Squeaks Type S rear squeak! - Civinfo
post #1 of 5 (permalink) Old 14th May 2010, 13:54 Thread Starter
Type S rear squeak!
When i park on a flat and drive away in the morning or the car has been sitting a long time i get a huge sweeking from the rear suspention! it goes away by the end of the road! what is it? Honda cant find anything wrong!
HELP
Type-s-nick is offline
post #2 of 5 (permalink) Old 14th May 2010, 13:59
I get this too, it's more of a creak fromt he rear suspension with mine.
I'm guessing it's just another civic quirk. I'm not too worried about it and as you say, it only happens from start off in the morning for a second or two. Handling is absoutely fine.
AmyF is offline
post #3 of 5 (permalink) Old 14th May 2010, 14:02
You military fool you!
GavChap's Avatar
Car: 2006 1.8 Sport 5Dr NHB.
On the wiki it explains it's the rubber exhaust hanger, try squirting it with some silicone grease.
http://www.civinfo.com/wiki/index.ph..._in_a_cold_car
GavChap is offline
post #4 of 5 (permalink) Old 14th May 2010, 14:05
Evora's Avatar
Car: 2007 1.8 CTS GT, Silver
I have exactly the same problem with the rear, even after the cars been unused for a couple of hours. Honda UK do have a log of the problem, but have no solution. I got told it was a characteristic of the civic!
I'm looking into replacing the springs with the eibach pro kit, as this might be a solution to the so called characteristic of our cars.
Evora is offline
post #5 of 5 (permalink) Old 14th May 2010, 16:54
more torque than the mrs
deni.babe's Avatar
i have it to every morning when i reverse off the drive i get a creaking sound and knocking sound it clears after 30 seconds of driving must be the suspension leveling out as you drive.
deni.babe is offline
Squeaks Squeak/rattle from rear curtain airbag mechanism area? benjamino Bugs, faults and irritations (8G) 12 20th July 2011 22:17
Squeaks squeak/creak darron Bugs, faults and irritations (8G) 0 11th January 2010 16:57
Squeaks Squeak under car... stops when raining!... mike170177 Bugs, faults and irritations (8G) 2 25th August 2009 12:50
Squeak from rear woody2k4 Type-R 7 12th August 2009 22:53
Faults squeak from engine eddie642 Engines and Transmission (8G) 4 27th April 2009 21:38
