Electrics Low oil level warning light - Civinfo
post #1 of 2 (permalink) Old 7th March 2010, 21:25 Thread Starter
I've had this problem now on 2 Type R's, a 07 & 09.
If I drive past a radio mast I get the low oil level light come on. I have to be on the nearside and going no more than 50ish. It is only the level light not the low oil pressure. When it first came on I checked the oil level and it was right on the top mark. If you stop, switch off and then on the light stops off.
Dealer had it and checked the log and found nothing wrong but they reset everything. It was OK then for about 6 months.
Swopped the 07 for a 09 and this has started to do the same.
There are 2 masts nearby both with lots of dishs & aerials on and they both light up the warning light.
Dealer has checked the Honda notices and cannot find any other similar faults.
Anyone else had this?
bazctr is offline
post #2 of 2 (permalink) Old 7th March 2010, 22:32
Cockup Specialist
Relic's Avatar
Must be susceptible to high power emf fields.
Buddyclub uk
Cant say I have a problem..but only had mine 6 months.
Relic is offline
Faults Glow plug warning light flashing and engine management light on. Gmac00 Engines and Transmission (8G) 74 10th September 2019 07:54
Warnings speed warning beep level cbax Electronics (8G) 35 13th August 2012 09:56
High level brake light Paul M Styling (8G) 20 2nd April 2010 12:46
Oil Oil Level Warning Smeepers Engines and Transmission (8G) 18 6th September 2009 10:40
Brake Width of high level brake light - doesn't fill the light shape? benjamino Lights (8G) 3 12th January 2009 16:53
