#21 (permalink) | |
Clingfilmed
![]() Car: 2008 2.2 CTS GT
Thanks given: 853
#23 (permalink) |
Never tap!
![]() Car: 2007 Type S 2.2GT Milano Red
Just been to local garage they think it could be the driving rack, or something to do with the springs. Never felt a car with handling like mine before as the turning changes so much.
Guess is will be a job for Honda |
#25 (permalink) |
Cockup Specialist
Thanks given: 740
Lean on the corners where the bonnet meets the wing over the struts.
See if you have any give at all. See if both sides collapse and rebound the same. Not hitech but will rule out obvious stuff like seized/bent damper |
#26 (permalink) |
Never tap!
Dammit, steering rack and motor need to be replaced.
Honda want £1,600+ for the work Does anyone know where i could get this work done other than Honda in the west midlands? Cheers James |
#27 (permalink) |
Never tap!
Looks like i am not going to be able to get round having to pay out a small fortune to resolve the steering issues.
Parts from Honda are £1,300 alone |
#29 (permalink) |
Never tap!
Cheers for checking mate.
also had this one in mind - BREAKING FOR SPARES HONDA CIVIC 2008 i-CTDi 2.2 S-TYPE POWER STEERING RACK ONLY | eBay |
#31 (permalink) |
Never tap!
Wouldn't give allot of information to be honest, just kept with the whole unit needed replacing.
I have been quoted £240 for fitting which is estimated to take 7 hours. Sound about right guys? |
#32 (permalink) | |
![]() Car: CTR GT
Thanks given: 702
As for the reported issue, lowering a car causes negative camber, in an ideal scenario camber bolts would be fitted to correct any excess negative camber. Excessive negative camber can cause the steering to feel weird, you've lowered your car by a whole 25mm so I would get the camber measured at least and maybe corrected. Last edited by ash_rage; 10th July 2012 at 00:33. |
#33 (permalink) |
Never tap!
I will try and get more info on the problem, as for camber bolts they made no difference when fitted. The steering still makes a loud clunk noise half through turning.
To be honest I am at the point now that I will probably get this replaced and sell the car |
#34 (permalink) | |
![]() Car: CTR GT
Thanks given: 702
Whoever fitted the springs did they fit the top mounts lined up correctly? The reason I say this is that I had the same symptom and it was fixed when ABP realligned the top mount to its correct position. |
#35 (permalink) |
Never tap!
I assume so mate, i had the car back after the springs had been fitted and everything was fine for about 3-4 months then i started to notice the problems.
Saying that i would be really happy if i could get the car back to how i remember |
#36 (permalink) | |
Cockup Specialist
Thanks given: 740
Topmounts is not unusual....rack is very unusual. |
#37 (permalink) |
Never tap!
Not managed to get anymore info out of Honda
I have taken the plunge and managed to get a rack and motor taken from a 2009 low milage Civic, no reserves on either and got both for £90 including delivery with a 30 day warranty. I also found out about a Rack and steering specialist very local to me after i had purchased the above who quoted £140 to repair my current one. Who ever i get to do the work i will get them to check the top mounts, thanks for all the replies guys. |
#39 (permalink) |
Never tap!
Looked at a new Scirocco today 1.4 TSI and 170 TDI god, they are so boring inside to a civic!!!!!
Similar Threads for: Light steering since having eibach's installed
| Steering Light Steering | vtecpower | Bugs, faults and irritations | 9 | 1st May 2013 17:05 |
| Wheel Tech Steering's gone light...?? | tommlangley | Wheels, Tyres, Suspension and Brakes | 10 | 27th April 2013 18:24 |
| Steering Steering Warning Light | visionkeys | Bugs, faults and irritations | 61 | 18th June 2012 17:12 |
| Bulbs led side light's installed | manwe | Lights | 6 | 20th August 2009 21:34 |
| Steering goes light....... | jamesaberdeen73 | Type-R | 2 | 16th March 2008 21:39 |
