![]() Car: 2013 1Series MSport Plus
Thanks given: 208
Wheel won't come off! Novice question.
So I currently have a flat tyre after driving over a screw earlier, which is feel and truly embedded. Went to put my space saver on and...
I don't ever remove my wheels on my civic, always used to take my old cars wheels off, mainly due to my civic being just over a year old, but i undid the wheel nuts and no matter what i do it won't budge ![]() What am I missing or doing wrong? |
Aye Aye....
![]() Car: 2009 CTR, Milano
Thanks given: 482
Have you just stopped driving? If you have the heat will have effectively welded the wheel t the hub, tbh I tend to just hit the wheel edge with the base of my hand and it'll eventually come off...... Ya big blouse!!
Thanks to DPG87 from:
![]() Car: 58 2.2, Black ; 09 CTR, Red
Thanks given: 3
Had this before on a Mondeo. In the end used a rubber mallet to belt the wheel off - took some hammering but they will eventually come free. Just make sure you have the car securely raised first!
Sent from my BlackBerry 9900 using Tapatalk |
Thanks to stevencavanagh from:
![]() Car: 2011 Type S
Thanks given: 31
This might sound really silly but better to start with the obvious but you have undone and removed all the wheel nuts?
If so and the car is secure on an axel stand or equivalent then try using a mallet and a piece of wood to protect the wheel and give the wheel a good smack with the mallet all the way around and then as much as you can on the rear of the wheel. It sounds like it's slightly seized on which isn't uncommon if they haven't been off in a while but it should still come off easy enough with some gentle persuasion. |
![]() Car: 2007 CTR GT, Milano Red
Thanks given: 8
Make sure the car is well supported when jacked up and sit facing the wheel and kick it at nine and three on a clock position if you get my drift. One side at a time and this should loosen it.
Thanks to brian mc21 from:
Thanks given: 208
Thanks people, but I don't have my trolley jack at home with me so I'm I'm using the little metal thing that came with the car, tried hitting it a few times, my last attempt was to shake the ****er off, but the whole car was rocking that much the jack nearly tipped over.
Will try with a mallet in the morning Sent from my iPad using Tapatalk HD |
#8 (permalink) | |
![]() Car: 09 Crystal Black CTR GT
Thanks given: 42
Mine are tight every time. Has the wheels off 2days apart a couple of weeks ago and was tight. |
Thanks to ScottM from:
Clingfilmed
![]() Car: 2008 2.2 CTS GT
Thanks given: 927
Get some copper grease on the hub before you put the wheel back on to make it easier next time around
Thanks to Syx from:
![]() Car: 2006 2.2 EX, NHB
Thanks given: 89
Just wondering what you'd do in an emergency situation when you get a flat tyre, and can't get wheel / bolts off !!
Sometimes the bolts are really tight. |
![]() Car: 09 Suzuki Swift Sport white
Thanks given: 1,186
Drop it back onto the deck with the nuts loose
Sent from my GT-N7000 using Tapatalk 2 |
Thanks to coste1l from:
#12 (permalink) |
![]() Join Date: 24th September 2011
Nuts slightly loose (!), drop on deck. Right then left with the steering wheel and then try again. Opposite for left handed folk
Thanks to Fosbucket from:
![]() Join Date: 15th September 2011
Thanks given: 3
I had this recently when trying to change a wheel on my sisters car. It would not budge no matter how much kicking or shaking. Called out the AA in the end as I wasn't 100% sure something else wasn't holding it on and was afraid I may damage something. They turned up and whacked it with a leather mallet and it popped off immediately.
The AA guy also suggested as mentioned above lowering from the jack (with loosened nuts) to try and pop the wheel. |
Thanks to Amac from:
#14 (permalink) | |
![]() Car: 08 2.2 nhb type s gt
Thanks given: 135
Thanks to firstcivic from:
Similar Threads for: Wheel won't come off! Novice question.
| Brakes Novice on brakes | Curbs | Wheels, Tyres, Suspension and Brakes | 23 | 1st June 2010 12:38 |
| Performance HELP !!! Complete Novice | lewis2008 | Engines and Transmission | 1 | 15th December 2009 20:45 |
| Tuning could someone help a complete novice lol | mark_VII_jenkins | Engines and Transmission | 11 | 4th June 2009 12:27 |
| AUX in Quick Novice Question (Dension) | tonyt | Ipods, MP3 Players and ICE | 7 | 7th September 2007 15:32 |
| hello from a novice | ptaz | Introduce yourself | 4 | 31st January 2007 18:26 |
