Electrics power steering fault - fk2 - Civinfo
post #1 of 7 (permalink) Old 11th March 2010, 17:43 Thread Starter
Hello guys
i read many threads about the problem with the power steering ...
i have got a similar problem but not exactly the same ...
it appears normally when the car was parked over night at cold temperatures ...
i start the engine and get the orange steering wheel with ! beside ... powersteering does not work then ...
i have to restart to remove the failure and the car works without any problems then ...
the difference to the known problem is, that there is nothing recognized by the ECU ... no fault saved ...
i have been to the shop about 10 times now ... they cant find anything
they actually laughing at me because they think i'm dreaming or whatever ...
did anyone of you have something like that?
IMHO the car has a over all problem with the powersupply from the battery in cold weather while starting ... i also had problems with the radio that did not initialize correctly ... it was replaced but it happened again one after a really cold night ...
baernhard
darock is offline
post #2 of 7 (permalink) Old 12th March 2010, 23:10
fidsey's Avatar
Car: 2017 Civic 1.5 turbo sport +
That's what your problem is power supply, The only way to find the problem is to plug a handset into the obd an run a live data program, probably due to low voltage problems,had this problem with an MGF,came up with steering angle sensor,ran live data and found only 11v supply found a duff battery led to the problem.
fidsey is offline
post #3 of 7 (permalink) Old 13th March 2010, 12:37 Thread Starter
thats exactly what i'm thinking of ... but the guys at the shop won't listen to me
bernhard
darock is offline
post #4 of 7 (permalink) Old 13th March 2010, 16:11
CCC
CCC's Avatar
bernhard
I would go to a different dealer.
CCC is offline
post #5 of 7 (permalink) Old 13th March 2010, 16:45
pcr
pcr's Avatar
Somewhere on the forum is a Honda service bulletin which I think replaces the EPS module for this fault.
pcr is offline
post #6 of 7 (permalink) Old 13th March 2010, 20:32
a lot of important systems in your civic require a minimum of 12.6v to work propperly. a car will start with less than this but the damage is allready done so to speak. thats why once started and then switched off and on again the fault may dissapeer. you have increased the battery voltage and the fault is no longer there. there have been problems with the eps controll units and the connectors to the steering rack being loose. as a start point though check the battery voltage and eliminate any problems that may be causing a battery drain.
beefy_634 is offline
post #7 of 7 (permalink) Old 14th March 2010, 09:01 Thread Starter
i will call the dealer tomorrow or tuesday ... lets say what they think about this ...
i hope i can find this bulletin on the forum
bernhard
darock is offline
Steering Power Steering problem PipsBBQs Bugs, faults and irritations (8G) 10 9th October 2017 09:16
EPS Power steering fault avatacrx Wiki Article Discussion 3 17th April 2015 16:07
Steering fault Merk1981 General Discussion (8G) 5 8th February 2010 11:43
Steering Help please - lost power steering! Stew200 Bugs, faults and irritations (8G) 5 22nd December 2009 23:31
Steering Power Steering Error DeshiUK Bugs, faults and irritations (8G) 11 17th September 2009 22:31
