This thread is about: Front wheels turning by themselves, it's in Wheels, Tyres, Suspension and Brakes at the Honda Civic forum Civinfo; I've been running into a strange problem for the last couple of months (I think it started when I switched to summer tyres). Sometimes when ...
Old 11th May 2007, 12:58   #1 (permalink)
Skaven252's Avatar
Question Front wheels turning by themselves
I've been running into a strange problem for the last couple of months (I think it started when I switched to summer tyres). Sometimes when I slow down to a stop in the traffic lights, the steering wheel suddenly turns left or right by itself, and has to be resisted by hand if I intend to keep going straight forward.
Someone told me it may be because the wheels' brake force may be assymmetric, and they fixed(?) that at the repair shop, but the problem persists.
It usually only happens on roads where deeper wheel grooves have worn into the asphalt. So, is this just "groove sensitivity" (I don't know the correct term in English), the wheel's edge getting caught on an uneven slope? Is it normal, or should I worry? Anyone else having this?
Skaven252 is offline   Reply With Quote
Old 11th May 2007, 13:08   #2 (permalink)
mes
hi,
have you made sure that the brakes are all ok. because the front brake calipers seem to be not working properly.
mes is offline   Reply With Quote
Old 11th May 2007, 13:16   #3 (permalink)
Skaven252's Avatar
Thanks for your reply. I don't know how to check it myself, and they claimed they had "fixed the brake pads" - but if the problem is in the calipers, I guess they just didn't look at them at all?
So, the steering wheel should never turn by itself while braking, even when the car is on a deeply grooved road?
Old 11th May 2007, 13:21   #4 (permalink)
Amnesia's Avatar
I have had the same issue since I had the car last March.
The dealership couldn't find a problem and suggested it might be that the front tyre pressures were uneven (even though they were both as per spec). The problem is most pronounced on rough tarmac finishes, and isn't just limited to braking. I can feel the steering 'choose' its own direction when the car is coasting on some occasions....
Amnesia is offline   Reply With Quote
Old 11th May 2007, 13:33   #5 (permalink)
Mr Lovedog's Avatar
This is not an unusual problem at all.
Low profile tyres and larger wheels will always produce this when you drive in ruts in the road.
Mr Lovedog is offline   Reply With Quote
Old 11th May 2007, 13:56   #6 (permalink)
elfa7's Avatar
We have some atrocious roads around this area, but I've never had an issue with the steering. Even on motorways, where you get the occasional rut on lane one, no problems whatsoever. Drives straight as an arrow, and the brakes are superb.
Old 11th May 2007, 14:14   #7 (permalink)
this sort of thing is fairly common - "tramlining" is what it's know as over here.
It only tends to happen at low speed - when the momentum of the car isn't helping it to just ride over the edges of the ruts.
Old 11th May 2007, 14:36   #8 (permalink)
pcr
pcr's Avatar
Yes, mine does this. The worst aspect of it that I notice is when say a large truck is coming in the opposite direction and the gap is narrow, if I lift off the accelerator then the steering goes loose and vague. Not very pleasant really.
Old 11th May 2007, 14:38   #9 (permalink)
Skaven252's Avatar
This is not an unusual problem at all. Low profile tyres and larger wheels will always produce this when you drive in ruts in the road.
So no worries then? Indeed, I noticed this only when I switched from winter to summer tyres (I got my car in winter). The winter tyres have a higher profile.
Old 11th May 2007, 16:56   #10 (permalink)
Sounds like you have nothing to worry about, TT explained how 'tramlining' works, I get it daily, its the roads and not your car
Old 11th May 2007, 17:11   #11 (permalink)
Happens to me all the time, at first I thought the my tracking was out, but it is just tramlining. The large wheels definitely help to reduce roll when cornering at high speed though.
sfboy is offline   Reply With Quote
Old 11th May 2007, 17:23   #12 (permalink)
And give more grip...
Old 11th May 2007, 22:55   #13 (permalink)
GHGH's Avatar
And slower acceleration....
Old 14th May 2007, 19:24   #14 (permalink)
repales's Avatar
Hi. No need to worrie, its just normal when you have wide tyres like 225/45-17. mine does it. you just have to live with it. And keep enjoyng your car....
repales is offline   Reply With Quote
Old 14th May 2007, 19:56   #15 (permalink)
sprkeh's Avatar
Happens to me alot too, but it is just ruts in the road, just dont let go of the wheel!!!
sprkeh is offline   Reply With Quote
Similar Threads for: Front wheels turning by themselves
Front wheel drive, but rear wheels get dirty THX1138 Cleaning 32 2nd October 2007 08:28
No turning back now... LoonyJohn Buying, Dealers and Servicing 4 29th May 2007 07:12
Turning off front Airbag east5ive General Discussion 13 30th April 2007 12:28
Turning Circle? blzb0b Type-R 10 21st April 2007 01:36
Computer Turning the engine off generationgav Electronics 11 5th October 2006 17:32
