Alarm Civic key advice - Civinfo
post #1 of 7 (permalink) Old 17th June 2008, 19:29 Thread Starter
Civic key advice
I own a 2006 civic dm shape and would like another key for it.
If i buy a used cut key and remove the internals and then put the internals into a new uncut key will i be able to get the key registered to my car.
I suppose my question is can the chip be written over and over again or can it be written only once.
I understand that the key needs to be coded to the ecu but not sure if i had to buy the new internals with a chip that had not been written before.
Please can you advise thanks.
TYPE R MAN is offline
post #2 of 7 (permalink) Old 18th June 2008, 13:16
Naughty but nice
angie4m's Avatar
Car: Z4 sDrive35is
See the Who wants a filp key thread. Put that in the search and the guys there will tell you what you can and cannot do.
angie4m is offline
post #3 of 7 (permalink) Old 18th June 2008, 17:20
I've just looked on ebay at a number of used civic keys for sale. In one of the listings the seller states,
' Dealers generally do not have the equipment to reprogram used fobs, they are often only kitted out with the equipment and knowlege to program your vehicle ECU to the latest new item supplied for your vehicle model. '
If I was you I would contact your dealer and explain what you want to do and see if they can help.
Dimplyred is offline
post #4 of 7 (permalink) Old 18th June 2008, 18:21
That's utter rubbish. What does he think happens when a customer looses one key/fob and has the other remaining? turn around to the customer and say that he/she has to order two replacements??? You can re-program the transmitters as many times as you like.
Holdcroft_Honda is offline
post #5 of 7 (permalink) Old 18th June 2008, 18:27
I suspect he is covering himself it the eventuality that it doesn't work at all, like a lot of ebay sellers, they don't want to know once they have got your money.
Thanks for clearing that one up.
post #6 of 7 (permalink) Old 18th June 2008, 22:37 Thread Starter
Thanks for the reply,still 50/50 to go ahead with it as you get some conflicting replies.
Holdcroft Honda i have been told by someone in the pub that the dealers use something called HDS ? which can re-write or add keys to the system can you advise on this as i did not know if this would only work with a unused chip etc.
If by what you are saying is YES go ahead it will work no problem then i will go for it but thought i would ask again first "sorry".
Thanks again for the reply..
post #7 of 7 (permalink) Old 18th June 2008, 23:23
I think you can go ahead and buy one now.
Holdcroft Honda are a main dealer and have said you can re-program a key as many times as you like. Good enough for me.
Questions Considering getting a civic, advice? tomsel Buying, Dealers and Servicing 37 6th June 2008 20:50
Dealers Buying civic advice need sahal Buying, Dealers and Servicing 23 13th April 2008 00:10
Questions Advice on new civic festa Buying, Dealers and Servicing 8 12th April 2008 15:08
Advice on selling my 07 civic 1.8 SE discostu General Discussion (8G) 7 28th March 2008 21:15
Used advice please!! looking for a civic type s diesel davep Buying, Dealers and Servicing 17 24th September 2007 16:28
