2008 honda civic ex - Civinfo
 1Likes
  • 1 Post By munkehpunch
post #1 of 17 (permalink) Old 18th April 2018, 11:22 Thread Starter
munkehpunch's Avatar
2008 honda civic ex
hey everyone, I'm new to honda but I have came across something that was fine at the start but now it's getting on my nerves don't know if it's a bug or a setting.
the digital speed readout is 4mph over the actual speed that I am doing . I've checked everything in the settings where the trip is etc and I have pressed to put them back to factory prefers but still no joy, is this a problem or is it because of a setting somewhere?
I sooner it be over than under but after a while it gets a bit annoying
regards
Phil
munkehpunch is offline
post #2 of 17 (permalink) Old 18th April 2018, 11:28
peniole's Avatar
How did you determine it was over by 4MPH, and at what speed?
Typically most manufacturers overestimate speed on their speedometers, and it gets worse the faster you go. Which is why you frequently see super accurate digital GPS speedos being used on car shows and record runs (even in ridiculously expensive cars).
My 8G was about 2-3MPH over at 50 IIRC.
Are the wheels on it stock? or have they been changed? That can add or lessen the problem depending on the final diameter.
peniole is offline
post #3 of 17 (permalink) Old 18th April 2018, 13:00
cb550's Avatar
Car: 2009 EXGT auto, Audi TT 190
regards
Phil
Hi
all our 4 civics were the same, and I think they all(8 gen's) are.
Not an issue for me, actually prefer it that way in the event the car speed should run away a little in any restricted length of road.
cb550 is offline
post #4 of 17 (permalink) Old 18th April 2018, 14:28
chriss95's Avatar
Car: 2008 2.2 Civic, Grey
Mines the same, whenever I pass those roadside speed indicator thingys my speedometer is constantly out by 4-5mph...
chriss95 is offline
post #5 of 17 (permalink) Old 18th April 2018, 17:59
Das
i-Vtec
Das's Avatar
Car: 2009 1.8 ES
Mine is 3mph out at 70 when checked against a phone based GPS app on my phone. My last car(Analogue Speedo) around about the same. I think the Digital speedo makes it look worse than on an old style Analogue Speedo that doesn't have 1mph increments. Good news is you should never really be caught speeding.
Das is offline
post #6 of 17 (permalink) Old 18th April 2018, 18:59 Thread Starter
thanks for the replies ( sorry I'm new to this forum I apologise if I'm replying in the wrong way)
just rough estimate I have used the usual road signs and my sat nav, my sat nav on previous car was spot on this one it's over and now that i have a dash cam the speed on that matches up with the others ones and still states that I'm 5mph over.
it's not a issue as such just wasn't to sure it was a problem I had or if others had it,
I would sooner it be 5mph over instead of 5mph under so suppose that's a bonus.
but looks like people have the same issue as I do so at least I know it's common .
as for the wheels their all stock and tyres are correct size.
im new to Honda's i have a 2008 1.8 ex what gen is that classed as
thanks again people if I am replying to posts in the wrong way could someone please point me in the right direction 🙂
regards
post #7 of 17 (permalink) Old 18th April 2018, 21:12
cb550's Avatar
8 generation- 2006 to 2010/11. 9 gen is a remodelling of the 8 gen with improved suspension and changes to the front,rear, engines and interior.
Ours is the 2009 1.8 auto. 'Been very pleased with the car 3 years on.
cb550 is offline
post #8 of 17 (permalink) Old 18th April 2018, 21:14
I Hate tailgaters!
Red Dwarf's Avatar
Car: 2016 1.6 SR Lunar Silver
Eco display Eco display
regards
2008 says Mk8 to me.
Especially if it has a nose like this.
Red Dwarf is offline
post #9 of 17 (permalink) Old 18th April 2018, 21:53
Ex-Pat Geordie!
nturnb's Avatar
Car: 2015 Civic S Navi I-dtec
Over 30 MPH mine was always about 5MPH out using SatNav...
nturnb is offline
post #10 of 17 (permalink) Old 18th April 2018, 22:02 Thread Starter
mine is a 2008 ex . but doesn't have the black grill as seen in my display pic
post #11 of 17 (permalink) Old 18th April 2018, 22:06 Thread Starter
ah right thanks, mine is a 2008 1.8 ex I shift, only had it a few weeks first Honda I have had and cannot fault it has a couple of annoying buts like no aux but that's easily sorted apart from that their very good cars
thank you for your reply
cb550 likes this.
post #12 of 17 (permalink) Old 23rd April 2018, 11:44
NS_15's Avatar
My 8gen EX 1.8 is under by 3-4 mph.
I've only noticed this a few times when driving past those digital speed checkers on inner city roads that show your speed and request to slow down e.g. the car display shows 30mph, the speed checker shows 27mph.
(Sorry, not sure what those speed checkers are called, but I've seen them usually near a school or park)
NS_15 is offline
post #13 of 17 (permalink) Old 23rd April 2018, 12:06 Thread Starter
mine is the same but it's different at different speeds. 30mph I'm 5 over 70mph I'm 3 over .
it's not a issue though as to be honest I would sooner it be over than under.
think the only way you could fix it is to get a propper digital speed clock but the price of them wouldn't make it worth while
post #14 of 17 (permalink) Old 23rd April 2018, 16:11
NS_15's Avatar
Not sure if a software upgrade by Honda would fix it? To be honest, it's probably best to leave it and just aim to keep your speed down by 3mph when approaching a speed camera
NS_15 is offline
post #15 of 17 (permalink) Old 23rd April 2018, 16:34
Car: MY13 1.8 EX Auto
Kremmen is offline
post #16 of 17 (permalink) Old 23rd April 2018, 17:15
Car: 2006 1.8 ES petrol v-tech
All vehicle manufacturers speedometers are set up with a reading that is slightly under actual speed, it's 4-5 mph at low speed 7-8 mph at higher speeds so completely normal. It's to try and stop people exceeding the limits!!
painter is offline
post #17 of 17 (permalink) Old 23rd April 2018, 17:42 Thread Starter
I had a feeling that could be the case but as it's the first car I have owned that has a digital display I wasn't to sure
2008 (Reg 08) Honda Civic 2.2 I-CTDI SE / 2008 = Problems Solved? andyp2 General Discussion (8G) 6 28th March 2012 10:58
2008 Honda Civic DX-G BrianHA Introduce yourself 5 12th February 2008 13:15
