Windscreen creaking windscreen - Civinfo
post #1 of 18 (permalink) Old 21st December 2009, 12:02 Thread Starter
Send a message via MSN to yorkie926
creaking windscreen
Just noticed it with the cold weather but soon as i drive the car untill it heats up for about 5 minutes the fron windscreen creaks and sounds like its cracking,,it isnt but it sounds like it is does anyone else have this problem?>
yorkie926 is offline
post #2 of 18 (permalink) Old 21st December 2009, 12:09
Bez
Bez's Avatar
Car: 07 Type S 2.2
Yes!
Creaking windscreen & a "mouse-like" squeek coming from inside the dashboard too.
Think the whole car would need rebuilding to get rid of all my squeeks/rattles so I'm not planning on doing anything about it.
Bez is offline
post #3 of 18 (permalink) Old 21st December 2009, 12:59
Aye Aye....
DPG87's Avatar
Car: 2009 CTR, Milano
aye get it all the time...i actually find that it happens when its cold outside and i've had the A/C or fans on the windscreen for a wee bit....dunno whether its somethin to do with the contrast of cold on the outside and heat on the inside
DPG87 is offline
post #4 of 18 (permalink) Old 21st December 2009, 13:17
ninjanik's Avatar
I've found the majority of these creaks / cracks and even half the squeaks in mine are just the windscreen cowl. I've had the usual rev counter surround one which sounded like rice crispies but recently the others were terrible and was all set to pull the dash apart. Then i noticed that when it was raining really hard... they had all gone. Common denominator... water lubricating the windscreen cowl stopping it from rubbing on the screen. I can even replicate the cracking noise by pushing down on the cowl where the end pieces join the middle section. Gonna do the windscreen cowl fix once the weather improves.
ninjanik is offline
post #5 of 18 (permalink) Old 21st December 2009, 16:45
Bungle's Avatar
I had to get my windscreen removed and rebonded to fix it. It was really bad and creaking constantly. 3 years down theml line and it has just started to creak again, out of
warranty. It will be some other poor bugger's problem soon though. As with all the other creaks and rattles and buts falling off!
Bungle is offline
post #6 of 18 (permalink) Old 21st December 2009, 16:59
Silent Assassin
Windlepoons's Avatar
Car: Mazda 3 MPS MK2
funny you should mention that, last night I had a creak/squeek I couldnt locate, it sounded like the whole dashboard was coming away from the front of the car, it is the first time I have ever heard it, and put it down to the cold weather or something.
Then the exhaust started whistling lol.
Windlepoons is offline
post #7 of 18 (permalink) Old 21st December 2009, 19:06
As ninjanik mentions it could be the windscreen cowl. Give this a try.
http://www.civinfo.com/forum/how/118...wl-creaks.html
Dimplyred is offline
post #8 of 18 (permalink) Old 21st December 2009, 19:18
pcr
pcr's Avatar
Sounds like the cowl problem to me. If you have a glass roof, the sealing strip between roof and windscreen is also suspect. The effect of these two problems on my car can be so severe that is sounds like the whole dashboard is about to fall in your lap.
pcr is offline
post #9 of 18 (permalink) Old 24th December 2009, 08:55
CCC
CCC's Avatar
My windscreen also creaks when its extremely cold outside, or when its really hot in summer. Its been like this since new, so have just lived with it.
CCC is offline
post #10 of 18 (permalink) Old 24th December 2009, 09:00
john87's Avatar
Car: Golf GTI
My windscreen is creaking too in this cold weather, problem only seems to be there when its icy/frosty though
john87 is offline
post #11 of 18 (permalink) Old 29th January 2010, 22:07
Ah. This seems like a common problem then. Thought that I was going mad with the creaking noise
ieuuk is offline
post #12 of 18 (permalink) Old 16th February 2010, 15:48
the same on my fk2
was not noticeable when the car was at the dealer so he said there is nothing wrong and he wont do anything about it ...
bernhard
darock is offline
post #13 of 18 (permalink) Old 16th February 2010, 17:10
morten's Avatar
Car: 2011 Skoda Octavia 1.4 TSI
Remember that water easily freezes up inside the cowl. and I think this causes the cracking sounds - like you would think the whole windscreen was about to crack...
morten is offline
post #14 of 18 (permalink) Old 16th February 2010, 17:32
Sandozer's Avatar
WD40....
Did my cowl on the outside of the car 2 years back, Simples.
Sandozer is offline
post #15 of 18 (permalink) Old 17th February 2010, 20:06
Coldwarkid's Avatar
I have this too! Dealer said it was in my head and nothing wrong with it.
Coldwarkid is offline
post #16 of 18 (permalink) Old 17th February 2010, 22:05
Heavy Footed!
HenryTheHonda's Avatar
Car: 2012 Astra GTC SRi
Im having same problems... Getting it replaced and sorted tomorrow
http://www.civinfo.com/forum/bugs-fa...-headache.html
HenryTheHonda is offline
post #17 of 18 (permalink) Old 18th February 2010, 08:37
PugLord's Avatar
I'm glad its just not me! I first started hearing this after xmas when we had cold mornings.....now its all the time so I'll get it sorted. It was such a strange noise to hear at first......thought the screen was about to go.
PugLord is offline
post #18 of 18 (permalink) Old 18th February 2010, 11:57
andy l's Avatar
As Morten said, its due to water freezing inside the windscreen trims that run along the 'A' posts.
Mine sounded awful in the cold weather even though the cars kept in a garage.
After 5 mins of driving the noise had gone
andy l is offline
Suspension Creaking Rear! alloallo Bugs, faults and irritations (8G) 89 25th May 2019 11:57
Clutch Creaking Diesel to Type R !!!! Engines and Transmission (8G) 2 3rd August 2009 08:13
Steering Steering creaking MisterTee Bugs, faults and irritations (8G) 28 31st July 2009 10:53
Windscreen Creaking windscreen ?? Ferny Bugs, faults and irritations (8G) 17 29th April 2008 07:20
Creaking Civic chris rowden Introduce yourself 5 8th June 2007 07:23
