This thread is about: Rear Brake Disks, it's in Wheels, Tyres, Suspension and Brakes at the Honda Civic forum Civinfo; Had my car in for its 1st service last week and was told that they were getting me new rear brake discs under warranty because ...
Old 24th June 2007, 18:19   #1 (permalink)
ricky_west's Avatar
Rear Brake Discs
Had my car in for its 1st service last week and was told that they were getting me new rear brake discs under warranty because they were scored. Has **** else had their rear discs replaced because of this? Any ideas what could have caused it? Here are a couple of pics, one from each rear disc.
ricky_west is offline   Reply With Quote
Old 24th June 2007, 18:21   #2 (permalink)
SimonB's Avatar
Ouch... thats not good!
I'm assuming they're replacing the brake pads at the same time!
SimonB is offline   Reply With Quote
Old 24th June 2007, 18:25   #3 (permalink)
ricky_west's Avatar
Well i hope so, will be double checking that when i take it in to get it done.
Old 24th June 2007, 18:27   #4 (permalink)
PTR
PTR's Avatar
sometimes I have similar (but not that strange) lines on my front disc...
I say sometimes because after harder brakings they disappear and gets back to normal...
the reason for your problem could be something with the pads.. there is something in the pad compund...
I would try some harder brakings from higher speeds (but with care! don't fell off the road and watch mirror if anybody is coming behind you!)
so after some brakings with nice hot discs (don't touch them) make a visible check... it might won't be a solution but you can try
Old 24th June 2007, 18:33   #5 (permalink)
I have the same problem went back to the dealer at 975 miles on the clock and showed him the scoring and also surface cracks
I told them to make a note and they can change them at the first service.
we will see!
jasmac is offline   Reply With Quote
Old 24th June 2007, 19:07   #6 (permalink)
Mines are getting done ,waiting on a phone call hopefully new alloys aswell
bigal is offline   Reply With Quote
Old 29th June 2007, 14:32   #7 (permalink)
yep had the same problem with my rear disks at 10 months old. My dealer skimmed the rear disks. I knew the problem and they confirmed that the rear pads had limited movement due to a build up of brake dust on the pad carrier.
problem sorted
maza is offline   Reply With Quote
Old 30th June 2007, 08:00   #8 (permalink)
Jedi71's Avatar
brakes
im having to have a second set of front pads after 18000 miles seems wrong to me as in my subaru fronts would last at least 20k and i used the stop pedal alot more on that lol - rears swere changed at 16 k whic again seems to frequent - any ideas
Jedi71 is offline   Reply With Quote
Old 6th July 2007, 20:39   #9 (permalink)
ricky_west's Avatar
New rear brake disks and pads were fitted today, hopefully no scores appear on these ones
Similar Threads for: Rear Brake Disks
Brakes Replacing Front and Rear Brake Pads (merged) Miggins Wheels, Tyres, Suspension and Brakes 45 1st June 2008 01:29
Brakes Brake wear Kpow99 Wheels, Tyres, Suspension and Brakes 76 8th May 2008 17:26
front and rear brake pads? valmiki Holdcroft Honda 13 10th September 2007 15:56
Brake Third rear Brake light Brodick Lights 8 13th May 2007 10:09
Built in CD MP3 Disks and Vista Maldax Ipods, MP3 Players and ICE 4 6th April 2007 14:11
