Electrics 2006 Honda Civic - ABS/VSA Check System Message - Civinfo
post #1 of 6 (permalink) Old 5th April 2018, 12:35 Thread Starter
Car: '06 FK2 Honda Civic
I have a daily 2006 1.8 Honda civic (fk2) and last week after driving in an unavoidable puddle, the Check ABS and VSA system message has appeared. I have run a diagnostic, cleared all faults and the following still remains:
' 54-1 - Relay fail; safe relay fail '
Does this mean the ABS relay in the exterior fuse box is faulty and needs replacing? Battery was replaced about 8 months ago so cant see this being the issue (as I have read low voltage can be an issue). Anyone with an FN2 or same generation civic had this issue?
Update: Had this issue for a while now and MOT is due so time to get this sorted. See the image attached below. I have tried to remove the ABS/VSA black plastic box fuse as per the diagram - this is #3 for the VSA/ABS - is this the relay? No luck with it as I removed the screw but it won't move at all - is there a way of taking this out/how do you remove this? And where can I get a replacement as I believe this is the best place (and cheapest) to start in solving the issue.
All other fuses seem fine on inspection including the interior fuse box - #4 ABS unit fuse.
All input is appreciated.
ad_illest is offline
post #2 of 6 (permalink) Old 8th April 2018, 12:26 Thread Starter
Anyone able to help?
post #3 of 6 (permalink) Old 8th April 2018, 12:35
scaramanga's Avatar
Car: 2015 white orchid 1.6 dtec
never came across this one but if its saying relay failure its a good place to start
if you cant get 1 at reasnoble price try a scrap yard
scaramanga is online now
post #4 of 6 (permalink) Old 8th April 2018, 20:36
Skomaz's Avatar
Car: 2006 2.2 ctdi Sport
Got the same (intermittent) for probably the same reason (drove through the ford at Kenilworth Castle last weekend).
I was suspecting a sensor failure but no codes for those, which I assumed would be saved and not deleted on the next start) so I'm suspecting a battery on the way out as I have a low voltage code as far as I can make out - PA50 B1177 and an open recirc flap code PA51 B2983...
Any thoughts?
Skomaz is offline
post #5 of 6 (permalink) Old 9th April 2018, 10:22
cosmicma's Avatar
once you have undone the screw on that fuse just pull upwards to remove
it'l be tight but it will come out
cosmicma is offline
post #6 of 6 (permalink) Old 10th April 2018, 14:40 Thread Starter
So I have had the car checked over by a local garage also and the same code was thrown up (54-1) and nothing additional. If it were to be sensors or battery related, this would throw up a code right so I won't be chasing those parts.
As far as I am aware, the relay is part of the ABS module / pump if I am correct? So I will probably be replacing the pump and seeing how that goes.
Brakes ABS and VSA system check rindo Bugs, faults and irritations (8G) 13 17th October 2017 19:36
Lights VSA and ABS check system lights. Marley365 Bugs, faults and irritations (8G) 6 15th March 2013 17:40
VSA Check VSA system and Check ABS system lights Dizzy65 Electronics (8G) 10 27th January 2013 16:41
VSA ABS / VSA Check System!! davenoddy Electronics (8G) 6 17th January 2013 21:16
Electrics Check System ABS / VSA at Start Dai_kun Bugs, faults and irritations (8G) 0 19th November 2012 22:05
