![]() Join Date: 8th June 2012
Thanks given: 3
traction control kicking in too easy!
I am wondering has anyone else had this problem and if so did they manage to correct it. The VSA is kicking in fairly easy when cornering right. especially if i am taking a roundabout then let off the accelerator. seems to be when weight is put on left hand side of the car. Had it in to honda last week for full health check and came out all clear so thinking its something deeper than tyres etc. also my brakes seem to be overheating, could this be related?
![]() Car: 2007 FN2 GT
Thanks given: 160
Binding Calipers?
Take the brakes apart and clean them up, clean the sliders and use High temp grease in the grooves, also file the shoulders of the pads to allow them to move more freely |
Thanks given: 3
had honda carry out this work. problem dissapeared for a while in dry conditions but remained in wet. now its back again whether wet or dry
Thanks given: 160
Are all your tyres the same?? diameters?? and pressures match per axle as well.
We have had a couple of dodgy yaw sensors on here but I am unfamiliar with diagnosing them |
![]() Join Date: 10th August 2006
It's still possible your calipers might be binding.
After a drive, try to touch each alloy - they should all be just mildly warm. If one is much hotter than others - there's your problem. |
Thanks given: 3
Thats good to know thanks. sometimes the front two are so hot you wouldnt be able to keep your hand on them. Have honda done a bad job freeing the calipers or do they just need replaced now.
Thanks given: 3
to be fair it is only exceptionally hot after a 'spirited' drive. weirdly i had one of these drives on the way to work today and no problem with the vsa. Stuck to the road.
#12 (permalink) |
[ Laird Mac Nac Feegle ]
Thanks given: 297
'Binding' Calipers can happen to any car - don't buy new - horrendous price ! - get an exchange refurb deal from some place like "Bigg Red" - they'll even paint them for you as well - better than new afterwards ...
Thanks given: 3
thats great thanks. was on their site there but im not sure what parts i need. is it just the calipers or do i need pistons etc?
#14 (permalink) | |
Thanks given: 297
I found this out the hard way !!! |
#15 (permalink) |
![]() Car: 2006 Type-S GT
Thanks given: 47
I have the same problem. Honda had the car 3 days but failed to diagnose it (although they agreed they had had it happen to them). They did say they thought it might be the yaw sensor but would expect an error code which they didn't get.
Thanks for the tip about alloy heat, will be sure to check that tonight. Someone else on here reported having a similar problem and they actually found it to be the negative battery terminal was loose - may be worth checking. |
#16 (permalink) | |
Thanks given: 3
#18 (permalink) | |
Thanks given: 47
#20 (permalink) |
Thanks given: 3
that sounds similar to my problem but mine is more frequent. iv even went around roundabouts the wrong way (dis used road of course) to test left cornering but its fine.
Similar Threads for: traction control kicking in too easy!
| AC/Heater Climate control problem - Compressor not kicking in. | CivPilot | Bugs, faults and irritations | 18 | 14th August 2012 21:37 |
| Other Traction Control? | Alsone | Wheels, Tyres, Suspension and Brakes | 17 | 20th August 2010 15:50 |
| Traction Control on Typer | boring.com | Type-R | 17 | 29th August 2008 21:49 |
| VSA Traction Control | daveuk321 | Electronics | 15 | 15th February 2008 17:39 |
| VSA Does VSA include Traction Control ? | pcr | Electronics | 19 | 28th November 2006 22:59 |
