Engine 2.2CDTI Engine rasp/whine into cabin? - Civinfo
 6Likes
  • 1 Post By Jarrodstrachan
  • 2 Post By cavalrystu
post #1 of 15 (permalink) Old 20th March 2018, 17:31 Thread Starter
Hi all,
Before I go ahead and pay to have this diagnosed, I was wondering whether it sounds similar to any known issues with the 2.2 CDTI?
I had the manifold gasket replaced under warranty on my 07 2.2CDTI a few weeks ago and ever since I've noticed a rasp/whine/blowing coming from the engine, audible from inside the cabin. More noticeable the higher the revs.
Does anyone have any theories?
Many thanks
Jarrodstrachan is offline
post #2 of 15 (permalink) Old 20th March 2018, 17:36
Farqui's Avatar
Car: x'06 2.2 EX FK3 Milano
Eco display Eco display
The exhaust or inlet manifold gasket? The gasket was leaking?
Do you mean the exhaust manifold was cracked and repaired under warranty?
Have you approached the garage who performed the warranty work about this noise?
Are you using a stock Honda air filter?
Farqui is offline
post #3 of 15 (permalink) Old 20th March 2018, 17:42 Thread Starter
I believe it was the exhaust manifold that was cracked yes, £750 worth of work according to the dealership (under warranty though)
I did replace the air filter in January, I don't believe it was OEM however? Cost me around £15
Farqui likes this.
post #4 of 15 (permalink) Old 20th March 2018, 17:45
Farqui's Avatar
Okay, that makes sense as zoorst manifold repair is fairly common on the old 2.2's.
Try re-seating the air filter and see if that helps. None OEM are known to make odd noises. An OEM filter isn't much, is easy to fit and known to flow well, so I'd suggest getting one fitted.
Did the warranty repair folks not mention the noise then?
Farqui is offline
Thanks to Farqui from:
post #5 of 15 (permalink) Old 20th March 2018, 17:47
I'll second the Air Filter, get a genuine one in there, and it will be a lot better.
They're good for 25k miles....
scaramanga and Farqui like this.
cavalrystu is offline
Thanks to cavalrystu from:
post #6 of 15 (permalink) Old 21st March 2018, 10:26 Thread Starter
Thanks for your suggestions guys, I'll grab a Honda filter from COX in next few weeks and report back
Many thanks!
Also, dealership were pretty useless with any questions I put towards them so I haven't even bothered asking them so far
Farqui likes this.
post #7 of 15 (permalink) Old 21st March 2018, 13:35
Trev27's Avatar
Car: 2010 Civic Si 2.2
Agree with air filter, mine had the same noise, changed the air filter to a OEM one and the noise went
Trev27 is offline
Thanks to Trev27 from:
post #8 of 15 (permalink) Old 21st March 2018, 14:04 Thread Starter
I've ordered a genuine filter form COX, should be with me Friday. Hopefully will sort it
I'll be sure to report back
Farqui likes this.
post #9 of 15 (permalink) Old 22nd March 2018, 05:46
madman's Avatar
Yeah with air filter, fuel filter and oil filter its best to go for genuine parts.
madman is offline
post #10 of 15 (permalink) Old 22nd March 2018, 09:53 Thread Starter
I'm just hoping it's not a timing chain issue
post #11 of 15 (permalink) Old 22nd March 2018, 12:49
If the timing chain is a problem (and I've only heard of this on a car without regular oil changes), then it should be nosiest at idle... not under load.
I'd expect, under load, the chain should tension more
post #12 of 15 (permalink) Old 22nd March 2018, 13:18
Zaheen's Avatar
Car: Silver 2.2 EX (Type R Kit)
Originally Posted by Jarrodstrachan View Post
Hi all,
Many thanks
Hey, mind if I ask what the mileage was on your car when it was changed under warranty?
They refused to change mine, wanted me to pay labour.
Zaheen is offline
post #13 of 15 (permalink) Old 22nd March 2018, 13:43 Thread Starter
Ah ok, it's normal at idle so that sounds good.
Mine was on 118k, the dealership refused, however HondaUK customer services agreed (with a bit of arm twisting over me being worried about fumes in the car).
deni.babe likes this.
post #14 of 15 (permalink) Old 24th March 2018, 23:11 Thread Starter
So quid update
Installed the new Honda air filter, felt like more power lower down in the range (maybe placebo effect? Felt real though) . However, the noise is still present. Iím starting to think itís maybe not a rasp and more of a very very slight rattle?
Looks like Iím going have to take it down to the dealership
Thanks all for suggestions though
post #15 of 15 (permalink) Old 25th March 2018, 00:10
Farqui's Avatar
Heat shield?
Is quite common for a simple mount to rust thru. Often easily fixed by a big washer.
Modern cars have lots of thin heat shields, some seem completely pointless.
Farqui is offline
Other Engine whine Kirkyboy1981 Engines and Transmission (8G) 21 26th May 2017 14:20
Engine whine jamie_85 Type-R 14 21st November 2015 11:48
Servicing cabin air filter in 2.2cdti 06 model Amalup Engines and Transmission (8G) 5 27th March 2014 17:58
Other wire from cabin to engine bay robm255 Electronics (8G) 5 10th September 2013 09:01
Electrics Wires from cabin to engine bay. Grayfox Electronics (8G) 2 28th December 2012 09:44
