Electrics New ecu 1300!!!! - Civinfo
post #1 of 20 (permalink) Old 3rd July 2014, 17:26 Thread Starter
New ecu 1300!!!!
Hi, had major issues with my 2.2 cdti car starting, would show engine light then vsa light then airbag, would turn over but not start. After 3 garages couldn't sort, had aa tow me to Honda. Had horrible feeling would be ecu issue and sure enough not something simple, they said needs new ecu, 1300. Excellent. Told them not got those sort of funds but after spending all day on the phone, no other garage can resolve!!! Any final suggestions??? Honda aren't interested in getting the ecu repaired by the way.
jimbojones22 is offline
post #2 of 20 (permalink) Old 3rd July 2014, 17:31
FireBIade's Avatar
Car: M200, er.....CW
ebay?
FireBIade is offline
post #3 of 20 (permalink) Old 3rd July 2014, 21:29
Bye bye Honda...
Jon_G's Avatar
Car: Volvo V60 VEA D4 (181)
Originally Posted by FireBIade View Post
ebay?
Yep, usually a few Honda ECUs there... fingers crossed you'll find the right one you need.
Jon_G is offline
post #4 of 20 (permalink) Old 3rd July 2014, 21:34
Guest
Car: 2007 2.2 ES CTDI
Breakers yard?
41034 is offline
post #5 of 20 (permalink) Old 4th July 2014, 01:29
Grayfox's Avatar
Car: '11 Impreza R Special
Eco display Eco display
ECU dont really just fail, did you remap it or mod it?
Grayfox is offline
post #6 of 20 (permalink) Old 4th July 2014, 02:18
Gezzi's Avatar
Car: CTR FN2, Milano Red
If its 100% confirmed its not a wiring issue, have they at least tried reflashing it first? Or can they at least fit a donor one just to try before you commit to buying one?
Gezzi is offline
post #7 of 20 (permalink) Old 4th July 2014, 02:23
Gezzi's Avatar
Or even get them to plug the ecm into another car and see if the fault moves?
Gezzi is offline
post #8 of 20 (permalink) Old 4th July 2014, 02:27 Thread Starter
They put a donor ecu in. Asked them if they could fix it, they said no! I was told it's not possible just to take an ecu from another car and put it in? Not that well informed on these things.
post #9 of 20 (permalink) Old 4th July 2014, 02:29 Thread Starter
No, stock ecu, car just started having starting issues and then wouldn't start at all.
post #10 of 20 (permalink) Old 4th July 2014, 02:31 Thread Starter
Si can I just purchase a second hand one and take it to honda to install it??
post #11 of 20 (permalink) Old 4th July 2014, 04:31
Grayfox's Avatar
Yes and no.
You have to make sure it is the same part number.
And even then they may say no as you could have stolen it.
Hard to say really.
Grayfox is offline
post #12 of 20 (permalink) Old 4th July 2014, 06:50
Bye bye Honda...
Jon_G's Avatar
Assuming that this dealership is happy to fit second hand parts, then yes. Fitting is easy, but they'll also need to recode it for your locking/immobiliser system. which needs specialist knowledge and equipment.
Use the Lings website... Honda Car Parts / Genuine Honda Parts | Honda Cars | Honda Motorcycles | Honda Power Products | Lings Honda to find the correct part number for your ECU/ECM (or Control Module, Engine as Honda call it)... you'll probably find it in the 'control unit, cabin' schematic.
Once you find the ECU (CM,E) it will show a Lings part number... this can be converted to the universal Honda part number by either putting it back into the Lings search box, or delete the characters '_pfk' from the web address/URL (which magically converts all part numbers on the schematic to Honda part numbers). Hope that all makes sense?
Jon_G is offline
Thanks to Jon_G from:
post #13 of 20 (permalink) Old 4th July 2014, 09:27
Civinfo's Bulb Supplier
Mr JP's Avatar
I'm not saying they are wrong, but I have seen so many dealer reports recommending new ECU required for cars which is just plain wrong and it turns out to be something else. It's usually the token response when they either haven't got a clue or haven't checked everything else.
Mr JP is offline
post #14 of 20 (permalink) Old 4th July 2014, 10:41
Stage 3 Hybrid
Trevor7979's Avatar
Car: CR-V CTDi, Silver.
Phone Elite tuning in Leeds, they should be able to sort out your ECU for you.
0113 257 5338
Trevor7979 is offline
post #15 of 20 (permalink) Old 4th July 2014, 11:29
Syx
#MrGrumpy
Syx's Avatar
Car: 2008 2.2 CTS GT
Injectors need coding also
Syx is offline
post #16 of 20 (permalink) Old 5th July 2014, 09:46 Thread Starter
Might have a result, spoke to manager of the repair center and asked I'd it would be okay to supply the part myself. He said would be okay but obviously no guarantee that it would Defford work, but must get a part from same year and even month if possible.
post #17 of 20 (permalink) Old 5th July 2014, 11:25
Type EX,A guy called Mark
markvirgo's Avatar
Car: 2015 Peugeot 208 GTI, 208BHP
I would go to Elite or TDI and avoid the dealers as they won't be much help beyond fitting and saying if it worked or not.
markvirgo is offline
post #18 of 20 (permalink) Old 5th July 2014, 12:52
Stage 3 Hybrid
Trevor7979's Avatar
Elite are the electronic experts.
post #19 of 20 (permalink) Old 5th July 2014, 14:15
Bye bye Honda...
Jon_G's Avatar
Is that the same as Premier Tuning in Halifax? I've never seen Fahad offer to repair ECUs on the TypeAccord forum that he runs... in fact, he and I both contributed to a recent thread there regarding a probable replacement ECU... Reoccurring Fault Code - Faults - TypeAccord but I'm sure they could fit one and recode it as necessary with their HDS.
Jon_G is offline
post #20 of 20 (permalink) Old 9th July 2014, 21:29
nugg_sportd's Avatar
Car: 2006 2.2 icdi sport, NHB
Send a message via Skype™ to nugg_sportd
I had a problem similar to this with my 2.2 cdti and it turned out to be the emergency fuel shut off switch in the side of the dash
nugg_sportd is offline
Tags
ecu
J33 CCC? Friday around 1300 GoatMasterUK Was it you? 0 3rd March 2012 17:39
