| Help Rules Search Clothing Stickers Surveys Wiki Forum |
| View Poll Results: Which would you choose and why? | |||
| Mugen suspension - Shocks and Springs |
7 | 21.21% |
| Bilstien/HKS/Tein - Coilovers |
26 | 78.79% |
| Voters: 33. You may not vote on this poll | Withdraw Vote | |||
LinkBack | Thread Tools |
#21 (permalink) | |
![]() Car: FN2 NHB Type R
Thanks given: 30
#22 (permalink) | |
These settings should not change on bumpy roads unless your talking about real extreme impacts. Coilovers feature on rally cars (same basic architecture and operation just a lot more expensive) and they do get a hammering! Personally I would say the coilovers. I have had springs, springs and struts, coilovers and also air ride in the past and if you want all round performance with the ability of dialing in the ride they are perfect. If you are not one to adjust or tinker then the KW V1 would be perfect. |
#24 (permalink) | |
Thanks given: 30
Go on... Sent from my iPhone. |
#25 (permalink) |
aka Colin
![]() Car: 2008 CTR GT, Black
Thanks given: 626
i think the mugen is over rated for what it is, again with their stuff, your paying for the name. ive not heard any reviews on the hks so cant comment on those, but the other 2 strike me as a budget product. im running buddyclub p1 race spec coilovers which dont cost the earth but are unbelievable handling wise. ive also driven cars with kw v3 fitted and again, fantastic pieces of kit pal.
#29 (permalink) |
![]() Car: 2007 FN2 GT
Thanks given: 159
^^^^^ Colins car is probably a smidge higher than mine but the handling is night and day better.
Firmer, flatter and far better damped than OE shocks and the way it goes from one direction to another is vastly superior to Eibachs. |
#30 (permalink) |
![]() Car: 09 Suzuki Swift Sport white
Thanks given: 1,113
V1s my mate has v3s on his and has them set to what mine are for road use then tweaks it slightly for track use
Sent from my GT-N7000 using Tapatalk 2 |
#31 (permalink) | |
![]() Join Date: 2nd March 2011
Thanks given: 574
As has been said about rally cars, they take a beating and doing 20 foot jumps and then crashing down into the ground. I guess from all of your questions that you have never driven a car with coilovers?? May i suggest you go to abp, tdi north or tdi south etc and get a test drive or passenger ride. If you want to improve the performance of your cars handling then coilovers are the only way imo. I don't think the fn2 needs lowering on the front....10mm max, you need to level the rear with the front 20mm maybe a smidgen more. Also, just because a modification is track oriented doesn't mean you can't use it on a daily car. Martelius isn't a daily use exhaust but people use it. Sent from my Galaxy Nexus |
#32 (permalink) |
Commercial user
![]() Join Date: 19th July 2008
Coilovers allow a lot more control so adjustments can be made to the driver preference.
Ride quality are important... that is something suspension designer have to look at. The idea that coilovers are for "track cars" is because many owners get "racing" coilovers. Then find out that they are so stiff it is impossible to get traction on uneven road surfaces that we drive on everyday. This is a common issue because most racing coilovers are expensive, and people often associate price with quality. However, picking the right tool for the right job is important. The most expensive coilovers in the world will probably ride rubbish if it wasn't design, specified, and adjusted correctly. Coilovers have to be compliant to provide traction, comfort is a by product of the compliancy. Coilovers with linear rate springs and adjustable mono-tube dampers will give smoother weight transition, better steering response, and control over ride height and ride quality. But then like I said... it depends on how they are design. Very stiff suspension will not do traction or comfort any favours, especially on our British country roads that are far from smooth. |
#34 (permalink) | |
Thanks given: 30
#35 (permalink) | |
Thanks given: 574
Most coilovers are comfortable, the issue is when bought on a car the mistake people make is to turn damping up flat out. This imo is wrong, its extremely uncomfortable and causes the car to skip when taking bumpy twisties at speed. I know it doesn't sound technical but thats how it happens when you buy second hand. Sent from my Galaxy Nexus |
#36 (permalink) | |
Commercial user
Most of the time the most comfortable setting is around 25% of the damping force... that is where I normally end up. The issue is that comfort and performance in a way comes hand in hand. A good set of suspension will reduce body roll and make the weight transfer much more controlled due to the stiffer linear rate springs. The damper adjustments control the "ride comfort" so to speak. What you want is a compliant ride that keep the wheels on the ground on uneven roads, but at the same time do not break your spine over every little bumps. Many coilovers on the market (mainly JDM coilovers) are design for racetrack... and they are valved too stiff for uneven road surfaces. That is why you have many owners complain that coilovers is too hard for road use. |
#37 (permalink) | |
![]() Join Date: 11th October 2010
Thanks given: 199
#38 (permalink) |
![]() Car: 2009 CW CTR
Thanks given: 412
I've just had the buddyclub P1 RSD coilovers fitted after going out in Pigdogs car and have to agree for the price there amazing best mod i've done!! since fitting i've been on different road surfaces and its so smooth, no bangs, crashy rides completely gone and rides potholes with no effort but put the car in a bend and you get no roll and so much grip.
Thanks to leigh from:
Similar Threads for: Suspension choices
| suspension choices | alphaone | Type-R | 59 | 20th January 2013 00:44 |
| Gaiter choices | Walton11 | Styling | 19 | 21st February 2012 20:02 |
| Tyre Life tyre choices? | twaiter | Wheels, Tyres, Suspension and Brakes | 21 | 25th October 2011 22:19 |
| Choices, choices | leepickering16 | General Discussion | 9 | 5th April 2011 23:40 |
| Company car choices..... | rmh999 | Any non Civic chat here please! | 11 | 9th July 2008 14:12 |
