Lights Headlamp washer + cold weather = stuck - Civinfo
post #1 of 11 (permalink) Old 8th January 2010, 09:39 Thread Starter
eighteentee's Avatar
Car: 2006 1.8 EX i-Shift
Send a message via MSN to eighteentee Send a message via Skype™ to eighteentee
Well, just like a pair of nipples in the cold, my headlamp washer jets are 'stuck' out again! Is this a known fault?
eighteentee is offline
post #2 of 11 (permalink) Old 8th January 2010, 09:54
mrh339's Avatar
Its not a fault as such its just that there is not enough screenwash/antifreeze in the washer bottle mixture hence the water has frozen and expanded pushing out the nozzle.
mrh339 is offline
post #3 of 11 (permalink) Old 8th January 2010, 10:00
Car: MX-5, C6 Vette & MB S212
Yes, it happens.
FWH is offline
post #4 of 11 (permalink) Old 8th January 2010, 20:47
As soon as the temperature rises above zero, the "fault" will repair itself
civicfan is offline
post #5 of 11 (permalink) Old 8th January 2010, 20:53
The White Knight
Josh1987's Avatar
Send a message via MSN to Josh1987
mine still work at -12 lol
What wash you using im using Halfords Pink/ Honda Stock
Josh1987 is offline
post #6 of 11 (permalink) Old 9th January 2010, 09:38
abecelius's Avatar
Car: 2006 1.8 EX
my washers do not pop up... tank of washing liquid is filled to top.
Will spraying with silicone help to keep them not frozen again?
abecelius is offline
post #7 of 11 (permalink) Old 9th January 2010, 10:04
I don't think so - it would be better to park the car overnight in a place where the temperature is above zero, then empty the washing liquid tank the next morning (you only need to pull and hold the lever), then fill with non-freezing liquid and (that's important) pull again for a few seconds to get water out of the tubing
civicfan is offline
post #8 of 11 (permalink) Old 9th January 2010, 12:26
abecelius's Avatar
Car: 2006 1.8 EX
I started to use non-freezing liquid since the beggining of autumn, so there cant be any water in the tank...
post #9 of 11 (permalink) Old 10th January 2010, 20:43
This might mean that either
1) water got to the mechanical parts during washing(?) or
2) that the non-freezing liquid is not that non-freezing after all... Happened to me several times in Poland, you buy liquid rated at -20C and at -10C you got a frozen lump in the tank.
But if you can get the tube attached to the cap out of the tank and the tank is indeed full, it looks like option one and then silicone may help
civicfan is offline
post #10 of 11 (permalink) Old 11th January 2010, 06:17
abecelius's Avatar
Car: 2006 1.8 EX
everything is ok with the fluid, i can take the cap of and tube comes of with no problems. Will try to lubricate washers when snow stops
post #11 of 11 (permalink) Old 11th January 2010, 06:41
It can also be snow which has found it's may into the mechanism, melted and frozen again into ice.
FWH is offline
Performance Affects of cold weather katsock Engines and Transmission (8G) 9 25th February 2009 13:59
Faults 2.2 cdti rev at 1.5 in cold weather Paul542 Engines and Transmission (8G) 18 12th February 2009 09:31
VSA VSA warninig light in cold weather Smugger Electronics (8G) 4 8th January 2009 18:25
Tech Oil, cold weather selection oilman Engines and Transmission (8G) 25 16th November 2008 17:12
Head missing headlamp washer nozzles v001148 Lights (8G) 1 29th December 2006 10:27
