guys.
Previous 2 cars have spoilt me a bit. Rover 75, simply the most comfortable car I have ever driven, well besides the Bentley Arnage I once had a go in. And a Discovery with Air Suspension.
The ride on the Civ is just as its been described, Jiggly & Harsh.
The idea of a supple suspension on it sounds like heaven.
Have looked at the Koni's and I don't like the idea of the alterations to the front struts etc. Will take a look at the KW solution.
Thanks guys.
Old 4th June 2008, 22:03   #11 (permalink)
Quick look at the KW's tells you that they are height adjustable from between a 20mm drop to 50mm. So they will lower the car
Chris
Old 7th June 2008, 17:40   #12 (permalink)
GKAR's Avatar
Has anyone had any personal or from a familiar, experience from Weitec suspension.
Weitec is in the KW-group which uses KONI shocks, would you think that this might be a good reason to assume that Weitec is worth the trouble and euros?
GKAR is offline   Reply With Quote
Old 17th June 2008, 14:29   #13 (permalink)
CTR42's Avatar
have use kws and set at stand road hight for a while on the road before slaming it down 45mm for the track use only
CTR42 is offline   Reply With Quote
Similar Threads for: Upgrade suspension without lowering?
lowering springs civic_jaso Type-R 11 14th February 2008 09:37
Suspension Honda suspension kit Vs Aftermarket suspension kits?? Ronny Wheels, Tyres, Suspension and Brakes 10 19th January 2008 15:17
Suspension lowering suspension nomy Wheels, Tyres, Suspension and Brakes 18 12th October 2007 04:34
Suspension New CTR Lowering Kit dandydon Wheels, Tyres, Suspension and Brakes 14 27th March 2007 14:15
Suspension Lowering Springs available yet!?! DanKo Wheels, Tyres, Suspension and Brakes 3 18th February 2007 18:02
