Brakes Rear Discs - Civinfo
post #1 of 3 (permalink) Old 10th January 2010, 10:14 Thread Starter
Car: 2009 CTS DBP
Rear Discs
I know there are alot of posts about brake issues, but wonder if mine is developing an issue, car has done 5k miles of steady town driving i try not to use the brakes much, try to read the road and let the car slow down on it own, anyway iv noticed that the rear o/s brake disc is starting to score quite alot, the other 3 discs have no issues at all, visually checked the pads and they look to have plenty of meat on them, still look new. Is this a fault or just normal ????
by the way no more or less brake dust than the other wheels.
cheers
sie
sie1uk is offline
post #2 of 3 (permalink) Old 10th January 2010, 10:54
Could be a stone in between the pad and disc but i had a problem where one of the rear calipers had seazed and therefore the opposite side brake was the only rear one working. This caused one side to wear the pads quicker than the other. At 5k though i wouldnt have thought you'd need new rear pads.
hoskurner is offline
post #3 of 3 (permalink) Old 14th January 2010, 08:02
CCC
CCC's Avatar
Mines going in next Saturday as I get a rubbing noise when the brakes are cold, but only in reverse. The dealer told me that the pads may be worn or sticking, also that cars with VSA and EPS eats through rear pads! I've now covered 25k miles on these original pads, they may be on their way out even though they told me that they were 60% worn in the last service 2.5k miles ago.
The stone issue is very common, I have more wear on my rear disks too.
CCC is offline
OEM rear discs... Neily03 Type-R 0 26th August 2009 18:33
Servicing Replacing rear discs and pads (285!!) iamholam Buying, Dealers and Servicing 48 10th September 2008 11:53
Brakes Rear discs illegalhunter Wheels, Tyres, Suspension and Brakes (8G) 3 1st June 2008 11:40
Brakes rear discs ?? daiashthomas Bugs, faults and irritations (8G) 9 30th April 2007 15:58
