Suspension knocking from rear when cold - Civinfo
Old 27th November 2011, 11:39   #1 (permalink)
Car: 2007 type S , royal blue
Thanks given: 63
hi all , just bought a type s, 06 plate,1.8, 23000 miles on it,with 2 year warranty, from arnold clark, im well chuffed with it, only problem with it is when i pull out my drive when cars cold i get a knocking noise coming from the rear of the car , sounds like suspension shifting about ? it knocks 4 or 5 times then its fine till its cold again, any ideas ? problem is if i drive it down to arnold clark to show them it wont make the noise cause its fine for the rest of the day. anyone heard of this problem before , cheers for any help
celtsof67 is offline   Reply With Quote
Old 27th November 2011, 11:50   #2 (permalink)
leigh's Avatar
Car: 2009 CW CTR
Thanks given: 687
That's your rear shocks, mine did this and took it back Honda and they fitted new rear shocks as it was a recall
leigh is offline   Reply With Quote
Thanks to leigh from:
Old 27th November 2011, 12:49   #3 (permalink)
The Dugs Baws
dobe's Avatar
Car: CW-0575
Thanks given: 583
Is this deffo a recall?
My nearside rear has started doing this over the last couple of weeks.
I done a search and the info was a bit conflicting with some dealers saying it is and some not.
dobe is offline   Reply With Quote
Old 27th November 2011, 13:05   #4 (permalink)
leigh's Avatar
Car: 2009 CW CTR
Thanks given: 687
Mine started about a week after owning the car, so read up on it and spoke to the garage I brought car from and they didn't know what problem was so I rang Honda uk and explained to them and they were aware of the problem and it was a recall of sort basically it wasn't an official recall where every car on a certain year was recalled has Honda said it wasn't dangerous etc just an annoying noise bit like the type r clutch squarking when cold, but if the customer complains about it then they will fix the problem. So I went back to my garage told them and in the end had the rear shocks replaced and they also said they made a modification on the exhaust brackets. Not had the problem since and didn't cost me anything.
Old 27th November 2011, 13:10   #5 (permalink)
The Dugs Baws
dobe's Avatar
Car: CW-0575
Thanks given: 583
Cheers bud.
I'll be phoning HUK tomorrow before i contact my local dealer as they are not the greatest at helping you out if they don't have to.
Old 27th November 2011, 13:44   #6 (permalink)
leigh's Avatar
Car: 2009 CW CTR
Thanks given: 687
Cheers bud.
No problem mate, hope you manage to get yours sorted free of charge has one thing I've found with Honda dealers and Honda uk it all depends on who you speak to.
Old 27th November 2011, 14:17   #7 (permalink)
Thanks given: 63
cheers for help, dont think honda will help seeing its nearly 5 years old, but will try arnold clark with with my warranty ....should be fun
Old 27th November 2011, 14:25   #8 (permalink)
CCC
CCC's Avatar
yes this is a common problem, my car squeaks and knocks when really cold outside.
CCC is offline   Reply With Quote
Old 27th November 2011, 15:31   #9 (permalink)
Dunc_82's Avatar
Car: 2010 BMW 320d M Sport
Thanks given: 19
The attached service bulletin may help. I tried to find the original thread I got it from, but no luck.
I had this done a month or so ago and not had a creak since.
Dunc_82 is offline   Reply With Quote
Thanks to Dunc_82 from:
Old 27th November 2011, 19:59   #10 (permalink)
Thanks given: 63
n
nice 1 cheers, do you need the yellow tube or do you think a quick rub with grease in the general aread would work ?
Old 27th November 2011, 20:58   #11 (permalink)
Dunc_82's Avatar
Thanks given: 19
No problem.
The yellow jig is for getting the grease up in between the damper and dust cover. I presume that if you apply the grease lower down it won't help.
Fortunately my warranty hasn't expired yet so just had the dealer I purchased the car from do the work.
In your case I would at least ask at your local dealer; it really shouldn't be more than a 30 minute job for them. It would save you the hassle without costing the Earth.
Old 28th November 2011, 09:08   #12 (permalink)
Thanks given: 63
No problem.
cheers
Similar Threads for: knocking from rear when cold
knocking/clicking noise in rear of car jjmu15 General Discussion 1 30th August 2010 13:43
Suspension Knocking from rear of car? Naresh Wheels, Tyres, Suspension and Brakes 12 7th July 2010 21:22
Suspension Knocking STILL coming from rear! Wazza350 Bugs, faults and irritations 30 30th March 2010 01:44
Suspension knocking from rear suspension tinkz Wheels, Tyres, Suspension and Brakes 5 17th February 2009 22:52
Squeaks Knocking at rear......possible solution fickel Bugs, faults and irritations 0 6th June 2008 20:24
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116
