Steering Steering drift - Civinfo
post #1 of 12 (permalink) Old 30th March 2010, 13:22 Thread Starter
Syx
#MrGrumpy
Syx's Avatar
Car: 2008 2.2 CTS GT
Steering drift
Hi folks - my first post here after lurking for a few months!
When I first joined I had a 1.4 SE Civic, now that's been traded in for a 2.2 Type-S
The issue I have is that coming from the 1.4, I'm noticing a fair difference in the steering; the only way to explain it is like having a side wind on the car, even when there is none. Holding the wheel steady will result in varying amounts of pressure feedback from the steering.
I've read a few threads on this and there are various pointers to the alignment/tracking, but before I get on the phone to the dealers I was just hoping for some feedback on whether this is at all normal due to the change in tyre profile?
Any input is much appreciated... it's the only thing I can find that isn't perfect about the car!
Syx is offline
post #2 of 12 (permalink) Old 30th March 2010, 13:33
Voxen's Avatar
Car: 2006 2.2 i-CDTi FK3
Best get your car checked.
I have 2.2 I have no problems like this.
Voxen is offline
post #3 of 12 (permalink) Old 30th March 2010, 13:37
Car: Jag XF 3.0
How bald are the tyres and what make and type are they?
Pottsy is offline
post #4 of 12 (permalink) Old 30th March 2010, 14:22
morten's Avatar
Car: 2011 Skoda Octavia 1.4 TSI
I assume you feels these differences on the same roads as you drove (and felt nothing) with your 1.4? Do the car pull both right and left? If you have wider tyres on the 2.2, you could be feeling tramlining.
morten is offline
post #5 of 12 (permalink) Old 30th March 2010, 14:48
J. Derek Riddell's Avatar
1} If thetyres are well worn (as Pottsy pointed out) you'll get this ...
2} Civic ex-works wheel alignment can be poor (wide tolerances) - a proper 'FRS' is a very good idea ...
J. Derek Riddell is offline
post #6 of 12 (permalink) Old 30th March 2010, 15:04 Thread Starter
Syx
#MrGrumpy
Syx's Avatar
Tyres are far from worn, I'll check the exact details in a little while as, typically, it's tipping it down outside at the moment.
I'm driving the same roads as before (i.e. to work and back!) and am now experiencing this - I didn't notice it when I picked the car up last week but most of my miles have been motorway up until Sunday.
No idea what an 'FRS' refers to... coming from a background in performance motorbikes, the car is a bit of an unknown!
Syx is offline
post #7 of 12 (permalink) Old 30th March 2010, 16:39
everyday i get older
Evil Berto's Avatar
Car: 2007 CTR NHB
Send a message via MSN to Evil Berto
balancing, track rod end?
Evil Berto is offline
post #8 of 12 (permalink) Old 30th March 2010, 17:25
Originally Posted by Syx View Post
....... No idea what an 'FRS' refers to... coming from a background in performance motorbikes, the car is a bit of an unknown!
FRS is Fast Road Setup - it's a vastly better alignment setup than Honda let the Civic out of the factory with - check out the [ABP Motorsport] section for lots of info. ...
post #9 of 12 (permalink) Old 30th March 2010, 18:47 Thread Starter
Syx
#MrGrumpy
Syx's Avatar
Will definitely look into that, JDR.
I'm thinking that the problem is tramlining more than anything; on the way home from work I noted that driving to the left side of my lane resulted in left pull, and the right side of my lane (i.e. close to the center line) resulted in right pull. This happened on several occasions on differing road surfaces...
Oh, and tyres are 225/45's (17").
Syx is offline
post #10 of 12 (permalink) Old 30th March 2010, 19:48
morten's Avatar
225's should be tramlining far more than for example 205's. I use both, the wider as summer tyre and the narrower as winter tyre. In my case, there are of course other things to consider as the construction of summer/winter tyres are completely different.
But the pattern is clear - narrow tramlines less than wide.
morten is offline
post #11 of 12 (permalink) Old 30th March 2010, 20:07 Thread Starter
Syx
#MrGrumpy
Syx's Avatar
The difference in width probably is the explanation. No harm in getting the dealer to take a look though as it's still under warranty!
Many thanks for your help.
Syx is offline
post #12 of 12 (permalink) Old 11th April 2010, 20:37
Merk1981's Avatar
Car: FRV EX 2.2
Syx - Did you manage to get to the bottom of this? I think I have the same problem. I had a long trip out today down a very straight old roman road and the drift was even more noticable than usual.
Merk1981 is offline
Steering Steering creaking MisterTee Bugs, faults and irritations (8G) 28 31st July 2009 10:53
23rd May. British Drift Championships - Round 2, Llandow, Wales. royal Any non Civic chat here please! 1 11th May 2009 18:34
Steering Rattles from steering column/steering pump morten Bugs, faults and irritations (8G) 11 18th April 2008 07:38
Steering Steering drift (merged) KJay Bugs, faults and irritations (8G) 17 22nd August 2007 10:04
