Engine Is my clutch on it's last legs? - Civinfo
post #1 of 3 (permalink) Old 12th April 2010, 09:34 Thread Starter
ash_rage's Avatar
Car: 2016 CTR FK2 GT - Milano
Hello all,
My 2006, ES, 1.8 Manual Petrol has developed a fault. It has done 32K miles. When moving off in 1st it feels like the wheels are on spinning on ice then it suddenly moves off, the wheels however are not spinning this is just what it feels like. This only happens now and then. I was wondering if the judder is coming from the clutch? It started after I sat in traffic for 2 hours a few weeks back. It occurs after a long journey and first thing in the morning. The clutch is definitely not slipping when i am changing up gears whilst driving. I have seen simliar posts on here but the issue others describe are not exactly the same as mine. I have recently started using V Power, could that be causing it?
Many thanks.
ash_rage is offline
post #2 of 3 (permalink) Old 12th April 2010, 09:55
J. Derek Riddell's Avatar
As per my reply to your other thread, I heavily suspect that you've "polished" the clutch pad, probably by 'slipping' the clutch in a traffic queue ...
Try to rigorously avoid touching the clutch, except for "normal" changes, for a week or two - and never 'slip' it in traffic or on a slope (use the handbrake) ...
If you're lucky, the problem will disappear ! ...
J. Derek Riddell is offline
post #3 of 3 (permalink) Old 12th April 2010, 09:58 Thread Starter
ash_rage's Avatar
Ok thanks buddy, I tried to delete this thread once you replied in the other one but I'm guessing supervisors can only delete threads, thanks for you help.
ash_rage is offline
Tags
clutch judder
Tuning Slipping Clutch - Tuning or Clutch issue? Jambo0607 Engines and Transmission (8G) 7 24th May 2012 10:14
Clutch 2.2 clutch steve fox Engines and Transmission (8G) 4 1st March 2010 22:13
Clutch Is my clutch on the way out? Rab Engines and Transmission (8G) 26 10th February 2010 07:47
Transmission Stretching my legs MisterTee Engines and Transmission (8G) 14 22nd March 2008 21:00
Transmission Clutch on the way out ?? tezwar Bugs, faults and irritations (8G) 1 7th March 2008 21:11
