Electrics Indicators - Civinfo
post #1 of 13 (permalink) Old 27th May 2008, 11:02 Thread Starter
Dave25's Avatar
Question Indicators
If I use the ' lane changing facility' on the indicators ( press the indicator control gently and it indicates 3 times) it works fine but doesn’t work on the motorway. I can only assume that it only works up to a certain speed.
Is there any adjustment to set the speed that it works up to
Dave25 is offline
post #2 of 13 (permalink) Old 27th May 2008, 11:05
MIne work fine at all speeds.
milano sport is offline
post #3 of 13 (permalink) Old 27th May 2008, 11:08
Lord of JAE.....
Car: 58' NHB Type R-GT
Same here, maybe your just hitting it a bit too hard on the m/w, mine is temperemental on the force it needs to work on the three blinks feature.
Unknownsoldier is offline
post #4 of 13 (permalink) Old 27th May 2008, 11:17
sallytraffic's Avatar
Yes, it took a while for me to get this right. It takes a very short flip of the stalk to a rather precise position part way to full travel. You need a very brief touch of the first point of resistance. Any more than a fraction of a second and it will not work.
I have had no speed related issues in using it after getting the 'knack' of doing it.
sallytraffic is offline
post #5 of 13 (permalink) Old 27th May 2008, 11:17
The switch to use your blinkers is very sensitive, if you hold it too long up (or down) it won't blink 3 times, just flick it up (or down) a bit faster... works fine with mine
G.
CivicLover_BE is offline
post #6 of 13 (permalink) Old 27th May 2008, 11:22
emmaloula's Avatar
Mine works at all speeds too. Just takes some getting used to I think.
emmaloula is offline
post #7 of 13 (permalink) Old 27th May 2008, 11:23
I've found, as Sallytraffic says, there is a 'knack' to it. Once you've got it you'll be fine.
Dimplyred is offline
post #8 of 13 (permalink) Old 27th May 2008, 11:32
Lord of JAE.....
Agreed, knack to getting it just right, it's almost just a brush past it as it needs to be incredibly briefly touched.
post #9 of 13 (permalink) Old 27th May 2008, 12:15
pjr
pjr's Avatar
Car: Mk VII Golf GTI
Yes, just needs the briefest of flicks - hold it too long and you just get one flash. As Sallytraffic & Unknownsoldier have said it takes a bit of practice, but once you know the technique it is quite easy.
pjr is offline
post #10 of 13 (permalink) Old 27th May 2008, 14:15
Bungle's Avatar
It's a useless feature, and certainly no good for changing lanes on a m/way!
The only thing it is good for IMO is for exit signal at smaller roundabouts.
The reason 3 flashes is never enough on a m/way is simple. It gives no warning of your intent and it is impossible to complete the manoeveur safely within the 3 blinks.
I would let it flash at least 3 or 4 times before starting to mover, then it will need another 3 blinks or so to move from one lane to the next. I make that at least 6 or 7 blinks to do it properly.
The trouble is my Corsa L car has the same feature, but it can thankfully be disabled from the menus.
Thinking more about it, I would also say it is OK for passing obstructions like busses who might be thinking about moving away or for bin lorries etc.
Bungle is offline
post #11 of 13 (permalink) Old 27th May 2008, 14:29
emmaloula's Avatar
I agree with you and it's a case of using common sense to determine when the best time to use it is. It's nice to have the option.
post #12 of 13 (permalink) Old 27th May 2008, 20:13 Thread Starter
Dave25's Avatar
Will have another play, maybe not doing it quite right. Still perplexed that it seems to work sometimes with no issues but cant get it to work at all sometimes and it does appear to be speed related but maybe its just me. Aware of the limitations of the function but just bugging me .
Dave25 is offline
post #13 of 13 (permalink) Old 2nd June 2008, 09:47 Thread Starter
Dave25's Avatar
Tried the function again; works no problem at speeds up to 50 MPH or so but once above approx 60 MPH it will not work. So on my car is definite speed related. ( regardless of the usefulness or not of this facility )
Looks like remaining a mystery
Dave25 is offline
Indicator Lane change indicators Tomthumb Lights (8G) 39 3rd July 2010 15:47
Indicator Automatic cancelling of indicators 4415 Lights (8G) 16 10th August 2007 08:52
Electrics Dashboard Indicators PaulB Bugs, faults and irritations (8G) 15 24th April 2007 22:34
Indicator indicators? MARK182 Lights (8G) 2 19th January 2007 17:27
Rear Indicators elfa7 General Discussion (8G) 3 25th August 2006 06:33
