Suspension Civic noise going over bumps. - Civinfo
post #1 of 21 (permalink) Old 26th January 2010, 17:04 Thread Starter
"Grandad eye"
stevey_p7's Avatar
Car: 2007 1.8L CTS Silver
Question Civic noise going over bumps.
Hey guys,
Was wondering if someone could help me out. Only had 2007 Civic Type S for a few days now but getting this odd noise when go over bumps.
It sounds like it could be the drivers side suspension or chassy. I'm not sure whether it could just be nothing or whether there is something wrong.
So, the noise. It sounds a bit like a squeak but its a bit more than that. I can't explain it tbh. Only happens when going over speed bumps (even slowly) or on small uneven parts of roads.
Was wondering if anyone else had experienced such strange noises in the past when going over bumps. The sound doesn't seem too harmful and makes a noise in time with the back of the car going up a speed bump and back down again.
Hope i've explained enough. Thanks in advance to any replies.
stevey_p7 is offline
post #2 of 21 (permalink) Old 26th January 2010, 17:34
The quest for perfection!
0507448n's Avatar
you might have a problem with the suspension. U should get the dealer to check it out and get it fixed under warrenty.
My suspension is developing a strange creaking noise too hope getting into dealer asap.
0507448n is offline
post #3 of 21 (permalink) Old 26th January 2010, 17:39
NoNumpty's Avatar
Car: 2008 2.2 i-CTDi ES NHB
NoNumpty is offline
post #4 of 21 (permalink) Old 26th January 2010, 17:44
cb550's Avatar
Car: 2009 EXGT auto, Audi TT 190
More than likely the well documented front struts bump stops issue-apparantly the bump stops or the complete strut is changed under warranty.You're dealer should investigate under the warranty.My drivers' side squeaks over speed bumps or occasinally when the car's taking a hard left hand bend.At the moment planning to have the dealer look at it when the car's due its service.
cb550 is offline
post #5 of 21 (permalink) Old 26th January 2010, 18:05 Thread Starter
"Grandad eye"
stevey_p7's Avatar
Thanks, I bought the car from a garage not the Honda Dealer so would they sort it or is it not their problem. They gave me 3 months warranty like.
Think its out of warranty end of feb. (56 plate but only made in 2007)
post #6 of 21 (permalink) Old 26th January 2010, 19:46
J. Derek Riddell's Avatar
Warranty is 3 years from the first date of registration - Honda should cover this problem for free - so, get it to a Dealer a.s.a.p.
J. Derek Riddell is offline
Thanks to J. Derek Riddell from:
post #7 of 21 (permalink) Old 26th January 2010, 19:50 Thread Starter
"Grandad eye"
stevey_p7's Avatar
Cheers, thanks for that. Would I need to bring anything with me as haven't got the logbook to state that I own the car yet.
post #8 of 21 (permalink) Old 26th January 2010, 20:24
Mr Blue Sky
garyhipkinswolves@yahoo.c's Avatar
hi there,i've had the same problem on my 56 1.8es civic,told dealers about it at the last 2 services but they say everything is ok,[i'm not sure],shall find out at next service when my warranty has run out,there will be one hell of an arguement if there is something wrong.Does it get worse in the wet ?.
post #9 of 21 (permalink) Old 26th January 2010, 21:02 Thread Starter
"Grandad eye"
stevey_p7's Avatar
Not noticed it in weather changes, but when its colder it seems to be a bit noisier. At first I thought something was cold and would go way after a bit but must be something like the bump stops mentioned earlier. Hope it gets sorted.
Don't mean this in a bad way but glad others have experienced this problem.
Will give Honda in wigan a ring and see if they can check it out for me. Warranty is up end of Feb so don't want to leave it till after then.
post #10 of 21 (permalink) Old 26th January 2010, 21:42
sharky7866's Avatar
Car: 2007 2.2 5Dr Black Civic
bumpstops - had mine replaced cured the problem - a month later started to make same noise but not as bad as before, if that makes sense. I have learnt one thing knowledge is power! so dont take the dealers word, say to them 'i have been to civinfo website' bla bla bla and explain properly and i bet you my bottom dollar they will investigate it properly and fix it, it worked for me, so far! Will be back again to dealers with suspension issue though as im really gonna make use out of that warranty before it expires in march!
sharky7866 is offline
post #11 of 21 (permalink) Old 27th January 2010, 09:32
Car: 2006 Civic 2.2 CDTi EX
Bump Stops
I get exactly the same on my car but it is out of warranty now and doubt it would be covered by the warranty I purchased. Is it important to get it done can it damage the car if you don't get it done and finally how much to get repaired?
Lex1970 is offline
post #12 of 21 (permalink) Old 27th January 2010, 12:05 Thread Starter
"Grandad eye"
stevey_p7's Avatar
Just been back to the garage I bought it from.
Got one of the mechanics to sit in car when went over speed bumps etc.
I told him I thought it was the bump stops but turns out its not a clunking noise but has more of a squeak to it so he seems to think its a dry joint.
They're going to lube up the suspension for me ten try it again. Still thinking of asking Honda to check it over for me. How would I know its definitely the bump stops?
post #13 of 21 (permalink) Old 27th January 2010, 19:56
They're going to lube up the suspension for me then try it again. Still thinking of asking Honda to check it over for me. How would I know its definitely the bump stops?
Lubricating and tightening the sub-frame bolts has cured this for a good few members - so, if this doesn't fix your problem - it's something else ! ...
post #14 of 21 (permalink) Old 27th January 2010, 19:58
It's the car that has the warranty - not the owner - no 'proof' needed ...
p.s. - the 'squeek' might also be an exhaust mount (pipe runs down under the right side of the car) ...
post #15 of 21 (permalink) Old 27th January 2010, 20:15
AKA - Vin Petrol
leepickering16's Avatar
Car: 2008 1.8 Type S GT, Silver
maaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa!
leepickering16 is offline
post #16 of 21 (permalink) Old 27th January 2010, 20:22
I have the same on my 06 civic 5dr EX
It only squeeks from the front passenger side when going over speed bumps, gets worse in the wet s well
Think my warrenty has gone too, but i think it is the bump stops or dry joint so maybe its the same problem as mine. It been doing it for 1 month now and i have left it, sometimes it goes away. So not to sure if it will damage it?
Im not that fussed, i dont think any of it is expensive to do either so dont worry, just take it easy
but nice to know its not just me
Milano.civic is offline
post #17 of 21 (permalink) Old 27th January 2010, 20:32
<3
Wire_Gal's Avatar
Car: Seat Leon Cupra
Same on mine, strut replaced in August - Started happening again a few weeks ago if not longer!
Good luck... I hope you are able to get it sorted!
Wire_Gal is offline
post #18 of 21 (permalink) Old 28th January 2010, 00:55 Thread Starter
"Grandad eye"
stevey_p7's Avatar
Had mine fixed today at the Garage I bought it from and sound exactly the same as my problem.
They found it to be a dry joint and something, can't remember what had slipped down.
Lubed up the suspension for me and now its quiet as it should be going over speed bumps.
Milano you should take yours to a garage you can trust and get them to check out the suspension just for piece of mind. A bit of lube on the suspension could cure all your noise problems.
hope you get it sorted.
post #19 of 21 (permalink) Old 28th January 2010, 18:21
jimp's Avatar
Car: http://www.civinfo.com/forum
Hey guys,
Look and this...
http://www.civinfo.com/forum/bugs-fa...ise-gtoup.html
jimp is offline
post #20 of 21 (permalink) Old 28th January 2010, 21:24
MikeW's Avatar
I had a similar noise from the front off side and Honda replaced the entire front suspension assembly under warranty.
MikeW is offline
Windscreen Wipers V's Speed Bumps markymark81 Bugs, faults and irritations (8G) 14 1st June 2010 11:24
Suspension scared of speed bumps??? pegliobaglio Wheels, Tyres, Suspension and Brakes (8G) 11 19th November 2009 12:12
Road Noise Metallic tapping/rattle over bumps (exterior noise) S18TypeR Bugs, faults and irritations (8G) 2 29th August 2009 22:13
Suspension new disconcerting noise from the civic f.ss.t Bugs, faults and irritations (8G) 10 25th September 2008 08:29
Suspension Post 25000 Service - Heavy squeaking on Speed Bumps nelster Wheels, Tyres, Suspension and Brakes (8G) 3 29th August 2008 09:51
