Phone Parrot HFT and DICE Ipod player - Civinfo
post #1 of 3 (permalink) Old 8th July 2008, 12:47 Thread Starter
high.pressure's Avatar
Hi Guys, I am looking for a bit of advice.
I plan to install a Parrot hands free kit and an Dice for the Ipod, having read all of the posts in the various threads I have the following questions that I would appreciate some feedback on.
1) Can I install both kits or do they need the same connector on the back of the radio ?
2) If question 1 is yes then do I need a "Y" splitter ?
3) With the standard parrot kit will it allow you to use the steering wheel controls or do you need an extra bit ? if so what ?
Having read all of the "how to's" I feel sort of ok about going for the installs myself, nothing ventured nothing gained as they say !
Plan to put the Ipod connector in the cubby hole above the gearstick and I think the parrot where the cigarette lighter is, over the heated seat switches that I dont have ! Relocate the cig lighter into the centre consule for charging phone etc...
The planning stage is almost complete
Steve
high.pressure is offline
post #2 of 3 (permalink) Old 21st July 2008, 13:55
THP
Form & Function
THP's Avatar
Car: 2007 NHB CTR GT
1) yes they use the same connector in the back of HU
2) yes you need to use an "Y" splitter
3) yes you need an extra bit, go to www.parrot.com and you the part No. for your car/HFT set.
Make yourself ! It's not "too hard" ( belive me, i do it! )
Most important is to test everything you put in the car before "close"
the dashboard, belive me, i don't do it
THP is offline
post #3 of 3 (permalink) Old 22nd July 2008, 13:35
THP
Form & Function
THP's Avatar
Sorry Hight.Pressure, yesterday i give you some wrong info...
Here is the right ones...
1)They use 2 different "ports" ( one for connect the HU to car, the other
is to connect additional souces)
2)An Y splitter is not absolutely necessary, but i strongly reccomend to you
to connect your HFT to HU. If you 're experienced you must cut/ soldering/
jump-wiring some cables from HFT to car's main wiring harness...
Consider that an Y splitter lets you fit an HFT in a breeze, and in a "cleaner" way.
Many after-market brands produce an Y splitter specifically designed for your Civic.
3) this answer is ok!
Sorry for the mistake!
THP is offline
Thanks to THP from:
My install [how to guide] iPod/iPhone DICE box car Kit installation ashkeenon Ipods, MP3 Players and ICE (8G) 112 14th October 2010 20:05
AUX in Ice>Link Gateway 100 or DICE iPod Car Kit smi99th Ipods, MP3 Players and ICE (8G) 28 20th September 2008 22:06
My install iPod and/or iPhone / Parrot Bluetooth all working smoothly! Sav Ipods, MP3 Players and ICE (8G) 6 28th May 2008 01:56
AUX in Dice iPhone iPod Car Kit recomendations!!!? ashkeenon Ipods, MP3 Players and ICE (8G) 5 9th May 2008 16:17
AUX in iPod EX interface - Dice has possible solution! gnyf Ipods, MP3 Players and ICE (8G) 2 17th August 2007 23:04
