This thread is about: Rear Tyre wear, it's in Wheels, Tyres, Suspension and Brakes at the Honda Civic forum Civinfo; Just replaced front tyres after 30K miles from new (Michelin). Asked the tyre place to put rears on front and new on back, as you ...
Old 24th June 2008, 17:57   #1 (permalink)
Rear Tyre wear
Just replaced front tyres after 30K miles from new (Michelin). Asked the tyre place to put rears on front and new on back, as you do. Fitter pointed out that rears had a stepped wearing pattern on inside edge, bad enough to vibrate etc if they were put on the front. Anyone had similar issue or ideas?
mikeh is offline   Reply With Quote
Old 24th June 2008, 19:22   #2 (permalink)
theres this one, but I think it related to front tyres.
Uneven tyre wear
dave9_3 is offline   Reply With Quote
Thanks to dave9_3 from:
Old 24th June 2008, 21:18   #3 (permalink)
brawnr's Avatar
I had this on the rear types of my EP3 Civic. They'd not done as many miles as you had but were 4 years old. There was a crack in the tread running around the tyre.
The guy at Kwik-Fit said 'it happens'.
brawnr is offline   Reply With Quote
Old 25th June 2008, 10:47   #4 (permalink)
Glepor's Avatar
Hi Mike,
I have exactly this problem detailed here:
Droning/Roaring Noise & Refuelling
and here:
Springs Fitted Upside Down At Rear!!
For info, I still haven't had the 4-wheel alignment done as I don't have £65 spare to gamble with at the mo. I tried switching the rears to the front but this just made the noise & vibration problem worse. Please let me know how you get on with any investigations.
Glepor is offline   Reply With Quote
Old 25th June 2008, 10:59   #5 (permalink)
pcr
pcr's Avatar
This came up in another thread somewhere. My daughter's Leon had the very same problem and the best info' I could find was that it can be characteristic of Torsion-beam rear suspension, made worse by wide tyres. It is recognised to the extent that I believe tyres are available designed to minimise the effect.
Old 25th June 2008, 17:03   #6 (permalink)
Old River Man's Avatar
Yes I had uneven tyre wear on the rears. They were worn on the inside lots more than the outside.
Anyway I did change the rears at 75000 miles, along with the fronts and also had the 4 wheel alignment done and it now seems fine.
The roaring noise from the rear has gone and the new rubber has settled very well.
Old River Man is offline   Reply With Quote
Similar Threads for: Rear Tyre wear
Tyre Life Uneven tyre wear Muz Wheels, Tyres, Suspension and Brakes 23 27th June 2008 23:33
Suspension Inner tyre wear GHGH Wheels, Tyres, Suspension and Brakes 10 20th May 2008 08:25
Tyre Other Uneaven tyre wear aj1soad Wheels, Tyres, Suspension and Brakes 6 6th May 2008 18:43
Tyre Life Another tyre with a nail / Poor tyre wear, What should I do nelster Wheels, Tyres, Suspension and Brakes 3 6th March 2008 09:46
Tyre Life Uneven tyre wear Miggins Wheels, Tyres, Suspension and Brakes 57 14th April 2007 11:31
