AC/Heater 2.2 Diesel 2010 CDTi Heater not Working—Could it be the compressor? - Civinfo
 1Likes
  • 1 Post By Stuart Henry Wilson
post #1 of 4 (permalink) Old 9th November 2018, 17:38 Thread Starter
Hi all,
A few weeks back I bought a 2010 CDTi for £1000. I think it was involved in an accident at the passenger side as the passenger window does not work and the mirror adjustment is pretty wonky but the main issue is that the heating system does not work at all.
I've spent the past few weeks (slowly) troubleshooting and trying different things and I now think that the AC compressor is gubbed (I saw a post from September that mentions shimming or replacing it but I can't post any links just yet).
I'm not a mechanic, and this is the first time I've ever tried to do something to a car other than drive it, but here's what I've tried so far:
  1. I tested the fuses (7 and 36) and they work ok
  2. I replaced the AC relay in the bonnet fuse box but it didn't help—I can hear it clicking on, though
  3. I tested the blower motor resistor and it seemed fine—I replaced it anyway but it didn't help
The heating IS doing something. There's definitely a fan kicking in somewhere when I turn it on, just not the main blower motor at the left side of the clutch. You can hear it, though (I tried to record a video but it didn't pick up the subtle sound). Having read around on this forum a bit, I get the impression that the AC compressor (I think) is supposed to start turning whenever I turn the heating on (or is it just when I have the AC temp low?). This isn't happening. The main fans at the grill are turning when the engine is on and, when I drive it for a bit, hot air does come through the vents but it's very weak.
I'm just looking for any suggestions on the best way forward. I've sourced a replacement blower motor but I don't wanna drop the cash on it if it turns out to be the AC compressor that needs fixing. Any ideas on what to do next?
I have some videos to upload but, again, the forum won't let me because my post count is less than five!
Stuart Henry Wilson is offline
post #2 of 4 (permalink) Old 9th November 2018, 17:43
Farqui's Avatar
Car: x'06 2.2 EX FK3 Milano
Eco display Eco display
Your AC system is separate from your heating system.
Heating comes direct from the engine coolant and you should be able to trace 2 hoses from the engine bay through the firewall at the back of the engine. These should both be warm once the engine is up to temperature, if one isn't then you may have a blockage within the cabin matrix.
Engine bay fans cool then engine coolant and aren't responsible for blowing air into the cabin.
The cabin blower should work regardless of AC/heater temps, you say this isn't working right?
You may (also) have an issue with your heater direction control flap(s).
I suggest you get a garage to check the issue for you.
Farqui is offline
post #3 of 4 (permalink) Old 10th November 2018, 11:50 Thread Starter
Hey, thanks for your reply.
The cabin blower isn't working at all. Would that mean that I need a new fan unit regardless of what other issues there are? I have sourced one for just £25—I can pick it up mid-week.
Next time I take it for a longer drive, I'll check the hoses you mentioned to see if there could be a blockage. I think the direction control flaps are also working ok because, when I adjust the heating controls, I can hear them moving.
Farqui likes this.
post #4 of 4 (permalink) Old 11th November 2018, 08:02
Farqui's Avatar
It does sound like your internal fan maybe kaput, try and confirm that it's getting power.
Farqui is offline
Heater, Mirror controls, Alarm lights not working!!!! Knight Rider General Discussion (8G) 17 13th January 2019 19:05
AC/Heater A/C Heater not working. thefiss Bugs, faults and irritations (8G) 15 16th January 2016 16:28
AC/Heater A/C not working after new compressor notsure Bugs, faults and irritations (8G) 7 31st May 2015 18:01
AC/Heater Compressor Not Working..Please Help! CivicX Bugs, faults and irritations (8G) 4 26th August 2012 19:12
Heater not working!!! doogle Type-R 12 1st March 2011 21:09
