![]() Car: 2007 2.2 i-CTDi
Thanks given: 4
Hello guys!
2 months ago I fit a new set of EBC brake pads (green stuff) and discs (drill and groove) on my Honda. I noticed rubbing noise coming from the front brakes. I have done over 1000 miles before I drove back to my country. Everything was fine till I start using brakes more often on motorways (speed about 90-100 mph). Steering wheel start to shake and I did notice that new set is much worst then genuine Honda brakes. Brakes were very weak. I took car to a mechanic, who has checked and measured the discs. It turned out that one of the discs is over the norm so thats why my steering wheel shaking. I expected a lot more from these brakes for this price. Did anyone else had similar problem? Can that be a EBC manufacture fault? Why brakes were so weak? Thanks, Lucas. Last edited by lucas; 22nd August 2012 at 01:17. |
![]() Car: 2008 cts 1.8 red
Thanks given: 1
if your mechanic is correct and confident of measurments then contrct EBC and see what they say.
Did not realise that they did drilled and grooved discs, thought they only did solid,kgrooved and dimpled with grooves. |
#3 (permalink) | |
![]() Join Date: 15th February 2011
Thanks given: 30
Thanks given: 4
I have problem with mine since day one. Brakes are much worst then genuine. I will contact ebc tomorrow to see what they will tell me.
![]() Car: Silver Civic EX 1.8
Thanks given: 3
Got the same setup as you EBC slotted + Greenstuff & not had any problem at all so perhaps you have a duff disc, normally EBC are OK & I have never had any problem with them in the past.
If the garage who tested them can confirm they are out then they should help. |
Thanks given: 4
I fit discs and pads myself. It's not a first time when I have done this kind of job myself. Never had any problems before. So what's th best solution now? Call EBC or go straight to a garage?
Runout been checked by one of garages back in my country. |
#8 (permalink) | |
![]() Car: '07 1.8 MR Type-S 63000 km
Thanks given: 90
I had the EXACT same problem on my greenstuff and turbo grooved discs. Braking at high speeds gave massive judders in the steering wheel and a booming noise from the disc. Yet i was able to cover more then just 1000 miles, i believe it was arond the 8000 miles. After my direct purschase i already had great issues in contacting EBC for certificates so i just swapped with my OEM set and never looked back. They did however brake better then OEM when in the right temperature operating window. Perhaps a fault in installation? As a lot of other people some very pleased with them?? Its probably worth trying to contact them and see what comes up, i never tried as my discs are deemed illegal in belgium (hence my request for certificates). I really hope you get it sorted soon because driving like that is dangerous and annoying. |
#9 (permalink) | |
Cockup Specialist
Thanks given: 762
Similar Threads for: EBC brakes problem
| Brakes Help with front brakes and brakes in general? | kap01 | Wheels, Tyres, Suspension and Brakes | 6 | 1st June 2012 13:17 |
| Brakes Problem with dealer over brakes | rkidoasis | Wheels, Tyres, Suspension and Brakes | 8 | 21st January 2011 08:20 |
| Other Brakes and wheel bearing problem | ian.civic | Wheels, Tyres, Suspension and Brakes | 0 | 1st March 2010 02:11 |
| Other Brakes , Clutch , Wheels - Problem ? | mickstery | Wheels, Tyres, Suspension and Brakes | 1 | 30th September 2009 20:46 |
| 07 CTR rear brakes problem | SanderS | Type-R | 5 | 10th July 2009 20:03 |
