Windows Window Seals Look Odd - Civinfo
post #1 of 1 (permalink) Old 27th February 2010, 13:01 Thread Starter
Car: 2009 Civic Type s 1.4 i-VTEC
Hallo,
I've got a 2009 Type S and I've got 2 issues with the door window seals. At the front of the door the lower seal sits flat against the window glass. By the time it reaches the back of the door (above the door handle) the seal is a couple of millimetres away from the window. Is this correct ?
Also, on the drivers side, when the window is raised it pulls the trailing edge window seal out of its groove. Any fix ?
Clipper
clipper is offline
Windows side window seals tucked under jamo rgt Bugs, faults and irritations (8G) 11 1st April 2010 20:45
door seals! bassplayapaul938 General Discussion (8G) 6 20th August 2008 18:03
Bodywork Seals around the front wheels stu_iow Bugs, faults and irritations (8G) 12 30th March 2008 06:22
Damage Door Seals bucketp Bugs, faults and irritations (8G) 7 28th December 2007 17:37
