Trim Boot trim - Civinfo
post #1 of 14 (permalink) Old 26th January 2010, 10:38 Thread Starter
John Driver's Avatar
Car: 2008 2.2 SE Milano Red
Boot trim
Car a year old now and the trim is coming away behind the passenger's head - rear offside. The offending panel embraces an air bag. Tried to push it back but it no longer aligns properly with the black trim below - the panel that contains the boot light. Have asked for warranty repair since I am not keen to fiddle further when there is an air bag involved.
Anyone else suffered this?
John Driver is offline
post #2 of 14 (permalink) Old 28th January 2010, 10:32
no, but the trim that is on the inside of the boot (bit that goes around the rear windscreen) has sagged at the bottom in the middle, so when you look out of the back window you can acutally see the following!
Hope you get it sorted. I'm not sure about the quality of the trim in the 07- civics!
dersam is offline
post #3 of 14 (permalink) Old 28th January 2010, 11:07 Thread Starter
Hmmm, that doesn't look good. Will let you know how I get on - first service in just over one week.
post #4 of 14 (permalink) Old 5th February 2010, 15:24 Thread Starter
OK, so the car has been in today. They refitted the trim but - guess what? - it had sprung out again by the time I got home (20 miles).
Now they are ordering new trim panels having stated that they've never come across this problem before. Watch this space......
post #5 of 14 (permalink) Old 5th February 2010, 15:34
Merk1981's Avatar
Car: FRV EX 2.2
My 56 plate 07MY does the exactly the same thing. It doesn't really bother me though.
Merk1981 is offline
post #6 of 14 (permalink) Old 3rd March 2010, 15:19 Thread Starter
Car went back today for two new trim panels under warranty. Speedwell Honda of Paignton are very good - no quibbles and job done efficiently. Asked tech. man if they'd had this trim come adrift on any other Civics and he said: yes, a few. He went on to say that the clips 'get weak'.
I hope that's fixed it for me. Time will tell.
post #7 of 14 (permalink) Old 13th April 2010, 12:16
mmw109's Avatar
Send a message via MSN to mmw109
I have exactly the same problem, in exactly the same place. My dealer is being a bit coy about whether this is a warranty job (I've had the car just under 10 years, noticed the issue a couple of months ago though).
Do you have a dog guard perchance ?
mmw109 is offline
post #8 of 14 (permalink) Old 13th April 2010, 12:38
was that 10 years or 10 months? Nope, we've not even had the parcel shelf out!
I've just had a call from Honda to book the car in to replace this (and the clutch box for the clicking clutch problem) and it's all done under guarentee - our car is 18 months old now (yes, been waiting 4 months to get the bits in!!!)
dersam is offline
post #9 of 14 (permalink) Old 13th April 2010, 15:03 Thread Starter
No, perfectly standard boot area. My dealer accepted it as a warranty job with no quibble. But then my car is only just over a year old - presume you must have an earlier Civic model given that it is 10 years old.
post #10 of 14 (permalink) Old 13th April 2010, 16:49
mmw109's Avatar
No, don't know what happened there - It's 3 years (not 10).
The dealer's just phoned me back now, and they sound like they've had a mess around and managed to make the trim stay in place, but he didn't seem too confident. It seems that the dog guard exerts downward pressure on the trim which pulls it away from the Body. Given that I had the parking sensors and camera fitted originally, then there is a good chance that the original dealer may have damaged the clips, or just that taking them on and off a couple of times, meant that 3 years later, they've given way.
He's not charged me this time, but I think his trick with that is that when I go back I'll be out of warranty
mmw109 is offline
post #11 of 14 (permalink) Old 13th April 2010, 16:54 Thread Starter
In my experience, Honda are pretty good about warranties even if you are a bit outside of 3 years. So it's always worth pressurising the dealer (politely!).
I also had parking sensors fitted when new so your point about broken clips might well be valid.
Good luck!
post #12 of 14 (permalink) Old 13th April 2010, 16:54
if you have reported it whilist under warantee and they could never quite resolve the problem, they will have to fix it when it's out of warantee as the fault developed whilst under warantee.
As John said, they seem to be ok as long as you are polite and point out the fault was raised whilst under warantee but never actually resolved. If it sags again, report it as soon as you can is my advice.
dersam is offline
post #13 of 14 (permalink) Old 2nd August 2010, 14:55
BLN
BLN's Avatar
Car: 2006 1.8 Sport
dersam, I have a problem like yours, it's the exactly samme place, but the trim are not sagged here, it's bended upright, so when you look throug the back window from outside, you can see the trim sticking up in the middle. It's '06 Civic, but just discovered the problem now, a few days after I have a shop giving it a Dinitrol wax treatment.
Do you ever find the reason for you problem?
I have a suspicion that either the wax (which I assume is hot when it is sprayed on), or it is the sun, that got the trim to go out of shape.
Does anyone knows, if there should be a clip holding the trim in place at the middle?
BLN is offline
post #14 of 14 (permalink) Old 3rd August 2010, 16:38
Exclamation sagging boot trim
ours sagged because of hot sun on the back of the car (in the UK!!). There are no clips in the middle to hold it up and our replacement has started to sag again.Terrible design flaw if you ask me as plastic like that will sag or expand and bend up as yours has. If you are still in warantee drop it in for replacement.
dersam is offline
Removing boot trim panels Geflong General Discussion (8G) 4 6th April 2009 23:42
Your Boot- wot does it look like? Boot Mats anyone? psykik General Discussion (8G) 8 22nd April 2008 13:00
Trim Boot interior trim hanging off robbo51 Bugs, faults and irritations (8G) 20 7th November 2007 10:38
Speedometer Trim & Rear seat belt trim matg General Discussion (8G) 1 27th October 2007 17:37
Trim Boot trim GHGH Bugs, faults and irritations (8G) 2 5th October 2007 08:03
