Leaks passenger footwell - Civinfo
post #1 of 3 (permalink) Old 8th May 2010, 18:42 Thread Starter
shari37@hotmail.co.uk's Avatar
passenger footwell
i've got a trickle of water running out from underneath the centre console, on left hand side, into the front passenger footwell. it clear, cold water. the air con is on.
any ideas please, before i throw myself at the mercy of the local honda dealership?
post #2 of 3 (permalink) Old 11th May 2010, 07:33
fidsey's Avatar
Car: 2017 Civic 1.5 turbo sport +
Maybe the water drainer in the heaterbox is blocked or cracked.
fidsey is offline
post #3 of 3 (permalink) Old 11th May 2010, 13:07
boose's Avatar
Car: 57 1.8 EX NHB
I've had this on mine. There is a cover across a filter for the air con, and its in passenger kicking distance.
The cover is around an inch wide, and maybe 10 inches long and is quite easy to fit wrong....will try and get a photo of it as its going to end up being inuendo tastic here.
You should see something like that on the console side of your passenger footwell, and will likely need to get low to see it. You can see on the bottom of the picture there is a rectangle hole, thats whats broken on mine, but a bit of pressure got it sealed back up.
Have also got the original unsized http://img20.imageshack.us/img20/1993/imag0036t.jpg if that is any use to you.
Boose
boose is offline
Interior Red Footwell Lights In CTR-GT saggo Lights (8G) 2 1st October 2008 21:52
Leaks Water leaking into passenger footwell Type r Richard Bugs, faults and irritations (8G) 6 14th September 2008 22:39
Interior footwell leds lozhoon Lights (8G) 14 14th December 2007 17:04
Interior footwell lighting gers Lights (8G) 7 8th October 2007 20:03
Interior Footwell light DIY? pikkumies Lights (8G) 3 25th June 2006 17:00
