Electrics Cooling fans - Civinfo
post #1 of 24 (permalink) Old 29th May 2010, 12:41 Thread Starter
sotonsmut's Avatar
Cooling fans
Hi i have a bit of a problem, both my cooling fans are on all the time(with ignition on!). i have been told it might be a relay problem, but i cant seem to find them.
Any ideas on the problem or the location of the relays would help!
2.2cdti
sotonsmut is offline
post #2 of 24 (permalink) Old 29th May 2010, 14:06
Cockup Specialist
Relic's Avatar
2.2cdti
Relays are under the bonner on the right next to the battery ?
Could also be a faulty water temp sensor..there are issues with corrosion.
Water levels OK ?
Water pump OK ?
Relic is offline
post #3 of 24 (permalink) Old 29th May 2010, 17:22 Thread Starter
sotonsmut's Avatar
Water levels OK ?
Water pump OK ?
dash temp is the same as normal so dont think its the pump or sender, but if i pull the 40 amp fuse(fan pic) in the box next to the air filter they still stay on. making me think its the relay or temp sender on the AC side!
Are the relays next to battery in the fuse box or outside of it!
post #4 of 24 (permalink) Old 29th May 2010, 17:56
Cockup Specialist
Relic's Avatar
But if you pull the right relay they should be dead.. they wont get power
On the fords there are two temp sensors.
One for the dash and one for the ECU.
I believe there are two temp sensors for the Honda as well.
I'll pop outside later and see what I got.
Relic is offline
post #5 of 24 (permalink) Old 29th May 2010, 18:29 Thread Starter
sotonsmut's Avatar
I plulled the small gray relay in the under bonnet fuse box and only one went off!
post #6 of 24 (permalink) Old 29th May 2010, 19:35
guido09's Avatar
Car: 2007 2.2 sport Champ. Met.
when both of the fans are blowing, its probably that the car is doing dpf cleaning.
At least that is what my dealer told me.
guido09 is offline
post #7 of 24 (permalink) Old 29th May 2010, 21:11
kenP's Avatar
Car: 2014 1.6 i-Dtec SR, Red
Hopefully I've got the answer. This is not for cooling but to pull air through the air con matrix, try turning the air con off and the fans should go off as well.
kenP is offline
post #8 of 24 (permalink) Old 30th May 2010, 01:40 Thread Starter
sotonsmut's Avatar
Unfortunately no!! turned off AC /heater completely and still on.IF it is DPF cleaning (i'm sure i dont have) how long does it last. As been going for days!!!
post #9 of 24 (permalink) Old 30th May 2010, 06:04
jagu's Avatar
my DPF cleaning only takes +/-20km (motorway).
The car only does it once every 500km.
So it doesnt keep on for days.
The fans are only working then when driving slower than 50km/h
i hope this helps
jagu is offline
post #10 of 24 (permalink) Old 30th May 2010, 08:05
Temperature sensor, had problems twice with fans running
Pete52 is offline
post #11 of 24 (permalink) Old 30th May 2010, 11:12 Thread Starter
sotonsmut's Avatar
Is that the sensor at the bottom of the Radiator.
post #12 of 24 (permalink) Old 30th May 2010, 22:25
Cockup Specialist
Relic's Avatar
There are no DPF on the UK civics
..sorry been out all day down the inlaws.
Will look on monday.... see if there are two relays or something...dont want to lose both if one packs up.
Looking more like temp sensor though.
Relic is offline
post #13 of 24 (permalink) Old 7th June 2010, 22:27 Thread Starter
sotonsmut's Avatar
Update! dissconected one of the fans(to save on battery) so the only one working is the one that works off the small grey relay in the underbonnet fuse box.Now this one is now running on after the ignition is turned off by up to a minute and a half!
Any ideas!!
post #14 of 24 (permalink) Old 9th June 2010, 19:52
I've got exactly the same irritating problem on my 06 CTDI, been going for about 2 weeks and I'm stumped. Doesn't help much I know but I can empathise with you.
ratbagsdad is offline
post #15 of 24 (permalink) Old 9th June 2010, 21:19
Cockup Specialist
Relic's Avatar
Any ideas!!
I know there are some new turbos that have a water feed.
Turbos got destroyed by people burning around and switching the engine off imeediately before the turbo had cooled down.
People are told in the manual to let the engine idle for a minute or two before turning the engine off...but few do.
RTFM is a swear word
This reduced gas temperature at idle cooled the turbo down.
Perhaps it has soemthing to do with this ??
Relic is offline
post #16 of 24 (permalink) Old 15th January 2011, 12:27
Did anyone sort this???
I have both fans running on a cold engine as soon as the ingnition is on (engine off). Aircon Off.
Please help
Sport_Coupe is offline
post #17 of 24 (permalink) Old 15th January 2011, 13:30
Cockup Specialist
Relic's Avatar
Turn the aircon/heater/climate off.... see if the fans turn off.
Tell us what the outside air temp says on the dash.
Relic is offline
post #18 of 24 (permalink) Old 16th January 2011, 11:22
Kids use a lot of space
MC Hammer's Avatar
DPF is fited to some UK cars since 2009 model, but not all.
You should know if you bought new as it would have cost a bit more!
If you have go for a run and it should clear it, short runs won't complete the cycle so keeps going for longer.
MC Hammer is offline
post #19 of 24 (permalink) Old 16th January 2011, 18:15
john87's Avatar
Car: Golf GTI
The DPF was only fitted as standard in the UK on the i-DTEC engines and not our civic i-CTDI.
john87 is offline
post #20 of 24 (permalink) Old 1st March 2011, 20:54
its your temp sender. probably ect2 (bottom of radiator), unplug it and see if the fans stop.
sthomson1 is offline
Coolant Cooling fans running? phild6 Engines and Transmission (8G) 7 22nd September 2009 08:32
Malfunctioning cooling fan? Please help! bristolchino Previous Civics 4 17th July 2009 19:53
Indications Cooling-liquid christophe Engines and Transmission (8G) 6 24th December 2007 18:03
Cooling fan kicking in Pabtyper Type-R 10 22nd May 2007 17:27
