| This thread is about: Uneven tyre wear, it's in Wheels, Tyres, Suspension and Brakes at the Honda Civic forum Civinfo; Originally Posted by sarahjo I do hope u r referring to my driving drivingstyle of course...!!... | ||
#37 (permalink) |
Enthusiastic Supporter
My understanding is that when tyres wear on the outside it is either a geometry issue or due to sliding the front in corners - oops! If the issue relates to the inside then there is either a geometry issue or something is loose - during heavy braking the wheels are pushed back and too much toe out results which causes excessive inner tyre wear (don't believe this is the issue).
I am far from smooth and I know my driving leaves a lot to be desired but I do know how to drive smooth when necessary and could definately make my tyres last further than what they have. But I am still surprised at how quickly they disappeared - tyre depot said 20K from PS2's - I'm lucky if I've had 10k with a rotation!!!!! One thing I believe is responsible for the heavy wear is the EBA system. I know how to brake hard without going through tyres, however, the EBA applies the brakes much harder than I wan't and regularly implements the ABS when I know its not required for a smooth but hard stop! The inner wear after admittedly a basic tracking check does also surprise me. Yes I know basic tracking checks are sometimes far from reliable but to cause as much wear as has happened - anythings possible! Last edited by Miggins; 22nd January 2007 at 22:56. |
#38 (permalink) | |
您看了
I drive smooth and when being followed by a mate I always have to remember to drive to thier ability, not my own. Reason being is when you truely drive smooth you are actually erm.... "making more progress" Smooth & gentle=fast. going fast & Braking hard=sloooooow. Back to the tyre issue, I really think that a geometry check is in order, I am honestly shocked that some are managing to wear out front tyres in under 10k, let alone under 7k. Either there is something severely wrong with the geometry on your cars or you really really need to go on an advanced drving course of some sort. Driving fast and ragged enough to destroy tyres in 6k on the public roads is pretty dangerous, thats why I think it just has to be a geometry based issue. this is NOT a design flaw with the car and not a huge world wide problem, its only a few experiencing this so maybe there are a few "friday" build cars in this thread?. ps. Ignore 350z tyres, or any other car for that matter. Nothing to do with a Civic and they have a completely different geometry setup (some cars have camber added for a sharper front end giving uneven tyre wear |
#39 (permalink) |
I've had a reply to my enquiry with Tony at WIM and the Civic is not on his list of cars that need urgent geometery attention because the factory settings cause premature tyre wear.
#40 (permalink) | |
您看了
so are you saying that Tony reckons the factory settings do cause excessive tyre wear or don't? Does his list only include cars that have excessive tyre wear from the factory? So by not appearing on his list the Civic set up is ok (something I have found personally) and premature tyre wear is down to the driver? Your wording is very confusing due to to the fact it's one long unbroken sentence with no grammar to speak of and no breaks in what you are saying so it could appear to some that the meaning is not what you mean it to be or that what you mean is actually lost by the missing full stops and or commas this is the reason I ask you to clarify the points you have already made as the wording is written in such a way as it is not clear what you mean |
