AC/Heater Question about AUTO function - Civinfo
post #1 of 14 (permalink) Old 12th June 2008, 08:58 Thread Starter
I have question about the auto function of climate control at my Type-R. I think that originally when turned on the AUTO function I had the AUTO sign displayed at both boxes with set temperature left and right side too, now when I turn the AUTO on it's dispalyed only at the driver's side, not at the passenger's side. Is it ok or can I turn the AUTO sign on at the passenger's side somehow on too? Thanks for any advice...
lukasgtuh is offline
post #2 of 14 (permalink) Old 12th June 2008, 09:33
gm1980's Avatar
Have a check if the dual side button is activated
gm1980 is offline
post #3 of 14 (permalink) Old 12th June 2008, 09:49 Thread Starter
I think I tried already all possible combinations, even with the DUAL button on , but the AUTO sign on the display still appeared only on the driver's side....do you have the AUTO sign when it's activated on the both sides of the display right next the temperature box?
post #4 of 14 (permalink) Old 12th June 2008, 09:53 Thread Starter
Oh I'm sorry, cause I see that you have sat/navi so you have slightly different display then I have, where it's only one sign AUTO between the temperature boxes...
post #5 of 14 (permalink) Old 12th June 2008, 09:53
iamholam's Avatar
On my EX there is only 1 auto symbol and that is in the centre between the 2 temperature readings. I would imagine that that is the same for you:
Different temps 1 auto setting.
iamholam is offline
post #6 of 14 (permalink) Old 12th June 2008, 09:55
Lord of JAE.....
Car: 58' NHB Type R-GT
I thought it only came up in the middle of the two numbers???? Does on my GT.
Unknownsoldier is offline
post #7 of 14 (permalink) Old 12th June 2008, 10:11 Thread Starter
But you have different dispaly,cause you have sat/navigation, but I have only dual A/C , no navi, so I have wider display with two temparature readings for driver side and for passenger side on the left and right corner, and based on the picture in the operation manual it should show the AUTO sign on the both sides, but my car does only on the driver's side...
post #8 of 14 (permalink) Old 12th June 2008, 10:49
HappyMan's Avatar
Car: 2016 Ford Kuga Titanium
I have just been down to my car and checked my display as i have the same one as you. I only have the 'AUTO' sign on the left side of the display.
Hope that helps
HappyMan is offline
post #9 of 14 (permalink) Old 12th June 2008, 10:50
Lord of JAE.....
My display still registers both side temps and and notes the Auto function, from memory only the size changes in this instance.
post #10 of 14 (permalink) Old 12th June 2008, 11:41
Send a message via MSN to RabidManx
Another AUTO question......when its on, does the light for what I assume is air recirculation light automatically come on as well?
RabidManx is offline
post #11 of 14 (permalink) Old 12th June 2008, 12:11
pjr
pjr's Avatar
Car: Mk VII Golf GTI
Yes, the orange light on the recirculation button comes on automatically when the system automatically engages recirculation.
I've been seeing this light on every night recently when I leave work and the car has been sitting baking in the car park all day.
pjr is offline
post #12 of 14 (permalink) Old 12th June 2008, 12:19
NoNumpty's Avatar
Car: 2008 2.2 i-CTDi ES NHB
Goes off when the car reaches the desired temperature
NoNumpty is offline
post #13 of 14 (permalink) Old 12th June 2008, 13:15 Thread Starter
Ok, thanks, that helped a lot, cause now I can be sure that everything is fine with AUTO mode
post #14 of 14 (permalink) Old 12th June 2008, 14:10
Thanks for the sxplanation peeps!
Satnav Sat Nav Question blader Electronics (8G) 7 26th May 2008 12:34
Survey from AUTO TRITI (Greek Auto Motor und Sport magazine) rallakias User Reviews 10 25th February 2008 14:07
Electrics Electric Window mal-function Charles_Harding Bugs, faults and irritations (8G) 3 28th April 2007 20:08
Question for Everyone Brodick General Discussion (8G) 8 20th January 2007 18:57
Exterior VIN question szyba Bugs, faults and irritations (8G) 9 12th January 2007 21:56
