Damage FN2 TYPE R burnt in front of me 😞 - Civinfo
post #1 of 6 (permalink) Old 21st September 2018, 09:23 Thread Starter
Harry Robinson's Avatar
Hi All,
I bought my NHB FN2 last month and loved the car, it cost me 7000 in cash to buy and had 57k on the clock with the cleanest M.O.T history I had ever seen ( never failed only ever had 1 advisory ).
I had driven the car for only 1500 miles before the front passenger fog light went up in flames, leaving the car as an absolute wreck.
You can see on the images that the flame started from the fog, I believe there is only electrical components in that area of the car which could catch on fire.
Anyway, I am going to be after getting another NHB FNW but 3500 out of pocket 😞 does anyone know if it's a common fault for the fogs to ignite like that as it may sway my next car decision.
Also, would it be worth looking in to buying it back and getting it repaired rather than claiming the money back ?
I don't care if it will get labelled as a CAT as I don't intend on selling the car until it's at 110k+ or it dies.
Let me know your thoughts.
Last edited by Harry Robinson; 21st September 2018 at 09:28. Reason: Blurring numberplate
Harry Robinson is offline
post #2 of 6 (permalink) Old 21st September 2018, 10:18
Farqui's Avatar
Car: x'06 2.2 EX FK3 Milano
Eco display Eco display
I've not seen anything like this before and it seems odd that you would photograph this and that wouldn't be my first reaction.
Were you driving with any lights on? Odd that the fuse didn't blow and prevent this.
If your car has HID's then that's high voltage and temp's, which might have failed.
Do you have any aftermarket lights/bulbs fitted?
Farqui is offline
post #3 of 6 (permalink) Old 21st September 2018, 15:00
Clutch pedal guru
hondacivicnut's Avatar
Did the circuit have a fuse on it? Either that or aftermarket bulbs causing the issue? I've seen increased wattage bulbs melt connectors before.
hondacivicnut is offline
post #4 of 6 (permalink) Old 23rd September 2018, 16:14 Thread Starter
Yeah I just panicked when it happened to be honest and my first reaction after trying to kick the fog light out and call the fire brigade was to take photos for insurance.
I did have the fogs and headlights on at the time, I got my dad to have a look at it shortly after the fire had been extinguished and he said the sub frame may have been rubbing on the wires over time and it could have sparked the insulation. But he is not a mechanic at the end of the day so I'm unsure how accurate that is.
All bulbs and everything on the car appeared to be standard.
post #5 of 6 (permalink) Old 23rd September 2018, 16:30
Clutch pedal guru
A live bare wire rubbing would create a short which should blow a fuse.
post #6 of 6 (permalink) Old 23rd September 2018, 16:32
M8TJT's Avatar
Car: 10G 1.5 Civic Prestige
Doesn't look very foggy in your pic. Why on earth did you have your fog lights on?
The Highway Code says that you should only use your fog lamps when the visibility drops below 100m. If you're not sure when that is, a good rule of thumb is to work out whether you can see the tail lights of the car in front of you. If you can't, you (and they) should probably be using rear fog lamps.
See HERE Rule 236 applies.
M8TJT is offline
Broken wing mirror 😞 Sugarpink General Discussion (8G) 2 20th September 2018 11:20
Transmission Burnt FN2 flywheel jcws Bugs, faults and irritations (8G) 6 27th November 2014 12:54
Anyone been burnt by a hot knob? (gearstick) lol :) Mike710_0 General Discussion (8G) 10 11th June 2010 13:42
Windscreen Wiper Motor burnt out Grahamw Bugs, faults and irritations (8G) 1 22nd January 2010 08:16
Clutch Possibly completely burnt out clutch at 37.5k miles?? generationgav Engines and Transmission (8G) 16 10th June 2008 15:28
