This thread is about: Replacing Front and Rear Brake Pads (merged), it's in Wheels, Tyres, Suspension and Brakes at the Honda Civic forum Civinfo; The civic has just had it's first 12000 mile service and the report came back that my rear pads are 70% worn, fronts 60%. Was ...
Old 16th February 2008, 11:32   #41 (permalink)
ep1
ep1's Avatar
The civic has just had it's first 12000 mile service and the report came back that my rear pads are 70% worn, fronts 60%. Was hoping to replace the rear pads myself so photos would be a great help. Would also need to buy a wind back tool. Incidently I have already replaced the front tyres with Goodyear F1's after just 11500 miles. The car was an ex demo.
ep1 is offline   Reply With Quote
Old 24th March 2008, 09:54   #42 (permalink)
kevin_lufc's Avatar
I have changed front pads on other cars before now, so was just wondering if the Civic was any different? Just as easy?
Old 24th March 2008, 14:42   #43 (permalink)
Enthusiastic Supporter
Miggins's Avatar
Front Pads
No different - straight forward and relatively easy. Just as with all pads - brake dust and road muck makes removal a little difficult (careful location of a small pry bar / tyre lever required) but once clean they go back on nice and easy.
OEM sets come with plenty of lube / anti squeal paste.
Miggins is online now   Reply With Quote
Old 24th March 2008, 14:46   #44 (permalink)
Miggins's Avatar
Wind back tool
I have tried most of the 'cheap' wind back tools and failed to find one that fitted or worked adequately. Recommend you look at one with multiple 'feet' / 'plates' to ensure a good fit with the piston.
One I had was too small and ended up jammed inside the piston......grrrrrrrr.
will stick to my wooden dibber next time.
Old 24th March 2008, 15:54   #45 (permalink)
kevin_lufc's Avatar
Is a wind back tool real needed then? What is the purpose of the tool? I did my front pads this morning, I wanted to do the rear pads but didn't have a wind back tool. I have a G Clamp that I use to push back the piston on the front, just wondered could I use that?
Old 1st June 2008, 01:29   #46 (permalink)
kissifer1972's Avatar
Quote from Honda Shop Manual
16. Rotate the caliper piston clockwise into the cylinder, then align the cutout (C) in the piston with the tab (D) on the inner pad by turning the piston back. Lubricate the boot with rubber grease to avoid twisting the piston boot. If the piston boot is twisted, back it out so it is positioned properly. Make sure the piston boot is in position to prevent damaging it when installing the caliper.
NOTE:
  • Be careful when moving the piston back in the caliper, the brake fluid might overflow from the master cylinder's reservoir.
  • Return the piston fully so as to prevent damaging the sticky shim.
So yes you need a right handed (clockwise) wind back tool
Chris
kissifer1972 is offline   Reply With Quote
Old 9th August 2008, 21:09   #47 (permalink)
AscotciVic's Avatar
I changing my rear brakes.
The working method is the same like on the front.
Changing brakes - Civinfo Wiki
I used the wind back tool.
Just the piston from de rear must in de correct position
with the nippel on the back of the brake pad.
AscotciVic is offline   Reply With Quote
Similar Threads for: Replacing Front and Rear Brake Pads (merged)
Front end knock/tap when brake/accelerate/turn spacecadet Wiki Article Discussion 0 8th October 2007 14:56
front and rear brake pads? valmiki Holdcroft Honda 13 10th September 2007 15:56
front pads lazzy git Holdcroft Honda 2 7th August 2007 22:21
Front Discs and Pads and drivers side fog lamp for 2.2 EX sonicsteve Holdcroft Honda 1 10th July 2007 09:57
Brake Third rear Brake light Brodick Lights 8 13th May 2007 10:09
