Alarm Key Batteries - Civinfo
post #1 of 17 (permalink) Old 6th March 2008, 07:08 Thread Starter
Key Batteries
How often should the key battery be changed ?
The spare has never been used but the main key is used twice a day.
Lexus changed both mine at 2 years, is the Civic the same ?
Kremmen is offline
post #2 of 17 (permalink) Old 6th March 2008, 07:44
GHGH's Avatar
Do you know which batterys and how they're changed?
GHGH is offline
post #3 of 17 (permalink) Old 6th March 2008, 12:25 Thread Starter
It's in the manual somewhere but I'm not sure what the change period is.
Kremmen is offline
post #4 of 17 (permalink) Old 6th March 2008, 12:53
Greedy's Avatar
The batteries are CR1616 if I remember right. Both mine and mife's have lasted 3 years with no prob at 2 journeys a day so certainly you will get 2 years evry with quite a bit of use.
You have to undo the little screw, pop the key shell apart & take out the plip module from inside the key then unclip the back from the module and the battery slips in to the back plate. It's actually quite easy once the screw is out.
Greedy is offline
post #5 of 17 (permalink) Old 6th March 2008, 12:57 Thread Starter
Thanks for the info.
I'll probably rotate the keys at the weekend so the spare gets it's use over the next year.
Kremmen is offline
post #6 of 17 (permalink) Old 6th March 2008, 13:46
Not sure about the Honda keys, but on my old 307 which is from 2002, which my wife now drives, this is still on the original battery in the key and is used at least 2 times a day.
The 307 has an onboard warning that flashes up when the key battery is low, wonder if the civic has that?
Spud is offline
post #7 of 17 (permalink) Old 6th March 2008, 14:45 Thread Starter
Ta
Just aware that if the key battery fails you need to open the car with the key itself, which sets off the alarm and I don't think it stops until you disarm it with a button press = get the other key out ?
Also, would the transponder recognise the key if the battery was dead = stuck
Kremmen is offline
post #8 of 17 (permalink) Old 6th March 2008, 15:38
Charles_Harding's Avatar
Not so sure about the alarm going off.
Sounds like we're going to have some fun this weekend when I try it out!
"I feel so miserable without you,
It's almost as if you were there anyway!"
Charles_Harding is offline
post #9 of 17 (permalink) Old 6th March 2008, 16:00 Thread Starter
I could very well be wrong
She's always telling me that
Kremmen is offline
post #10 of 17 (permalink) Old 18th March 2008, 15:51
I've brought a new battery which I keep on me (well in my jacket) just in case! Its easier looking for a screw driver if it ever goes than a new battery. The battery cost me around 7.
cnicolini is offline
post #11 of 17 (permalink) Old 18th March 2008, 15:56
Lord of JAE.....
Car: 58' NHB Type R-GT
BMW used to charge when I put my key in the ignition, and I assumed it was a similar thing.
ATB,
Unknownsoldier is offline
post #12 of 17 (permalink) Old 18th March 2008, 16:53
Greedy's Avatar
Good idea but ouch to 7.00 - buy them on ebay - 1.89 inc P&P for 2 batteries and they are Maxell & from the UK not some cruddy light weight cheapoid from Hong Kong
Greedy is offline
post #13 of 17 (permalink) Old 18th March 2008, 19:05
electric's Avatar
Car: 2017 SR CVT
In my previous car (Ford) you only had 30 seconds with the battery out of the key to insert the new battery. If you wern't quick enough it lost it settings and all keys had to be re-programmed.
electric is offline
post #14 of 17 (permalink) Old 18th March 2008, 20:49
Bob H's Avatar
Greedy is correct, the battery is a CR1616. Book of words doesn't give battery life but suggests that if it takes several pushes on the button to lock/unlock then its time to change. No other warning with regard to alarm etc..
For info, never changed the battery on my old Civic key and had that for 4 years...
Cheers,
Bob...
Bob H is offline
post #15 of 17 (permalink) Old 19th March 2008, 08:29 Thread Starter
I've switched to the 'spare' for this year and I will probably change both batteries March next year which will be the one and only time I need to do it.
Kremmen is offline
post #16 of 17 (permalink) Old 19th March 2008, 08:51
Not a good idea!!! What happens if you loose your key and need to get the car moved/started, you'll be stuck!
You will then need to buy a new battery before you can get the car going, instead of going home and collecting the spare????
post #17 of 17 (permalink) Old 19th March 2008, 09:54 Thread Starter
The other key that has been in use for a year is now sitting at home quite safely and still works.
I am now using the one that has been sitting at home for the last year unused.
If they can last at least 4 years then I should be OK till I change htem next year.
Kremmen is offline
