![]() Car: NHB 07 Civic SE.
Thanks given: 151
Terrible noise from front wheel.
Ive just had my car back from having wheel the bearings sorted,also the ABS sensor got snapped whilst job was being done.
Its now making a noise as if the breaks are seriously worn down,its only occasionally. Is it something to do with the new bearings or has the garage messed the job up? Thanks peeps. |
![]() Car: 2009 milino red CTR GT+
Thanks given: 119
take it straight back sounds like they have done something wrong, bearings when replaced correctly and enough grease applied no sound will be heard.
Thanks to tonymac from:
![]() Car: 2008 2.2 Type S GT Red
Thanks given: 21
It maybe the brake pads have reached the squealer part that tells you the pads need replaced, but I would have thought the garage would have noticed that
Thanks to Xrv750 from:
regrets his username
![]() Car: Championship White
Thanks given: 542
ABS sensors are a pain to get off so usually the only way is to snap them off, as for your noise if it's when you brake and happens occasionally i would say it's maybe rusty disc or not you pads wearing but your actual discs. I had my pads replaced and a few weeks later had the grinding noise when braking booked it in elsewhere for an opinion turned out new pads on old discs was told to wait till they need doing, like you i get the occasional noise. If it was your bearing im sure it would be a constant noise.
Thank You to dweezle from 2 Users:
Thanks given: 151
It wasnt doing the noise before the garage,but is doing it after garage.
The discs are only about 2 years old. |
Thanks given: 542
Is it only when you brake and if so would you say it's a grinding noise (like a worn pad on a disc noise)
![]() Car: 2007 2.2 i-cdti ES NHB
Thanks given: 443
When my abs sensors where shot, I was getting terrible feed back from the brakes whilst putting foot on brake.
Did they replace the abs sensor? |
Similar Threads for: Terrible noise from front wheel.
| Squeaks Annoying intermittent noise coming from front wheel :( | gers | Bugs, faults and irritations | 35 | 13th July 2011 22:34 |
| Squeaks Metalic scraping noise from front wheel | gef | Bugs, faults and irritations | 9 | 11th May 2011 19:35 |
| Wheel Tech Noise coming from front N/S wheel? | Naresh | Wheels, Tyres, Suspension and Brakes | 16 | 13th April 2009 20:35 |
| Other soft whining noise from right front wheel? | alphaone | Wheels, Tyres, Suspension and Brakes | 4 | 11th March 2009 15:16 |
| Suspension This car drives terrible like! | pekwah1 | Wheels, Tyres, Suspension and Brakes | 43 | 20th November 2008 14:26 |
