Old 2nd September 2011, 11:49   #1 (permalink)
Never tap!
roundy's Avatar
Car: 2007 Type S 2.2GT Milano Red
Light steering since having eibach's installed
Hi guys,
Has anyone who changed to the eibach springs 15mm drop for a 2.2 noticed the steering feeling any lighter around town use?
I have only had the springs changed not had fast road setup, spacers or anything else done etc
When i first collected the car it felt firmer and better around bends i was just after some feedback really as this is something i am noticing more and more.
Tyre pressure is fine before you
Cheers
James
roundy is offline   Reply With Quote
Old 2nd September 2011, 11:59   #2 (permalink)
I drive my Mistress...
Sctrpop's Avatar
Car: 2008 2.2 3 door Type S RBP
Thanks given: 30
I thought that the 15mm were for the Type R and that we had to do the 25mm in our 2.2 due to weight...
Sctrpop is offline   Reply With Quote
Old 2nd September 2011, 12:06   #3 (permalink)
[ Laird Mac Nac Feegle ]
J. Derek Riddell's Avatar
Thanks given: 297
These are indeed a 25mm drop on everything except the Type R ...
Old 2nd September 2011, 15:15   #4 (permalink)
Pheasant Plucker
Fr0d's Avatar
Car: 2006 2.2 EX, NHB
Thanks given: 56
Get your geometry checked, as it is bound to be altered slightly if the struts have been removed.
Fr0d is offline   Reply With Quote
Old 21st October 2011, 13:21   #5 (permalink)
Never tap!
roundy's Avatar
had 4 new tyres and laser alignment done, still a problem
Think camber bolts will fix it?
Old 21st October 2011, 13:55   #6 (permalink)
Thanks given: 297
Originally Posted by roundy View Post
Had 4 new tyres and laser alignment done, still a problem Think camber bolts will fix it?
Eibach lowering springs and full FRS will result in the steering being that bit lighter and more precise - mine was "point and shoot" afterwards ...
Old 21st October 2011, 22:09   #7 (permalink)
Never tap!
roundy's Avatar
I agree, but still have the issue when turning left it is totally different from when turning the wheel to the right.
Shouldnt be the way it is and it wasnt for the first few weeks.
Old 21st October 2011, 22:28   #8 (permalink)
Thanks given: 297
I agree, but still have the issue when turning left it is totally different from when turning the wheel to the right. Shouldnt be the way it is and it wasnt for the first few weeks.
Full FRS ...
Old 22nd October 2011, 09:40   #9 (permalink)
Woette's Avatar
Car: '07 1.8 MR Type-S 61000 km
Thanks given: 90
Eco display Eco display
Did you fit the right springs?
I read on here that the kit for the 1.8 and 2.2 are different due to the extra weight of the diesel engine?
Old 22nd October 2011, 19:59   #10 (permalink)
WARRIOR
tinkz's Avatar
Car: Mitsubisi Outlander Warrior
Thanks given: 121
you say you had "laser alignment done", can i ask which type of laser alignment?
Was it the one where they clamp the lasers to the front wheels and a scale to the rears ! cost approx £25-30
Click the image to open in full size.Click the image to open in full size.
Or
Was it the Hunter 4 wheel alignment system there reflectors are attatched to all 4 wheels and the lasers are flaashing on something that wouldnt look out of place in Star Wars, cost approx £40-80
The Hunter system is by far the superior and most accurate, get the camber bolts fitted at the same time as alignment/FRS, this should cure it unless there is a problem with the springs/fittment of them
You can do an internet search for hunter Alignment machines in your area
tinkz is offline   Reply With Quote
Old 24th October 2011, 09:51   #11 (permalink)
Never tap!
roundy's Avatar
I would say more like the first one, with the readout being displayed on a computer for the guys to adjust. He did say he couldn’t adjust the camber side of things and recommended me to another company. Both front wheels were out to the left.
To be honest, I tried the car out on the way to work (70 miles) and it did feel better than before but still want the car checking due to the miles I cover on a month.
Old 24th October 2011, 09:53   #12 (permalink)
Never tap!
roundy's Avatar
This is what i had - http://www.iamotorsport.co.uk/gfx/walignment2.jpg
Old 24th October 2011, 10:30   #13 (permalink)
Thanks given: 297
I would say more like the first one, with the readout being displayed on a computer for the guys to adjust. He did say he couldn’t adjust the camber side of things and recommended me to another company. Both front wheels were out to the left. To be honest, I tried the car out on the way to work (70 miles) and it did feel better than before but still want the car checking due to the miles I cover on a month.
Well - we keeps a tellin ya - but ja don't listen so good ! ...
Full (4-wheel) FRS, done by a specialist - that'l sort out the tracking and camber, front and rear, once and for all ...
Old 7th June 2012, 16:32   #14 (permalink)
Never tap!
roundy's Avatar
I know i left this topic for while but finally made time to get the car on hunters alignment system and the guy said he wasn't happy at all with the way the car feels when he turns the wheel to the right (seems very stiff) and then effortless to the right. Said the tracking is spot on already and suggested i visit Honda to see whats going on or go back to my old springs.
Just wondered if anyone had the springs changed and did not have the FRS alignment + camber bolts done and they experienced the same problems as myself.
ps do you have the camber bolts fitted front and rear?
Old 7th June 2012, 16:39   #15 (permalink)
Never tap!
roundy's Avatar
effortless turning to the 'left' sorry, and is getting even worse at high speeds
Old 7th June 2012, 16:51   #16 (permalink)
Civinfo Wind Up Merchant
Scotty182's Avatar
Car: 56' 2.2, 5 door, 195bhp
Thanks given: 24
This is very similar to the hunter set-up mentioned, just another type
very good, and very precise bit of kit (this is what we use)
As for the issue, does the EPS made any noises at all when you steer from lock to lock ? could be a rack issue
Scotty182 is offline   Reply With Quote
Old 7th June 2012, 17:02   #17 (permalink)
Syx
Clingfilmed
Syx's Avatar
Car: 2008 2.2 CTS GT
Thanks given: 827
I have the springs fitted to my 2.2 with no FRS as yet. There has been no change to the steering.
Old 7th June 2012, 17:22   #18 (permalink)
aka Paul
Revs FN2's Avatar
Thanks given: 683
Mine felt different after installing springs. It may have accentuated the effect of an already incorrect camber angle.
Since FRS it's better, but it depends on how you have the guys set the car up. If you have some negative camber the tyre doesn't quite sit flat on the road and therefore takes away some of the self-centering effect. But if one side is cambered differently to the other it can do all sorts of odd things with the steering feel. Differing tyre pressures can have the same/similar effect so make sure they're correct.
Camber bolts at the front, shims at the rear (between the hub and arm).
Syx, you've been here a while now, you should know better! I demand you get FRS NOW! Seriously though, nothing.. NOTHING has improved the feel of the car more that FRS. The difference is stunning (mainly the feel of the rear end on the limit)
Revs FN2 is offline   Reply With Quote
Old 8th June 2012, 09:21   #19 (permalink)
Never tap!
roundy's Avatar
Can you guys give me any examples of camber bolt costs and fitting please?
Old 8th June 2012, 09:33   #20 (permalink)
aka Paul
Revs FN2's Avatar
Thanks given: 683
The kit is reasonably cheap, but they need installing as part of the FRS. Call ABP or TDi North for a price
Similar Threads for: Light steering since having eibach's installed
Steering Light Steering vtecpower Bugs, faults and irritations 9 1st May 2013 17:05
Wheel Tech Steering's gone light...?? tommlangley Wheels, Tyres, Suspension and Brakes 10 27th April 2013 18:24
Steering Steering Warning Light visionkeys Bugs, faults and irritations 61 18th June 2012 17:12
Bulbs led side light's installed manwe Lights 6 20th August 2009 21:34
Steering goes light....... jamesaberdeen73 Type-R 2 16th March 2008 21:39
