Cruise Cruise Control - Civinfo
post #1 of 52 (permalink) Old 31st May 2008, 23:25 Thread Starter
NoNumpty's Avatar
Car: 2008 2.2 i-CTDi ES NHB
Cruise Control
Had a bit of an odd occurrence with the cruise control today.
Was travelling down an A road at 50 mph in 5th gear and pressed the SET/DECEL button and nothing happened (yes the cruise control was enabled). Tried a couple of times but it wouldn't engage - changed to 6th and tried again and this time cruise control engaged.
Does cruise control only operate in 6th?
NoNumpty is offline
post #2 of 52 (permalink) Old 31st May 2008, 23:27
Car: MX-5, C6 Vette & MB S212
No, it should operate in any gear.
Recall someone posting a similair issue...
Try searching for that... can´t remember if it was a defective switch or something else.
FWH is offline
post #3 of 52 (permalink) Old 31st May 2008, 23:38
The Talented Mr. Robbieee
Robbieee's Avatar
Car: Ford Fiesta Zetec S
I would monitor that if i were you. Sounds like the switch to me. It shouldnt matter what gears your in....
Robbieee is offline
post #4 of 52 (permalink) Old 31st May 2008, 23:45
FWH is offline
post #5 of 52 (permalink) Old 31st May 2008, 23:50
Robbieee's Avatar
I looked at that thread too, but the outcome was there was nothing up with the switch.
Robbieee is offline
post #6 of 52 (permalink) Old 1st June 2008, 00:49
Naughty but nice
angie4m's Avatar
Car: Z4 sDrive35is
Mines does that sometimes. Did it this morning was in 6th and it wouldn't engage then after several presses and speed dropping it did. Its also happened when i've had it on then had to brake then tried to put it back on and it wouldn't work.
It doesn't happen all the time thats the strange thing. I went a whole weeks driving using cc and had no issues, then it decides to go haywire for no reason several weeks later.
angie4m is offline
post #7 of 52 (permalink) Old 1st June 2008, 01:49
ViBe's Avatar
mine does that as well sometimes. When it does I just keep pressing it harder until it engages, usually 3 or 4 times.
ViBe is offline
post #8 of 52 (permalink) Old 1st June 2008, 03:10
Car: DS3
I love the cruise control , mine works in all the gears.
illegalhunter is offline
post #9 of 52 (permalink) Old 1st June 2008, 09:33
oldmanchris's Avatar
Its great for average speed camera areas but tempremental. I had to have a look at the manual to see if I was doing something wrong.
oldmanchris is offline
post #10 of 52 (permalink) Old 1st June 2008, 16:58 Thread Starter
NoNumpty's Avatar
Thanks for all the post guys
I've figured out what was happening
if my left foot just rests (not pressing) the clutch pedal, cruise control will not engage - the reason it always worked in 6th was I moved my left foot to the foot rest so was well off the clutch pedal
this clutch switch is a bit sensative me thinks
Anyway will adjust my driving habits
NoNumpty is offline
post #11 of 52 (permalink) Old 1st June 2008, 17:01
Glad to hear it is sorted!
Resting your foot on the clutch is a bit of a bad habit as it may cause the clutch to wear out quicker.
FWH is offline
post #12 of 52 (permalink) Old 1st June 2008, 17:09 Thread Starter
NoNumpty's Avatar
Yeah!! didn't realise that was what I was doing
Lesson learnt
by the way, the biting point on the clutch seems to be when the pedal is near the floor so I don't think I was affecting the clutch - stop it, it's sorted - take you foot off the pedal you Numpty
NoNumpty is offline
post #13 of 52 (permalink) Old 1st June 2008, 22:27
ViBe's Avatar
I wonder if this is wy my wont engage sometimes as well.. I know I have a habit of resting the foot on the clutch while driving in the lower gears... gotta put a camera down there to se what my feet are up to while driving lol
ViBe is offline
post #14 of 52 (permalink) Old 1st June 2008, 22:56
Naughty but nice
angie4m's Avatar
Car: Z4 sDrive35is
Or you could make a mental note to make sure if it happens again you move your foot right up against the furthest part of the foot rest and that way you can be sure if your foots on the clutch. I'll need to check that one cause you usually put the cc on when you've got into 6th and just changed gear.
Jings Nonumpty you may have solved a problem a few of us have been having for a wee while. I'll have to wait until i'm out in the car again tho to check mines
angie4m is offline
post #15 of 52 (permalink) Old 1st June 2008, 22:58
I usually tap very very lightly on the clutch to disengage the CC when coasting off the motorway or something.
FWH is offline
post #16 of 52 (permalink) Old 1st June 2008, 23:26
Naughty but nice
angie4m's Avatar
Car: Z4 sDrive35is
I use the button but usually the cc on and off button not the cancel button. I like the clicking noise from it, I know that cause i've found myself tapping it on and off for no reason, but i'm getting better at hitting cancel especially on long drives
angie4m is offline
post #17 of 52 (permalink) Old 3rd July 2008, 06:33
HappyMan's Avatar
Car: 2016 Ford Kuga Titanium
Yesterday I was driving along a road where I could use CC and as you do not really concentrating on the gear situation I had got to 5th and engaged CC - I was feeling lazy and have seen i great increase in economy using it. It was only when I looked down I realised that I was in 5th and not 6th, so in my car you can engaged CC in any gear it seems.
To disengage CC I use a variety of methods from touching the clutch to needing to use the break as some intellectually challenged driver has just pulled out in front of me to using the button. All depends on my mood.
HappyMan is offline
post #18 of 52 (permalink) Old 3rd July 2008, 13:45
K20A's Avatar
Car: 2007 CTR, NHB
Need to hold the throttle (or accelerate) when press the set button, if you leave up and press it won't engage.
K20A is offline
post #19 of 52 (permalink) Old 3rd July 2008, 13:46
R - 11859
ctrdaveg's Avatar
Car: 2008 Type R-GT Silver
You may have a similar problem that i had on my CTR.
The rocker switch on the steering was faulty. It would only work now and again.
The technician from the dealer hit the steering wheel hard just to the side of the switch and it cut out while driving along. He then hit it again and it came back on again.
Therefore a new switch was fitted and it's fine now.
Also when you select "set", make sure you have not got your foot near the brake or clutch pedal as they are sensitive.
Hope you get it sorted. Also it doesn't work under 28mph
ctrdaveg is offline
post #20 of 52 (permalink) Old 3rd July 2008, 14:19
DeanFYoung's Avatar
Mine engages fine when not on the throttle at all.
DeanFYoung is offline
Electrics No Cruise control Diesel Virgin Bugs, faults and irritations (8G) 22 23rd December 2007 22:08
MPG More or less MPG with Cruise Control? matg Engines and Transmission (8G) 7 12th December 2007 14:24
Engine Cruise control angie4m Bugs, faults and irritations (8G) 36 1st November 2007 15:17
Cruise How To Use Cruise Control abu-sarta Electronics (8G) 5 12th June 2007 14:08
Cruise Cruise control honda4ever Electronics (8G) 8 30th September 2006 12:42
