Satnav Best way to mount a TomTom? - Civinfo
post #1 of 6 (permalink) Old 5th May 2008, 13:28 Thread Starter
Hi all,
I recently purchased a TomTom 920T for my newly aquired Honda Civic. I had considered having the Honda satnav installed but for some 1400, it seemed a whopping sum so I decided against it.
Anyhow, I've got a TomTom and so far so good, I'm liking the interface and the screen is clear and precise. The driving instructions are good and straight out of the box, it's very easy to setup and use. The packaging too was very smart - very Apple-esque.
I'm impressed with the device, and it seems a good purchase, but there's one thing I hate - the cabling and the mounting. I've not used it much so far, but when I have done I've stuck it in the top corner of the windscreen and I hate wiring it up when it runs out of battery. As standard, the TomTom only comes with a windscreen mount - those infernal things that leave rings on my otherwise sparkling windscreen.
So, what I need now is a better mounting solution. Here's the inside of my civic (as you're all no doubt familiar with!):
Excuse my horrible scribbling, I had to use the trackpad on my laptop. The red circle (so-called) is where I'd like to put the TomTom. There's lots of space there, and it could easily be placed without obstructing the clock/audio display in the dash. The trouble is, the TomTom's ports are on its underside, so if I put it down on the dash, I can't connect any wires to it.
Also in the TomTom 920T bundle is one of these in USB form, for connecting to the PC:
The dock itself looks really smart and the TomTom fits very nicely. What I would really like is one of those with a car charger on the other end, instead of a USB cable. That way I could stick the dock to the dash and I think it'd look smart.
The other problem I have is where the charger cable has to go. The red arrow on the picture of my car's interior points to where the cigarette lighter is housed. Truly a horrible position, so I've got to have a wire running from there to the sat-nav.
Last but not least, the TomTom 920T comes with some sort of traffic cable. I haven't tried it yet cause it'll involve having the cable right up the windscreen. Don't think there's anyway to avoid that.
So to sum it all up, the TomTom itself seems great, but putting it nicely into the civic is easier said than done. Spending the extra on a built-in Satnav might just have been worth it.
Does anybody know of a good mounting solution for the Civic? How can I use my TomTom without ruining the interior look of the car?
Parm is offline
post #2 of 6 (permalink) Old 5th May 2008, 15:10
Go to Brodit Proclip | UK | DSLDevelopments and have a look at the Honda Civic specific mounts.
Search on the basic "Civic" and not any of the other variants, then select 2006.
Both locations you mention are catered for but I would favour the air-vent mount as it needs to be in line of sight.
Kremmen is offline
post #3 of 6 (permalink) Old 5th May 2008, 15:35 Thread Starter
Hi Kremmen, thanks for the tip!
I've just had a look on the Brodit website though and I can't find any mounts made for the Civic dash. My picture probably isn't clear enough that, what I'm after is something that'll let me put the TomTom on the flat part of the dash. In front of the clock, the flat surface above the air vents.
Or maybe I'm just not seeing it on the Brodit site...
Parm is offline
post #4 of 6 (permalink) Old 5th May 2008, 16:41
AnnaBella's Avatar
Actually, Brodit do ones for the Civics dashboard.
http://www.brodit.se/montering.jsp?anr=853732
Unfortunately, its in Swedish. I'm still looking for a retailer. Will let you know if I hear of anything.
AnnaBella is offline
post #5 of 6 (permalink) Old 5th May 2008, 16:42
wizking's Avatar
Hello Mate.
I use a doughnut on the dash with an alternative mount in that. This allows for the tomtom to be much closer to you and the doughnut never marks or moves.
TOMTOM GO 520 GO 720 GO 920 ALTERNATIVE MOUNT KIT - TomTom GO Accessories
PORTABLE CUSHION FRICTION MOUNT - ROUND (SKU 3122)
wizking is offline
post #6 of 6 (permalink) Old 5th May 2008, 19:15
Did you find the 3 Civic dedicated variants ?
The one closest to what you want would be the air-vent ProClip.
Kremmen is offline
brodit mount installation help Type S Bournemouth General Discussion (8G) 16 1st July 2014 11:01
Mounts Mount your satnav on the dash Azbo Electronics (8G) 45 3rd January 2010 09:57
Mounts Sat Nav - vent mount for Garmin Nuvi? lhirst Electronics (8G) 2 11th January 2007 23:28
Can't think where I could mount it Maldax Any non Civic chat here please! 0 11th July 2006 19:41
