This thread is about: Brake pad Life, it's in Wheels, Tyres, Suspension and Brakes at the Honda Civic forum Civinfo; Just picked up my civic from 1st service and was really suprised when advised by the garage that it needed new front pads , to ...
Old 1st March 2007, 21:54   #1 (permalink)
Brake pad Life
Just picked up my civic from 1st service and was really suprised when advised by the garage that it needed new front pads , to start with i didn't believe them , but they were well and truly Knackered !
From memory the front pads lasted till about 35 k on my last car ( Volvo S60 D5 )
Has anyone else had the same Experience ?
Jimbo
jimbo is offline   Reply With Quote
Old 1st March 2007, 23:50   #2 (permalink)
elisgriffiths's Avatar
Me too i am afraid new pads at 12,500 they said they were over half worn and wouldn't make it to the next service...
elisgriffiths is offline   Reply With Quote
Old 1st March 2007, 23:54   #3 (permalink)
i-CDTI just makes you want to drive hard! My tyres are done after 7k, I'll be needing brake pads too then.
Old 2nd March 2007, 07:04   #4 (permalink)
If they were only just over ½ worn then I think I would have waited a while and had them done later.
Your possibly going to get the same situation in a years time.
ps: how much did they charge for pads & fitting ?
Kremmen is online now   Reply With Quote
Old 2nd March 2007, 07:14   #5 (permalink)
okehciv's Avatar
Oh dear mine is in for first service next week,wasn't expecting to have to get new pads already
okehciv is online now   Reply With Quote
Old 2nd March 2007, 08:40   #6 (permalink)
pcr
pcr's Avatar
Brake pad wear depends hugely on driving style. All things being equal you could expect similar wear to your previous car, but as CP says, I suspect the Civic has changed some people's driving style.
Old 2nd March 2007, 10:04   #7 (permalink)
Bournemouth Belle
lippy's Avatar
Then thank god I've got a petrol model!! Earliest I've ever done tyres on a car is 18k and I thought that bad. Will prob get eagle f1s when need changing.
Not happy that brake pads don't seem to be lasting that well either, first car I've had where, from what you lot are saying, that pads will prob need changing around the 25k service. Mind you with the number of miles I actually do in reality that will prob be after 3 years - MOT time!
lippy is offline   Reply With Quote
Old 2nd March 2007, 23:36   #8 (permalink)
I, m just glad that ive got a few mil. left on my tyres , my pads wernt just half worn , but about 95 % , quite scary really , if I actually drove my civic as hard as i would like to , without a care for fuel consumption . they may not have made it to the 1st service.
jimb0
Old 5th March 2007, 10:31   #9 (permalink)
mine were 30% worn front, 20% worn rear at my 12K service
Old 5th March 2007, 13:24   #10 (permalink)
Bardley's Avatar
Just got back from my first service, car has only done about 6700 brake pads are 30% worn on all 4. Wasn't sure if this was good or bad as this is my 3rd car in 3 years driving, so haven't had to change any pads yet.
Tyres are 4mm front and 6mm at the back
Bardley is offline   Reply With Quote
Old 5th March 2007, 14:37   #11 (permalink)
hmmmm
my fronts went at 11K
rears were still 6mm at 12K...
perhaps stop sliding to a halt at junctions Bardley?
Old 5th March 2007, 19:10   #12 (permalink)
jme1978's Avatar
Judging by the amount of dust that comes off them I use a set everyday but Honda sneak round during the night and change them.
This is the only explination I can think of.
J ;o)
jme1978 is offline   Reply With Quote
Old 5th March 2007, 21:41   #13 (permalink)
sik2k's Avatar
My last Type R (2003) had the same dust problem. It would get all down the side of the car and make a right mess. It was so bad I actaully took it back to the dealer to get them to look and they just said it was 'normal'. They didn't wear out particularly quickly though.
It was a good few thousand miles before I stopped noticing.
sik2k is offline   Reply With Quote
Old 6th March 2007, 06:38   #14 (permalink)
Bardley's Avatar
ahhh, that's what that screeching is ......I didn't think I ever brake very hard coming to junctions *Shruggs Shoulders*
Old 9th March 2007, 18:12   #15 (permalink)
Mr. Foglights
civicsport's Avatar
Just got mine back from 1st servce at 9286 Miles, Front pads 10% wear, Rear pads 0% Wear, Front tyres 7mm, Rears 6mm. They must have swapped them at the service!!! Also does anyone know how much oil the engine holds?? (1. they put in 3 Lts plus 1 Lt top-up on the invoice, but they also put a full 1 Lt top-up in the boot, It must hold more than 3 Lts surely???
Old 9th March 2007, 19:35   #16 (permalink)
Enthusiastic Supporter
Miggins's Avatar
someone is taking the.....brake pad material?
Be aware that if you are warned your pads are low they do disappear quickly
- I was warned at my service that they were low and one was close to 100%, which should mean close to the wear limit. What they didn't tell me was it was close to the metal. They also told me the wrong pad was close so I kept having a look at the decent one. I ended up with metal flake all over my wheel only 2 weeks after service.
Yes I carried on driving (my choice) but I had ordered pads and wasn't informed failure was immanent. It is the service departments duty to clearly state the position and risk - this is part of what they are paid to do in a service.
As it turned out both fronts were low - but ready to change. However the rears were a different story one was only half worn the other was down to the metal. I was told by the dealer this is acceptable. *** is an understatement - never have I heard or experienced such a thing.
Strangely it was the near side rear that wore the most.
Cost just under £70 (delivered) to do all 4.
I agree the Civic makes you drive 'differently' but the key difference is the emergency brake assist - I brake hard but sometimes it comes on when I dont want or need it - this will easily eat rubber and pads.
Old 10th April 2007, 09:53   #17 (permalink)
generationgav's Avatar
My fronts have gone "completely" at 21k, I was told by the AA and by where I got it done that it seems a very low mileage to require it, but maybe not now!
And was told to be very suprised that I wasn't warned of it at 1st service, maybe the dealer I used wasn't as good as I thought.
Old 18th July 2007, 10:55   #18 (permalink)
hia everyone please jump to reply as my car is at the stealers as I type.
Does anyone know if the civic Icdti should be eating front pads and tyres at the rate it does, I know people with BMW M3's that get more out of there rear tyres than I get out of my fronts.
Also isn't 12,500 miles ridiculously low milage for a 140bhp (admittedly high tq) car to be eating it's pads this fast. My mates 130bhp diesel Focus's and meganes and golf's all seem to be getting twice this milage out of the front pads and tyres.
I love my civic but the bloody thing is starting to eat me out of house and home.
Incidentally the rear pads have been replaced at 25,000 miles (also over half worn).
Not uniformed jibes about driving style please... I am an M4 warrior... 11,000 of the last 12,500 miles have been spent on the motorway doing 75ish... so I just don't get why the Civic hates it's fronts so much.
I have noticed chirping form the brakes even when i am going in a straight line... Hit the VSA button to off and for the most part the chirping goes. Even after short journey's there is a lot of heat in the front wheels. And my steering wheel is misaligned slightly so that if I steer the car straight it looks as if i am turning left ever so slightly, i.e. if held with the steering at the visual centre the car turns to the right i.e. away from the camber (enough for most motorway bends in-fact).
Understandably the dealer has kindly offered me the advice that it is my driving that is to blame, fair enough, but I don't drive 'crabwise' down the M4 so how does it all ware so fast?...
In other words
Please help...
Cheers
Elis
Old 18th July 2007, 11:05   #19 (permalink)
Jedi71's Avatar
Brake use
hi i have used 2 sets of fronts and one rear set in 22000 miles seems alot of use as my previous car 250 bhp and driven hard sti used less than this good think it is the vsa that makes u use more or so i have been told !!!!!!
Jedi71 is offline   Reply With Quote
Old 18th July 2007, 11:18   #20 (permalink)
Thanks Jedi71, I also just remembered that the chirping becomes far less when the wheel is at the optical centre. I remember reading a thread that said about there being a steering wheel angle sensor?
Is this a fallacy? or could the misalignment of the steering mean that my car VSA is always thinking that it is going round a bend and fighting to help me go round a bend even though I am just going straight ahead... though I admit that this is really clutching now. It would make sense in a way as even when going straight my satnav (EX civic not Tomtom) seems to think that i am going left i.e. on a straight ahead road the screen shows the road kinking left slightly, my work tomtom shows the road straight and true...
Would this also not help to explain the higher ware rate... Mum's got a 140bhp diesel A4 estate, heavier car and right foot. I get better MPG but she has been getting 24,000 out of her fronts and at 35,000 no sign of needing new pads... I am starting to thing that these new Civic pads are made of bloody recycled bog roll or something...
Similar Threads for: Brake pad Life
Life expectancy LoonyJohn General Discussion 19 14th June 2007 10:30
mid life crisis? TTDegs Any non Civic chat here please! 17 4th June 2007 14:00
Mid-life crisis...??? Maxbert Any non Civic chat here please! 29 27th October 2006 09:41
Life changes SUPERTEACH Any non Civic chat here please! 25 25th October 2006 08:39
What Car? Life saver Kpow99 General Discussion 7 18th May 2006 15:24
