This thread is about: Bump Stops??, it's in Wheels, Tyres, Suspension and Brakes at the Honda Civic forum Civinfo; Hey all - My civic is currently in for its 37500 service and the dealer just rang to say that it is in need of ...
LinkBack (1) Thread Tools
Old 20th June 2008, 11:49   1 links from elsewhere to this Post. Click to view. #1 (permalink)
tucker101uk's Avatar
Bump Stops??
Hey all -
My civic is currently in for its 37500 service and the dealer just rang to say that it is in need of some warranty work on the front bump stops...
This means nothing to me - not being mechanically savvy! I know that there has been some threads on squeeking and clunks from the suspension, but I cant find anywhere what the hell a bumpstop is!?!?!
Anyone that can help?!
Thanks!
tucker101uk is offline   Reply With Quote
Old 20th June 2008, 11:57   #2 (permalink)
mattlittle's Avatar
There is loads on the fault ang bugs forum, but they are the whit or yellow plastic bits on the top of the suspension struts (certainly front, not sure about rear).
If they are loose, then when you go over a pothole or speed bump, you hear a 'clank' sound when the strut expands again.
Sorry, but I don't have any photos.
Link Bump Stops
mattlittle is offline   Reply With Quote
Old 20th June 2008, 11:57   #3 (permalink)
RFY
RFY's Avatar
Found the following definition on the web:
Bump Stop:
Rubber bumpers (often cone or wedge shaped) on the chassis that limit suspension travel. "Bottoming out" the suspension means hitting the bump stops.
RFY
RFY is offline   Reply With Quote
Old 20th June 2008, 12:18   #4 (permalink)
Smarty's Avatar
I had bump stops replacement when I first got my Civic as there was a knocking noise. When the noise returned within a day or so I was told then whole shock absorber (i think) was replaced. New one is yellow, old one was white, or other way round. anyway, no problems now. All was done under warranty. I heard it was something to do with them not being able to fully cope with the heavier front of a diesel.
Smarty is offline   Reply With Quote
Old 20th June 2008, 12:20   #5 (permalink)
I thought this problem is long forgotten, but obviously not...
Old 21st June 2008, 00:46   #6 (permalink)
Had mine replaced yesterday under warranty on a 07 civic, apparently they were found missing when the handbrake mod was carried out the previous week
electron is offline   Reply With Quote
Old 21st June 2008, 07:15   #7 (permalink)
Nifty with fish
sushi_chef's Avatar
Have a look here for diagrams & discussion
Loose bump stops - Civinfo Wiki
It's always worth using the search box or checking the wiki
sushi_chef is offline   Reply With Quote
Thanks to sushi_chef from:
Old 5th August 2008, 11:24   #8 (permalink)
gmp
gmp's Avatar
Asked dealer to check for noise from engine a few weeks ago,evidently it was HUK policy to change bumps stops when a noise was refered to coming from front!Well now I have the constant thudding from the suspension(front and back) that I did'nt have before my original enquiry - its driving me to distraction!!!. Is there a diy remedy - like removing the stops altogether?My advice is think seriously if you have a noise, you will probably end up with problems later on!Incidently the dealer was a bit negative when I asked whether the shocks should be changed.
gmp is offline   Reply With Quote
Old 14th August 2008, 18:50   #9 (permalink)
matg's Avatar
My car is going back next week after its service today as I informed them of the suspension noise and they told me the bump stops needing replacing.
matg is offline   Reply With Quote
Old 26th August 2008, 17:27   #10 (permalink)
Had my 1st service today and one of my front Bump Stops has apparently dropped and needs to be replaced when they get chance. Doesn't cause any handling problems they say
chailey is offline   Reply With Quote
Old 27th October 2008, 14:20   #11 (permalink)
Reversing lessons anyone?
Car: 2.2 i-CTDi Type S GT, Milano
Had mine looked at today..Yes both bump stops have dropped at the front..
They are now submitting a warrranty claim to Honda.
So I now have to wait to get the work authorised.
I would have thought that it was cut and dried..
Its clearly a fault; not wear and tear!!
Old 27th October 2008, 14:28   #12 (permalink)
Service Dept Stormtrooper
NH Dan's Avatar
It should be cut and dried but the dealer still needs the work authorised through HUK before they do anything. this way, not only can they claim through Honda rather than you paying but HUK also get to log it as another 'repeat offender' and work on a long term fix if needs be.
Old 27th October 2008, 14:44   #13 (permalink)
Thanks Dan....This is the first manufacturer I have dealt with that has done this. (Skoda, Renault, VW, Vauxhall) my last 4 cars..all booked the car in there and then
Thanks to robbo51 from:
Old 27th October 2008, 15:20   #14 (permalink)
DeanFYoung's Avatar
Sounds like the dealer is going on the side of caution - perhaps they have been caught out before - undertaking work thinking it would be covered by HUK, but it wasn't...
Old 27th October 2008, 18:00   #15 (permalink)
NH Dan's Avatar
I could say thats because they have ALOT more experience in this market. buts that negative so i wont lol
Old 27th October 2008, 18:04   #16 (permalink)
Back on topic please..
So...could they have failed because of crap components then?
I'm not the only one to have this happen to.
Old 27th October 2008, 18:32   #17 (permalink)
Car: 09 CRV and 07 Accord SportGT
It has happened to loads of people.
http://www.civinfo.com/forum/attachm...-bumpstops.pdf
Old 27th October 2008, 18:33   #18 (permalink)
Car: 07 1,8 Executive 5 door NHB
Old 27th October 2008, 18:35   #19 (permalink)
Old 27th October 2008, 18:39   #20 (permalink)
Thanks guys...my car isnt mentioned on the Service Bulletin:
VEHICLES AFFECTED
2006 Civic 2-Door Si
– ALL
2006 Civic 4-Door:
From VIN 1HGFA1...6L000001 thru
1HGFA1...6L137665
From VIN 2HGFA1...6H500001 thru
2HGFA1...6H528035
2007 Civic 2-Door EX A/T:
From VIN 2HGFG128.7H500001 thru
2HGFG128.7H500056
2007 Civic 2-Door Si:
From VIN 2HGFG215.7H100001 thru
2HGFG215.7H100199
Are these UK spec cars???
LinkBack to this Thread: http://www.civinfo.com/forum/wheels-tyres-suspension-brakes/15328-bump-stops.html
???? ????? ??????? ??????? 5? ???? - ????????? - ????? \ ???????? - ????? ??? This thread Refback 24th January 2009 13:09
Similar Threads for: Bump Stops??
Suspension Bump Stops civicj1 Wheels, Tyres, Suspension and Brakes 7 18th May 2008 09:28
Loose bump stops Altimocivic Wiki Article Discussion 0 30th March 2008 21:30
Suspension Bump Stops slowhand Wheels, Tyres, Suspension and Brakes 73 26th October 2007 07:53
Seats Annoying bump in my seat JuhaR Bugs, faults and irritations 3 4th May 2007 12:24
Windows Electric windows stops working after opening door pikkumies Bugs, faults and irritations 1 20th June 2006 17:40
