Old 21st October 2012, 20:06   #1 (permalink)
Car: 2006 2.2
Thanks given: 5
Brake bleeding
Hi
I've bled brakes before and will be using my trusty Easibleed. From searching it appears doing the brakes in the order O/S F, N/S F, N/S R, O/S R is best.
However my question is can you bleed the brakes just by jacking up without taking the wheels off? It looks like the nipples are flush with the calipers?
Cheers
Jonny
JonnyS is offline   Reply With Quote
Old 21st October 2012, 21:41   #2 (permalink)
Warwick1984's Avatar
Car: 2007 Type-R GT Milano Red
Thanks given: 41
I think it can be done but I've not tried it that way myself
Warwick1984 is offline   Reply With Quote
Old 21st October 2012, 22:12   #3 (permalink)
davros77's Avatar
Car: 2006 1.4iDsi, 5 door, NHB.
Thanks given: 3
I would imagine it can be done, but you might need to lift car quite high to be able to get to them, for the front ones it might be easier to turn steering to full lock each way to get to them......... I have thought of using my eezibleed in the future to replace brake fluid on our Civic, but not sure whether there is a cap that fits on the reservoir to give a good seal, as it isn't a standard type of thread.... Do they make a cap that fits ?
davros77 is offline   Reply With Quote
Thanks to davros77 from:
Old 21st October 2012, 22:42   #4 (permalink)
newkid's Avatar
Thanks given: 124
I wouldn't bother tbh if you get brake fluid on your alloys could do some damage ! Don't be lazy get the wheels off :thumbup:
newkid is online now   Reply With Quote
Old 22nd October 2012, 03:59   #5 (permalink)
ScottM's Avatar
Car: 09 Crystal Black CTR GT
Thanks given: 42
It can be done. It's a little tight but its much quicker than taking all the wheels off. I jacked 1 front corner part way and this was enough for me to get at all the nipples(which had all been freed off the day before when wheels were off) and mine is lowered 30mm.
I didn't spill a drop but if I did just wipe with a rag then spray with brake cleaner and maybe plenty of water if you feel the need.
ScottM is offline   Reply With Quote
Thanks to ScottM from:
Old 22nd October 2012, 06:47   #6 (permalink)
Car: 2006 2.2
Thanks given: 5
Ah great cheers. I'll check on the Easibleed cap. Whilst brake fluid is nasty stuff, it does take a while to act. Good job as I once managed to spray it all over the front end of a car
Old 22nd October 2012, 19:50   #7 (permalink)
griffian's Avatar
Car: 2007 2.2 i-cdti ES NHB
Thanks given: 455
I bought an eezi bleed from halfords but it didn't fit the reservoir cap - so took it back.
I would like to know if there is such a sysytem that fits the civic????
griffian is offline   Reply With Quote
Old 22nd October 2012, 19:59   #8 (permalink)
Type EX,A guy called Mark
markvirgo's Avatar
Car: 2006 1.8, Alabaster Silver
Thanks given: 98
I don't think there is, Some people just use an old cap that they have modded.
markvirgo is offline   Reply With Quote
Old 22nd October 2012, 20:33   #9 (permalink)
Syx
Clingfilmed
Syx's Avatar
Car: 2008 2.2 CTS GT
Thanks given: 927
Tried that and it lasted for one complete bleed - second time round it gave up and brake fluid everywhere
They do a "clamp" cap but not sure how good that is... think I'll go for a vacuum bleed setup in future.
Old 22nd October 2012, 21:32   #10 (permalink)
Car: 2006 2.2
Thanks given: 5
Ah that's a pain. Just done the oil and filter, and access isn't too bad to save getting the wheels off. Hmm will have to see what I can come up with.
Old 22nd October 2012, 22:00   #11 (permalink)
Syx
Clingfilmed
Syx's Avatar
Thanks given: 927
The problem is that the pressure forces the fluid out from under the edge of the cap... need to find a way to seal it as silicone sealant wasn't good enough
Similar Threads for: Brake bleeding
Type R is bleeding. Type-R6 Type-R 22 1st August 2012 10:01
Brakes Brake bleeding Syx Wheels, Tyres, Suspension and Brakes 15 27th March 2012 22:51
Brakes Do-Luck Kit & Brake Bleeding bronze Wheels, Tyres, Suspension and Brakes 3 6th June 2011 09:49
Brakes .... Speed Bleeding Relic Wheels, Tyres, Suspension and Brakes 5 4th January 2011 12:31
bleeding woolz ABP Motorsport 3 30th April 2010 09:16
