Brakes Should the wheel rotate freely when car in neutral? - Civinfo
Old 24th February 2011, 23:16   #1 (permalink)
griffian's Avatar
Car: 2007 2.2 i-cdti ES NHB
Thanks given: 483
If I put my car on axle stands and put car in neutral and spin the front wheel, should it revolve a few times before coming to a stop as I have noticed the wheel is hard to turn. There is a rubbing noise. The wheel does not rotate freely.
I have just painted the calipers so I cleaned and copper greased the runners and filed the edges of the pads.
I can move the pads back and forth with little effort.
If my fronts are binding how do I make sure my front calipers are not siezed?
Any ideas?
griffian is offline   Reply With Quote
Old 24th February 2011, 23:42   #2 (permalink)
Cockup Specialist
Relic's Avatar
Thanks given: 791
Dont forget you are turning the driveshafts/diff/gearbox so there is a lot more resistance in the front than the rear.
You wont be able to spin it as such.
Resistance should be the same on both sides
Does the brake rub get louder and quieter or keep pretty much the same volume ?
Thanks to Relic from:
Old 25th February 2011, 12:52   #3 (permalink)
Wilfko's Avatar
Car: 2007 CTR, NHB
Thanks given: 8
I recently posted basically the same question, Mine doesnt 'spin freely' after spinning at all...
Wilfko is offline   Reply With Quote
Thanks to Wilfko from:
Old 25th February 2011, 20:16   #4 (permalink)
Car: 2007 CTR GT red
Thanks given: 16
As relic says you are turning the wheel, the brake disc which may rub a bit on the pads and the drive shaft which is connected directly to the gearbox. So yes you will certainly feel resistance and its unlikely you will be able to spin it. So nothing to worry about.
Andrew P is offline   Reply With Quote
Thanks to Andrew P from:
Similar Threads for: Should the wheel rotate freely when car in neutral?
Tyre Life How to rotate Michelin Pilot Sport 2's? fz158 Wheels, Tyres, Suspension and Brakes 3 4th April 2010 17:54
Engine Revs while in neutral Samuk General Discussion 12 20th September 2009 01:03
Bodywork Boot not opening freely TYPE_S_GT Bugs, faults and irritations 4 5th February 2009 16:27
Other rpm's when cold and in neutral anti-rsca Engines and Transmission 15 2nd December 2008 22:47
Tyre Life replace or rotate? (split posts) TTDegs Wheels, Tyres, Suspension and Brakes 24 23rd March 2007 12:20
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116
