Leaks Water Retention - Civinfo
post #1 of 7 (permalink) Old 17th February 2010, 11:30 Thread Starter
Disco's Avatar
Water Retention
I heard a swish swash sound when braking and accerlation my type s, i traced it to the passenger door which was full of water, opening and closing the door you could hear the water sloshing about.
Took it to the dealer and was told the door is designed to let water through but has a membrane inside to stop the water getting into the car or electrics and the water drains out the holes in the bottom of the door.
What happened was the rubber plugs had clogged up over time therfore stopping the water from draining, removing and cleaning the rubber plugs fixed the problem, one to be aware of that could save the hassle of a trip to the dealer.
disco
Disco is offline
post #2 of 7 (permalink) Old 17th February 2010, 11:42
hurricane's Avatar
Car: 2008 1.8i SP LHD, Milano Red
Send a message via Skype™ to hurricane
disco
If you do a search on this forum you will find many posts dedicated to this "fault". Remove the rubber bungs completely, they should not be there because they STOP the water from coming out.
hurricane is offline
Thanks to hurricane from:
post #3 of 7 (permalink) Old 12th April 2010, 01:14
The Property Man
fat4y's Avatar
Car: 2007 VW Beetle 1.6
aww god exatly what i needed!! i thought it was the fuel tank..only sourced it today after a year lol..duuuuh!!
fat4y is offline
post #4 of 7 (permalink) Old 19th April 2010, 22:45
Gnuttah's Avatar
Car: 2006 2.2 ex i-cdti 5 door
Re: Water Retention
My back drivers side door has the same issue. The rubber bungs needed cleaning.
Gnuttah is offline
post #5 of 7 (permalink) Old 19th April 2010, 22:58
doofus4000's Avatar
disco
Yea I just ripped those buggers out after the first week of owning the car - knew that was going to happen with time!
lol you are hilarious FAT
doofus4000 is offline
post #6 of 7 (permalink) Old 20th April 2010, 12:47
hurricane's Avatar
REMOVING, not just cleaning. Leave them out.
post #7 of 7 (permalink) Old 21st April 2010, 22:14
Gnuttah's Avatar
Re: Water Retention
I will make sure I bin them then.
Gnuttah is offline
Water Nitehawk Any non Civic chat here please! 3 4th September 2009 22:23
Windows Water leaks weejegfeg Bugs, faults and irritations (8G) 0 17th June 2009 18:05
water Cookie Type-R 10 23rd September 2008 23:32
Leaks Water and more water Welsh Boy Bugs, faults and irritations (8G) 16 1st August 2007 13:24
Leaks Water water everywhere. lofthouse lightweight Bugs, faults and irritations (8G) 5 1st December 2006 20:54
