This thread is about: New tyre - ouch!, it's in Wheels, Tyres, Suspension and Brakes at the Honda Civic forum Civinfo; Got the car out of the garage this morning (yes I'm one of those people who still use a garage to keep the car in ...
Old 27th August 2006, 15:22   #1 (permalink)
Hartside's Avatar
New tyre - ouch!
Got the car out of the garage this morning (yes I'm one of those people who still use a garage to keep the car in ) and noticed the drivers side was going flat. Checked the tyre and found it has a screw sticking in it. It being Sunday I phoned a few tyre fitting companies and found a local one open. You guessed it, the tyre could not be repaired as the screw was nearly in the sidewall on the shoulder of the tyre. Cost me £140 fully fitted
I know I may have got one cheaper on the net, but stood in the tyre centre with a tyre off the rim, that wasn't an option. Also it being Bank Holiday weekend I wanted a proper tyre on as I didn't want to run about on the space saver. Hope I don't get too many more, as seeing a tyre with only 3700 miles on it go to the bin brought a tear to my eye.
Old 27th August 2006, 16:23   #2 (permalink)
elfa7's Avatar
I'll bet its repaired and used by someone.
Old 27th August 2006, 16:29   #3 (permalink)
Hartside's Avatar
Probably, wouldn't mind betting someone's got a set of alloys for which this fits the bill
woohoo.......I'm a Supporter now, at least something to cheer up my day
Old 27th August 2006, 18:21   #4 (permalink)
Martin's Avatar
Thats bad news, but at least you had a compressor to put the pressure to the correct level so you didn't damage the rim
Martin is offline   Reply With Quote
Old 27th August 2006, 18:35   #5 (permalink)
Hartside's Avatar
I used my Halfords compressor to blow it up. When I got the car, it took me about 30 minutes to get the Honda compressor/gunk into the little compartment, so it will only come out in dire need
Old 27th August 2006, 18:39   #6 (permalink)
Martin's Avatar
Hartside,
Wait until you try to gat it back in!!
The wiring takes forever!!!
Old 29th August 2006, 20:44   #7 (permalink)
Hartside - I sympathise!
I had to have a new tyre after 1500 miles. Ripped the side wall - big hole in it, not repairable and obviously the gunk/compressor would have been a waste of time. Got towed home by the AA (had only had the car 2 weeks). Then had to get the wheel off (well boyfriend did) and had to abandon my Civic for a couple of days whilst I found the cheapest price in the shortest time I could for the same type of tyre which was £150 (balanced but not fitted). (18" storms on it).
kelly is offline   Reply With Quote
Old 30th August 2006, 12:24   #8 (permalink)
Bungle's Avatar
That's exactly why I got scared of relying on the gunk, so I 'acquired' a spare wheel just in case.
It has been mentioned before, and is my biggest gripe with the gunk. If you get a small puncture and use your gunk to get home or to a tyre place, they will not repair the tyre. Once the gunk is used, it ruins the tyre. A repair only costs £10 0r £15.
A really feel for you, though. Was the wheel itself OK? I would hate to damage an 18" storm!
Old 30th August 2006, 14:04   #9 (permalink)
Ancient Nerd's Avatar
This is why I think Honda is going to make a fair number of enemies (me already) by not supplying a spare wheel. In the last eight years, I have had three punctures, two of which wouldn't have been fixed by HondaGunk. If this happens to me with this car, they are going to get so much bad publicity it will really hurt. It is very short term thinking on Honda's part to save a few pounds on the cost of the car.
Renault tried the same sort of thing by not paying the TMC licences on their dearer Satnav systems. It ended up with them supplying replacement CDs, at full retail cost to large numbers of owners over the three years it took them to see the error of their ways. Honda is being equally short sighted with the spare wheel issue.
Old 30th August 2006, 14:20   #10 (permalink)
Bungle's Avatar
This is for another duscussion, but in Hond'a defence, if you do your research before buying the car, they do clearly state there is no spare, and it is not purly a cost thing, if at all. The cost of the air compressor and the gunk can't be that much less than the £99 spare.
The main reasons for the lack of spare were to be able to boast about having the largest boot in the class, and the weight savings (marginally) halping fuel economy and performance.
Old 30th August 2006, 14:46   #11 (permalink)
elfa7's Avatar
It would be nice if Honda offered to swap the compressor and gunk for a spare wheel.
Old 30th August 2006, 15:13   #12 (permalink)
Bungle's Avatar
Agreed
Old 30th August 2006, 15:20   #13 (permalink)
allan40alt's Avatar
Yes; but every car comes with the compressor and gunk. Bet they would swap if you had the wheel and offered
Old 30th August 2006, 16:11   #14 (permalink)
Bassa's Avatar
Should be customer's choice.
Honda should offer either as a no cost option - the customer could then choose between one or the other.
Bassa is offline   Reply With Quote
Old 30th August 2006, 23:53   #15 (permalink)
As I have said elsewhere in this forum, I found out about it after I had collected the car. I eventually found it in small and pale grey text buried in the middle of the specs detail. It is also in the incredibly badly photocopied price list handed to me by the dealer. Very definitely a buried in the small print exercise. But no, I obviously didn't do my research carefully enough. Still doesn't make me very impressed by Honda, whose attitude so far leaves me totally cold .
If the cost of the air compressor and the gunk isn't that much less than the £99 spare, then I feel sure that they would be willing to swap. However, I'll bet that they won't.
I can also assure you that if I end up having a non-repairable puncture, I won't be thinking nice things about Honda and the bit of extra boot space that always sits empty.
Old 5th October 2006, 11:24   #16 (permalink)
Tydo's Avatar
Not wishing to be horrible but did you not look at the ones in the showroom before you ordered it, I would have thought it was apparent that the spare wheel wasn't in the car, it was to me.
I don't have a spare wheel, I'm tempted to get the space saver for long trips but the rest of the time I'd chance the tyre goo. My last car had a full size spare and thinking about it rationally it must have cost a decent amount to lug it around all the time not to mention that the tyre would probably never be used. You've got the breakdown assist and the goo what more do you really need?
Tydo is offline   Reply With Quote
Old 5th October 2006, 11:39   #17 (permalink)
generationgav's Avatar
Breakdown assist do not carry spare tyres with them.
The goo does not work 30% of the time.
Most companies will not repair a tyre once the goo is used.
Someobody here couldn't fix the tyre with the goo and ended up having to get a tyre ordered and was without a car for 3 days; I cannot afford to do this.
Old 5th October 2006, 12:20   #18 (permalink)
Knat's Avatar
I can beat you on the timw for tyre replacment. 3 weeks after getting my new car I noticed there was a bulge in the front right tyre so I went to get it checked out and they said I needed a new one.
I didnt think it would be a problem until they said its not covered under warranty as it was my fault somehow and that the tyres don't just break for no reason. After sending it off to get inspected it took 2 months to get a reply saying that I had done "something" to the car and screwed the tyre up. £110 and I was not a happy bunny
Knat is offline   Reply With Quote
Old 5th October 2006, 13:00   #19 (permalink)
Nick7's Avatar
Well, frankly.. driving on 'repaired' tyre aint for me.
Goo is good enough for me - just to get to first shop where tyre can be fixed/buy new one. Even 'fixed' one I would replace. I do not want to put my head in the bag for driving on repaired tyre (especially since I tend to drive fast).
Old 5th October 2006, 13:03   #20 (permalink)
allan40alt's Avatar
On my Mini Cooper S Works I had 'run flat' tyres. Can you get them for the Civic
Similar Threads for: New tyre - ouch!
Tyre Choice Tyre reviews PJS Wheels, Tyres, Suspension and Brakes 1 30th July 2007 02:06
Delivery time Ouch Nighthaunt Buying, Dealers and Servicing 9 14th June 2007 16:51
Tyre Other new tyre KEN BYE Wheels, Tyres, Suspension and Brakes 0 5th June 2007 17:10
Ouch! Big& Type-R 14 1st May 2007 23:55
Tyre Pressure TYRE PRESSURES Mr Lovedog Wheels, Tyres, Suspension and Brakes 3 24th August 2006 14:24
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34
